Old 12-24-2008, 07:52 PM   #1
SubieGenius
Member#: 176874
2000 Impreza 2.5 Rs
SilverThorne
Default Inspection Probs...
Hey guys i got 2 codes p0420 and p0442, i bought a new gas cap at advance auto but that did not fix the p0442. How can i fix these?
I have borla replica headers and a catback.
SubieGenius is offline   Reply With Quote
Old 12-24-2008, 08:13 PM   #2
snaggleto0th
Member#: 184408
2002 Impreza WRX
Probably DO have a EVAP leak. Only way to find out is by doing a smoke test. Which most shops should be able to do for EVAP leaks. Or clear it again and tighten the gas cap 3 clicks tight...Still doesnt solve the problem take it to a shop to fix the leak. If you cant afford to go to a shop then try to find a broken/damaged/loose hose on the evap lines and go from there.
snaggleto0th is offline   Reply With Quote
Old 12-24-2008, 08:15 PM   #3
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
the correct place for this thread would be the Normally Aspirated Powertrain forum
MannyMohawk#5 is offline   Reply With Quote
Old 12-24-2008, 08:43 PM   #4
Jack
Add Lightness
Member#: 13699
2004 45k mile Outbac
(From General)
and away we go......
jack
Old 12-24-2008, 09:56 PM   #5
EdHilario
Member#: 137398
2004 Impreza 2.5RS
P0420 is cat inefficiency. Are you running catless? You can do the MIL fix.
EdHilario is offline   Reply With Quote
Old 12-24-2008, 10:07 PM   #6
seanvetter123
Member#: 174476
2002 Impreza RS
BRP
i have E-bay replica header and 2.5" CBE and stock cats. i was getting the P0420 code all the time till i replaced my front O2 sensor. easy fix but kinda spendy. i still throw the P0420 code every now and then when it is cold but i just clear it and it is no big deal cuz i know why it is being thrown.
seanvetter123 is offline   Reply With Quote
Old 12-24-2008, 10:31 PM   #7
SubieGenius
Member#: 176874
2000 Impreza 2.5 Rs
SilverThorne
IM running stock cats =/ Any other solutions?
How much is a front 02 sensor?
Old 12-24-2008, 10:40 PM   #8
seanvetter123
Member#: 174476
2002 Impreza RS
BRP
Old 12-24-2008, 10:48 PM   #9
EdHilario
Member#: 137398
2004 Impreza 2.5RS
So you have the 1 cat on the midpipe? If so, that cat is after the sensors.
Old 12-24-2008, 10:51 PM   #10
SubieGenius
Member#: 176874
2000 Impreza 2.5 Rs
SilverThorne
Confused, =/ please elaborate.
Also, i dont think my front 02 sensor is bad, but i know lots of people get the p0420 code bcause of the headers But they run catless, or hf cats, im running stock so wtf?! Do i need new cats? Sensors? Maybe wrap my headers?
Old 12-24-2008, 10:52 PM   #11
seanvetter123
Member#: 174476
2002 Impreza RS
BRP
ya i dont know if that makes any sense cuz the 02 sensor is always before the cats.
Old 12-24-2008, 11:15 PM   #12
piker28
Member#: 22664
It is very common with your setup to get a CEL, the people you probably are thinking of own 03 and newer RS's and they are not as picky about exhaust mods. Best bet is to slap on some stock headers and go that way
piker28 is offline   Reply With Quote
Old 12-25-2008, 08:58 PM   #13
SubieGenius
Member#: 176874
2000 Impreza 2.5 Rs
SilverThorne
Will wrapping my headers help with the p0420 code?
Old 12-25-2008, 09:34 PM   #14
EdHilario
Member#: 137398
2004 Impreza 2.5RS
O2 sensors are before and after the cats. The job of the rear one is to see is if you're cat is working or whether or not you have a cat. Otherwise P0420 will go on. Wrapping your headers will not replace having a cat in your exhaust. That's so stupid.
Old 12-25-2008, 10:05 PM   #15
SubieGenius
Member#: 176874
2000 Impreza 2.5 Rs
SilverThorne
Im running stock cats, and my 02 sensors were replace not too long ago. I got this code after i got my headers installed. So it was a stab in the dark. Canada's stupid.
Old 12-25-2008, 10:52 PM   #16
EdHilario
Member#: 137398
2004 Impreza 2.5RS
lol kid. Alright no more help for noobs.
Old 12-25-2008, 11:06 PM   #17
piker28
Member#: 22664
actually some have said that wrapping them does help that cel go away but it is never a gurantee. Also said to help cause cracking with the increased heat.
Eitherway why not put stock headers on and be done with it
Old 12-26-2008, 12:01 AM   #18
SubieGenius
Member#: 176874
2000 Impreza 2.5 Rs
SilverThorne
I dont have my stockers anymore, and i just bought an ispeed reflash, so it would **** the car up if i didnt have headers.
Rear Rotor prob or alignment prob? kaijubei Brakes, Steering & Suspension 7 08-03-2009 02:15 AM
Help inspection prob. scoobydude123 Texas Impreza Club Forum -- TXIC 3 07-10-2005 08:51 AM
Passed inspection with 1 HFC - no prob savka Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-24-2004 09:05 AM
Synchro prob or clutch prob? Evaider Transmission (AT/MT) & Driveline 4 03-19-2002 10:27 AM
RS probs, n1 same probs ? Kwez Technical Forum Archive 9 10-11-2000 10:12 PM
