Old 12-24-2008, 08:26 PM   #1
bradze
Member#: 103208
2011 Outback
Azurite Blue
Default any differences on r180 differential from usdm to jdm
my wrx has a usdm ej257 and trans/rear diff, axles, hubs from a jdm sti. ive been told by the garage that got it for me that its exactly the same except for 5th and 6th gear. just need to make sure before i get a carbon driveshaft.
bradze is online now   Reply With Quote
Old 12-24-2008, 11:01 PM   #2
bradze
Member#: 103208
2011 Outback
Azurite Blue
just read an edm sti diff is different. they were both with a 2.0l, need to talk to PIA
Old 12-25-2008, 01:40 AM   #3
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
Some JDM 01-06 R180s are Suretrack and some are mechanical clutch. Then in 07 some are torsen and most are clutch.
Some have the rear diff temp sensor some don't.
Then the most important part for you, when ordering a driveshaft, is that there are two different flange bolt patterns. Some use the smaller one from the R160 and some use the larger one like we have on our USDM R180 rears. I am not sure if its a year dependant or diff type dependant thing. They can easily be changed though, and I think the R160 and R180 yokes are interchangeable. You can get the yokes for about $80 at the dealer in case you need the larger one.
FourOnTheFloor65 is offline   Reply With Quote
Old 01-09-2009, 09:36 AM   #4
thejean
Member#: 17763
Do you know what type of the diff the V8 R180 is?
thejean is offline   Reply With Quote
Old 01-10-2009, 03:34 AM   #5
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
It depends. If the car it came out of had DCCD, it is a mechanical clutch type. If the car was non DCCD it is Suretrac.
Old 01-10-2009, 12:12 PM   #6
thejean
Member#: 17763
It is DCCD so I am stoked that I get the clutch-type.
Old 01-10-2009, 12:30 PM   #7
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
That's accurate..I have a mechanical v8 R180 - DCCD type transmission too.
zeropsi is offline   Reply With Quote
Old 01-21-2009, 01:48 PM   #8
thejean
Member#: 17763
So where does the temp sensor wires go when swapping into a WRX as I don't believe this is in the WRX harness.
help : rewiring taillights from USDM to JDM razy Interior & Exterior Modification 2 04-10-2007 08:29 PM
USDM - to - JDM part interchangability (engine) Subarutex North West Impreza Club Forum -- NWIC 1 10-07-2006 05:33 PM
Who makes the harness for the bug eye usdm to jdm guage cluster swap? S14guy Subaru Conversions 1 03-01-2006 10:02 PM
Opinions on USDM to JDM fitment... e11ys Subaru Conversions 12 02-01-2005 11:07 AM
Any differences or preferances for quality guages to price... strohausii Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-14-2003 08:27 PM
