Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 12-30-2008, 02:28 PM   #51
Cyclops
Member#: 95017
2000 2.2RSTI stroker
2010 SWP STI
Some 20gs are even as much as 100cfm more than 18gs. The Deadbolt 20g, however, is only about 30cfm more than my 18g. I agree, though, that this should be big setups. I was just trying to add my experience with a 600+cfm turbo . I'll get a bigger one soon, I promise!
Cyclops is offline   Reply With Quote
Old 12-30-2008, 03:10 PM   #52
zachary.berrier
Member#: 82476
GOD CREATED TURBO
LAG TO GIVE V8'S A CHANCE
very true, i didnt post numbers cause chassis dynamometer dont really count, i drive around mostly low boost like 16lbs. now cause of conditions and stay out of spool. I had it tuned at 23-25 lbs. of boost and then tweaked the maps myself. I didnt get a chance to get it to the track before the season ended to do trap speeds, but ive ran with 11 second cars on the highway and the turbo pushes 950+ cfm, the sbr 35r is ported and polished.
I run alcohol if i want, i tuned it in but i use a drag setup, not a progressive controller.
zachary.berrier is offline   Reply With Quote
Old 12-30-2008, 03:22 PM   #53
zachary.berrier
Member#: 82476
GOD CREATED TURBO
Originally Posted by Cyclops View Post
That's fine. I was just saying that a 20g isn't a whole lot bigger than an 18g and I was just trying to post per the OPs request. I'll have a nice shiny 850 cfm turbo for you guys to see soon.
so your 18g with an 8cm housing is 5 cfm over the 7cm. Just to let you know 5 cfm is like a 3whp gain off a mod, you wont feel it. It may be psychological though. Thats why up until subarus became popular the 18g was only used in honda turbo kits. I was a dsm guy through the 90's, the evo3 ported polished and clipped will spool faster and flow the same. Thats essentially what the momentum ej5-40t was. I had one of those too. There is no reason to even buy the 18g the gain is so minimal over the evo3 16g. The td06 20g i speak of thats been around for almost 20 yrs now is worlds apart power wise from an 18g.
its like td04 to vf34 difference with with alot more top end.
Old 12-30-2008, 03:24 PM   #54
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
There's more to power than just peak numbers. Please, quit cluttering this up with off-topic crap. Any more such posts will be deleted, because they are not on-topic.
Audiosavvy is offline   Reply With Quote
Old 12-30-2008, 04:25 PM   #55
AwdBoostCreep
Member#: 182804
2006 Gsxr 1000
Turbo
Mmmm. Guess i'll jump in the loop.
Stock EJ20 with drop in Wiseco pistons, ARP headstuds, BC valve springs & Ratainer's, and BC 280's.
Stock transmission
6-Puck sprung clutch kit
PT67 (Gt37R)
No times or number's yet, but it feels really nice.
AwdBoostCreep is offline   Reply With Quote
Old 12-30-2008, 04:47 PM   #56
conrad87
Member#: 163884
2008 G37S
^^now thats what i like to see! where abouts are you seeing full boost on that?
conrad87 is offline   Reply With Quote
Old 12-30-2008, 04:49 PM   #57
AwdBoostCreep
Member#: 182804
2006 Gsxr 1000
Turbo
From the reading on my AEM EMS I see 10 PSi around 4,000 then after it hits 10 PSI it just shoots up to the desired boost level like a rocket.
Old 12-30-2008, 05:20 PM   #58
conrad87
Member#: 163884
2008 G37S
I bet that feels amazing. lag may not be the best thing but it certainly does feel the best when everything pretty much hits at once. Suprisingly thats not as laggy as i though it would be.
Old 12-30-2008, 06:09 PM   #59
AwdBoostCreep
Member#: 182804
2006 Gsxr 1000
Turbo
Honestly lag is overated IMO. When racing on the streets I brake boost and have no lag. When at the track I have Launch control/Anti-lag and No-lift-to-shift.
Unless you autocross ofcoarse.
Old 12-30-2008, 06:43 PM   #60
conrad87
Member#: 163884
2008 G37S
how is your gas mileage out of boost when just cruising around? this really is close to a setup i would eventually like to have.
Old 12-31-2008, 12:47 AM   #61
AwdBoostCreep
Member#: 182804
2006 Gsxr 1000
Turbo
Very good gas mileage surprisingly. I guess it is because I don't get into boost as much. due to the lag.
Hard to actually give a good comparison though since I did put in a BC280's.
Old 12-31-2008, 07:14 AM   #62
zachary.berrier
Member#: 82476
GOD CREATED TURBO
OMGHi2U
if you clarified your threads and quit acting like a noob. then i wouldnt even respond to the nonsense, go back to the audio forum and whine.
Old 12-31-2008, 07:17 AM   #63
zachary.berrier
Member#: 82476
GOD CREATED TURBO
Stock transmission
PT67 (Gt37R)
nice setup, very nice
Old 12-31-2008, 08:58 AM   #64
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
^^ hell yea, 37r on a 2.0!!!
i want to see 1/4 mi times
mxpunk is offline   Reply With Quote
Old 12-31-2008, 12:41 PM   #65
AwdBoostCreep
Member#: 182804
2006 Gsxr 1000
Turbo
Here shortly. Hopefully within the next two weeks I will have some base times to start with.
Old 12-31-2008, 12:57 PM   #66
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG,FMIC, Big turbo
defiantly susbscribed!!! I have all the supporting mods I need for my turbo right now. I really want to go with a 18G but will prolly only throw a vf39 on for now. This thread is going to be very interesting
emsmap is offline   Reply With Quote
Old 12-31-2008, 01:21 PM   #67
Krang
Member#: 134272
Chapter/Region: HIIC
2002 WRX Wagon - WRB
ej207 v8 vf37
Save up the extra money and go with a big16g, the vf39 is great for a couple months but it will disapoint due to lack of flow in the high rpm
Krang is offline   Reply With Quote
Old 12-31-2008, 01:38 PM   #68
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
i dont know if he still gets on but i'll go ahead and post his setup since it's the main reason why i got a gt3076R
Originally Posted by fantabulous View Post
TURBOXS kit(gt3076r .63)
dyno graph w/stock ej205, and racegas (vp import)
ownnij is offline   Reply With Quote
Old 12-31-2008, 01:47 PM   #69
AwdBoostCreep
Member#: 182804
2006 Gsxr 1000
Turbo
Wonder how long it lasted.
Old 12-31-2008, 01:47 PM   #70
emsmap
Member#: 159334
02 WRX, 99RS, 96L
I have PPGs so I really dont need to worry about my tranny. a local friend will sell his vf39 to me for 300.00, I just am stumped on either a big16g, 18G or 20G. I have never drove any of them lol
Old 12-31-2008, 01:54 PM   #71
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Anyone have an idea what the evoIII big16g flows @ 27-30 psi or so?
Would that count as 600+ cfm if it does indeed flow more then that??
I plan on building a 2.2L block and potentially running big boost out of a 16g.
Would anyone object to a 2.2L motor being placed in here?
Old 12-31-2008, 02:50 PM   #72
zachary.berrier
Member#: 82476
GOD CREATED TURBO
you will over spin it, max is like 25psi with an evo3. buy a bigger turbo with a bigger exhaust housing and will allow you more top end.
Old 12-31-2008, 03:10 PM   #73
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
a local here ran a mid 11? i think with a vf34 running 28 psi or so..then ran a high 10 with an 18g @ high boost.
im sure a 16g could do this too..with meth/alc of course
Old 12-31-2008, 03:33 PM   #74
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
Wondering when you were going to post in here. I was going to drop you a link.
So i decided on going bigger before we retune. I'm getting to ATP 30-76 or the HTA Green. Then your tuning it.
So i may be posting in this thread again with a new turbo.
Wrx_Fan_0717 is offline   Reply With Quote
Old 12-31-2008, 03:37 PM   #75
AwdBoostCreep
Member#: 182804
2006 Gsxr 1000
Turbo
Ohh boi. We sha'll see how long the engine will last. Are you keeping meth or just running pump?
got a date you think you may be ready ?
subaru 2.0 GX AWD - NOW 2.0 L TURBO jay_parot Normally Aspirated with bolt-on Forced Induction Powertrain 0 07-24-2009 11:48 PM
subaru 2.0 GX AWD - NOW 2.0 L TURBO jay_parot Normally Aspirated with bolt-on Forced Induction Powertrain 0 07-24-2009 11:46 PM
Cobb Stage 2 0-90 MPH log - how's it look? Drivinwest AccessPort 3 06-18-2009 05:09 PM
New Hyundai 2.0 and 2.0-Liter Turbo Diesels with up to 200HP AVANTI R5 Non-Subaru News & Rumors 10 11-06-2008 02:50 AM
apv2 2.0 wrx 2002-2005 600 shipped paypal nuffy Engine/Power/Exhaust 0 07-24-2007 11:48 AM
