Old 12-24-2008, 06:52 PM   #1
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Default Reversed Intake Manifold
2001 2.5RS w/ EJ257, SOHC, GT3582R, Blitz FMIC
Just want to clarify a few things. I'm trying to figure out a plan of attack with my mechanic on how to go about the reversed intake manifold route. My understanding is that if I want to keep the AC, all I need to do is drop the alternator and get a shorter belt. The sensor wires and applicable vac lines need to be lengthened. A spacer must be fabricated to angle the throttle body down away from the hood. I assume this is an essential and can't be worked around.
He mentioned the possibility of flipping the throttle body (in lieu of the spacer???). I can't find any information on this. Has anybody ever accomplished this on a scooby or.... is it even possible?
Thanks guys.
-Brett
Last edited by ExecNav; 12-25-2008 at 09:12 AM. Reason: Wooooooo too much wine.....
ExecNav is offline   Reply With Quote
reverse intake manifold and fmic OneArmedScissor Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-29-2004 04:14 AM
Is there a reverse intake manifold made to fit a PII ej25? wighti Normally Aspirated with bolt-on Forced Induction Powertrain 7 08-11-2003 02:39 PM
reversed intake manifold QAboy Normally Aspirated Powertrain 3 12-13-2002 12:04 PM
Saw this on scoobynet, reverse intake manifold!!! pio!pio! Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-13-2002 10:44 PM
Reversed intake manifold Really_Soaked Normally Aspirated with bolt-on Forced Induction Powertrain 6 11-14-2001 09:49 AM
