Welcome to the North American Subaru Impreza Owners Club Thursday February 11, 2016
Old 07-27-2014, 10:04 PM   #1
thekamkikaze kid
Member#: 375498
Default stage 2 advice...
ok so i have an 03 wrx with 122k on it. right now i have a cobb sf intake, borla 14978 catback, and cobb ots stage 1 93 oct tune. i am looking to go stage 2.
i plan on putting on a cobb catted dp, walboro fuel pump, and cobb 3 port ebcs. then getting a dyno tune at elite auto works in goshen ny.
my question is does this sound like a good plan (would you suggest different parts?) and has anyone had any experience with elite autoworks in goshen?
any help would be aswesome!
thekamkikaze kid is offline   Reply With Quote
Old 07-28-2014, 12:49 AM   #2
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Talk to your tuner. This has be covered hundreds of time. I know that is a dick thing to say. Make sure you do a pre-dyno stuff. Compression test, change oil, boost leak test, change plugs. Put 3-port on day of in parking lot.
Brother EddieJ. is offline   Reply With Quote
Old 07-28-2014, 07:50 AM   #3
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Help? Talk to your tuner.
Does this sound like a plan? Sure, much like what thousands have done before you.
Old 07-28-2014, 10:32 AM   #4
cmiovino
Member#: 134005
2004 WRX Premium
Install DP yourself, run stage 2 tune from AP. Possibly even for a bit... days, weeks.
Then get the EBCS and tune later once all that is functioning. Make sure to do a compression test, vacuum/boost leak tests, and some datalogs on the AP before the final tune.
Old 07-28-2014, 03:23 PM   #5
thekamkikaze kid
Member#: 375498
the only reason i ask is that the dyno hasnt gone in yet so i cant talk to a tuner yet, not sure yet if they even know who is gonna tune. so obviously i cant talk to a tuner. which makes me a little nervous. only reason im bringing it to elite is that its within a reasonable distance and i dont feel like driving to antother state to get tuned. so im just waiting to talk to a tuner basically. i have heard that gettinig a dyno tune is much better than using ots maps.
Old 07-28-2014, 03:39 PM   #6
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
not if they get a tuner who does not know what their doing. just install the downpipe and flash the ots stage2 map for now until you get your tuner figured out
alexandern05 is offline   Reply With Quote
Old 07-28-2014, 03:45 PM   #7
thekamkikaze kid
Member#: 375498
i was hoping to get it all done in one shot. im in no rush to put the parts on. im gonna talk to the tuner and make sure he knows his stuff before i get the tune. i suppose i could always flash the stage 2 + ebcs map with the parts im getting. only problem is no one has any experience with that map, either way im taking a risk.
Old 07-28-2014, 03:50 PM   #8
thekamkikaze kid
Member#: 375498
how much do all those tests cost?
Old 07-28-2014, 04:52 PM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Call 3 shops and ask. There is no set price across the board.
Old 07-28-2014, 08:46 PM   #10
thekamkikaze kid
Member#: 375498
thanks for the help. I have talked to a few e-tuners and 2/3 recomended a fuel pump and 3 port ebcs. originally i was going to just get a downpipe. is the fuel pump and ebcs really all that necessary? im looking for a dependable ride, not just a fast car that is gonna break on me.
Old 07-28-2014, 09:44 PM   #11
Visonik
Member#: 360822
2002 Stage 2 WRX
Silver Frost Metallic
I'm running a full stage 2 with catless up pipe and turbo back exhaust. I haven't upgraded the fuel pump and my tuner has not recommended it. Once I do a turbo upgrade, the pump and injectors and what not will be upgraded, however.
Visonik is offline   Reply With Quote
Old 07-28-2014, 09:48 PM   #12
Brother EddieJ.
Member#: 181617
2004 wrx
im gonna talk to the tuner and make sure he knows his stuff before i get the tune. .
How exactly are you gonna find out if he knows his stuff? If you knew more than him, you would be tuning your own car.
Fwiw OTS stage 2 will hold you over nicely for a while.
Old 07-28-2014, 10:03 PM   #13
thekamkikaze kid
Member#: 375498
thats why im posting lol! but of course ill ask how long hes been tuning and how many subarus hes done yada yada. you can usually tell whose full of ****.
Old 07-28-2014, 10:31 PM   #14
tomacGTi
Member#: 297396
If you have an Accessport then why aren't you consulting the map notes? They tell you exactly what you need for whatever stage you desire.
IIRC they have even written stage 2 maps for their EBCS. The absolute minimum you need for OTS stage 2 from Cobb is the DP and catless up.
Obviously if you are looking to get protuned, that's a whole different story.
tomacGTi is online now   Reply With Quote
Old 07-28-2014, 10:56 PM   #15
thekamkikaze kid
Member#: 375498
The stage 2 plus EBcs map has just come out and no one knows if it's reliable or not. But anyway I'm tryin to get pro tuned. No one here has any experience with elite auto works?
Old 07-29-2014, 01:03 AM   #16
Rymaster
Member#: 296277
2002 Impreza WRX
I didn't think you needed a fuel pump until a turbo upgrade(stage 3)....
As far as I knew, "stage 2" is just a downpipe, full exhaust and a tune. I ran my stock turbo with the boost up to 17psi over the stock 13.5 psi without a fuel pump and it ran great all the way to redline.
Rymaster is offline   Reply With Quote
Old 07-29-2014, 12:18 PM   #17
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
I have a stg 2 05 Wrx with 132k.
I dont think you "need" the fuel pump untill going with larger turbo. I would highly recommend a catless uppipe along with the catted downpipe.
Cobb now offers stage 2+ebcs maps so you can use the Ebcs without a custom tune, or use it for a while until you get a custom tune. Supposedly only the Cobb ebcs works with their maps.
My 05 has Cobb sf intake/box/post maf hose, Perrin turbo inlet, Samco tmic hoses, Cobb catless uppipe, Cobb catted downpipe and Cobb Ap 93 oct stage 2 ots map. I too plan on adding their 3 port ebcs and trying the stage 2+ebcs ots map.
4eat05 is offline   Reply With Quote
Old 07-29-2014, 01:34 PM   #18
thekamkikaze kid
Member#: 375498
why the catless up pipe? i heard that the cat breaks down when airflow is increased and gets into the turbo. is this the reason? or is there another reason?
Old 07-29-2014, 01:47 PM   #19
Brother EddieJ.
Member#: 181617
2004 wrx
What you heard it true and this is the reason. But more specifically it doesn't break down with increased airflow, it breaks down from time and heat.
Old 07-29-2014, 01:52 PM   #20
winston856
Member#: 170133
That's the primary reason yes, to get rid of the pre-turbo cat and the EGT sensor which I've heard can also break off eventually.
Secondary reason would be a spool decrease with power increase, especially with an aftermarket up pipe.
winston856 is offline   Reply With Quote
