Old 12-31-2008, 02:41 PM   #76
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Originally Posted by zachary.berrier View Post
you will over spin it, max is like 25psi with an evo3. buy a bigger turbo with a bigger exhaust housing and will allow you more top end.
A lot more top end? Sure. The same fat powerband? NO.
And 25 PSI is NOT the max for that turbo. It's efficiency range is in the mid 20s, so high 20s isn't over-doing it and will leave you a BEAUTIFUL powerband on a 2.0 running 11s.
Audiosavvy is offline   Reply With Quote
Old 12-31-2008, 02:50 PM   #77
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
Originally Posted by AwdBoostCreep View Post
Ohh boi. We sha'll see how long the engine will last. Are you keeping meth or just running pump?
got a date you think you may be ready ?
No way staying meth screw pump gas.
I still have to get fighters to fix the cutout issue (stupid holidays). I think i found a HTA Green with 3" inlet i am going to get. The HTA is suppose to be a 56lb/min compressor!!! The 30r is what a 52lb or so?
Yea probably another week or so. Less than a week if i decide to keep the 20g. I guess i could just stretch the lungs of the 20g some more and go more meth instead.
Wrx_Fan_0717 is offline   Reply With Quote
Old 12-31-2008, 03:21 PM   #78
AwdBoostCreep
Member#: 182804
2006 Gsxr 1000
Turbo
Yeah that would be the cheaper route. Let me know!
AwdBoostCreep is offline   Reply With Quote
Old 12-31-2008, 04:38 PM   #79
testes1010
Member#: 47145
2012 Gas Saver
my old 2003 WRX EJ205
Mods that matter:
- ROMRaider/OpenECU reflash tuned by me
- TurboXS Hyperflow Top Mount Intercooler w/ custom made splitter
- Ultimate Racing EWG Uppipe ceramic coated w/ Tial 38mm EWG
- HKS Downpipe ceramic coated w/ 3" Magnaflow race muffler & custom 3" SS piping
- Crucial P&P&C manifolds w/ BPM XVR crossover pipe ceramic coated
- Ultimate Racing 785cc/min Cylinder Flow Matched Injectors
- Deadbolt Zilla TD05H-20G-7cm^2 turbo
- CoolingMist 150PSI Alky Injection (7gph nozzle @ the TB, 1.3gph pre-turbo, boost pressure switch activated.)
- Hallman PRO MBC
- Walbro Fuel Pump 255lph
- XS Engineering CAI w/ GREEN™ filter
- Mr. Josh's Lightened Crank Pulley
- APS DualVent BPV
DatalogLab roaddyno software, stock EJ205 WRX reads somewhere around 190whp/200wtq.
50/50 Meth/Water + 93 pump(MAFv 4.80v) vs. 93 pump only(MAFv 4.90v), 24psig on both maps all the way to redline:
testes1010 is offline   Reply With Quote
Old 12-31-2008, 04:47 PM   #80
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
^^ i want to keep it stock location turbo and tmic..its a daily driver. i have other hobbies that cost me alot of $$ and i dont want to give them up so i can buy a seperate bumper/bumper beam so i can hack it up for a fmic.
i dont want a front mount and i dont really care if it blows up (ok i do but..)and if i do..ill be kinda depressed/pissed for alittle bit, then ill just smoke alot of weed and put my old engine back in. hence the reason im building a spare block so i can learn to tune with it/pumble it with boost/etc
mxpunk is offline   Reply With Quote
Old 12-31-2008, 06:02 PM   #81
zachary.berrier
Member#: 82476
GOD CREATED TURBO
LAG TO GIVE V8'S A CHANCE
then 20g or a hybrid, the intercooler is gonna kill it . your gonna have to run meth with a sizeable top mount, to get really good numbers.
zachary.berrier is offline   Reply With Quote
Old 12-31-2008, 06:57 PM   #82
PolarisSnT
Member#: 85905
2004 WRX
Sigh...have you not seen testes 20g on a TMIC, its only a few posts up
PolarisSnT is offline   Reply With Quote
Old 12-31-2008, 07:18 PM   #83
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Originally Posted by Audiosavvy View Post
1. The RPM has ZERO to do with it. You can run to 7200 and never hit more than -5 PSI.
2. I'm talking about a 2.0, SINCE THIS THREAD WAS SPECIFICALLY DESIGNED FOR 2.0S. 2.2s are not welcome here, and this is not the place to discuss them.
3. The 16Gs are not all created equally. Your average FP Small16 is quite a bit different from the Deadbolt Super16
can you make an exception?? theres like 3 people in the universe with ej205/22e/t hybrids.
Old 12-31-2008, 10:08 PM   #84
zachary.berrier
Member#: 82476
GOD CREATED TURBO
no kidding, im from the east coast and hes from jersey and thats whats gonna kill it when the heat comes. thats why people in the south all around will run a front mount. I have seen and if he had a fmic, he could run more boost efficiently. now go sigh..... not my first forced induction car.
Old 12-31-2008, 10:16 PM   #85
testes1010
Member#: 47145
2012 Gas Saver
I ran 24psig all the way to redline on a stock EJ205, is that not enough boost? There was no hint of heatsoak(w/ all the heatshielding I had on the car) and no flow issues with the Hyperflow TMIC I was using. I can't imagine seeing much if any benefit w/ a FMIC with the setup I had.
Old 01-01-2009, 01:55 AM   #86
PolarisSnT
Member#: 85905
2004 WRX
I used to feel like Zach and went to a front mount. Switched back to a top mount and have no regrets, except that I wasted all that time/money/energy on the front mount.
Old 01-01-2009, 11:38 AM   #87
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
2005 WRX Wagon Helix RR500 (TD06 8cm 20g)
93 OCT 19 PSI (boost on chart is off)
50.88ft above sea level
1) Original EJ205 (101k atm)
2) No internal work
3) 325whp 296wtq
4) Stock trans - no drag strip for me
5) Compared to my stage 2 setup.. 5..4..3..2..1 blast off. Passing someone in a spirited manner on the highway requires 4th gear. Fully spools at 4.5k rpm.
She is only tuned to 19psi due to me forgetting the high boost spring for my mbc. Didnt matter to much because I was still on the stock clutch at the time.
Engine Specifications:
Stock EJ205
Engine Misc.:
Perrin Radiator Shroud - Camo’d
Gimmick Light Weight Crank Pulley
Camo’d Coolant Tank
Camo’d Alternator Cover
(Thanks Ryan…)
Turbocharger & Induction:
Helix RR500 20G TD06 8CM
CSS Performance FMIC
Tial 50mm BOV
Hallman RX Pro MBC
Fuel & Tuning
Open ECU Tune by Cleo @ Precision Tuning
Stock modded Injectors (825cc)
Walbro 255 Fuel Pump
Intake & Exhaust:
TXS Big Maf Intake
Gimmick Motorsports Turbo Inlet
Grimmspeed EWG Up-Pipe
Tial 38MM External Waste Gate
P&P Stock Manifolds
Ebay HKS Knock off Catless Downpipe
Greddy SP2 Catback Exhaust
Kartboy Exhaust Hangers
Drivetrain:
ACT Streetlight Clutch
ACT Streetlight Flywheel
Honest Bob is offline   Reply With Quote
Old 01-01-2009, 02:42 PM   #88
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
Originally Posted by mxpunk View Post
a local here ran a mid 11? i think with a vf34 running 28 psi or so..then ran a high 10 with an 18g @ high boost.
im sure a 16g could do this too..with meth/alc of course
Did no one else read this? Unless this was an EJ207 or an EJ257 I am gonna halve to call shenanigans
Show me the time slips and videos.
jmlaser is offline   Reply With Quote
Old 01-01-2009, 02:50 PM   #89
Wrx_Fan_0717
Member#: 152080
I think the record is 11.5 or 11.6 from CoolRex any other without proof is shenanigans to me.
Old 01-01-2009, 03:32 PM   #90
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Not an off the shelf typical Suby 16g.
Its a full 257 swap. He's talking about xdrian's car.
OppositeLock is offline   Reply With Quote
Old 01-01-2009, 03:57 PM   #91
smileyou
Member#: 152045
2003 PIA wrx
wrb..future ppg/fggreen
remember though, his car has a fair amount of weight reduction and straight cut ppgs
smileyou is offline   Reply With Quote
Old 01-01-2009, 03:59 PM   #92
Wrx_Fan_0717
Member#: 152080
PPGs FTL......
Old 01-01-2009, 05:29 PM   #93
jmlaser
Member#: 125529
02 WRX 18G EJ205
why where we even talking about this then,.. this thread is for the 2.0's! No offense I am sure its a nice setup
And yes Coolrex is the fastest USDM stock block stock internals 2.0 I have seen on here confirmed. And it is an 18G (7cm). Which is proof that all of you big turbo guys are missing the point of useable powerband. Other than that you made a nice number good for you, too bad it didnt help you get to the other end of the track any faster. Bigger is not always better. Turbo wise anyway
Now if you want to talk about the EJ207 we all know thats a different ballgame entirely.
Old 01-01-2009, 06:07 PM   #94
smileyou
Member#: 152045
2003 PIA wrx
not really.
Old 01-01-2009, 06:16 PM   #95
Wrx_Fan_0717
Member#: 152080
Yea he has a factory freak, period.
I dunno, the last i saw, he is putting out quite a "pretty" dyno sheet. Plus, as he told me it comes down to the driver.
<---------Decent, but not a great one.
Old 01-01-2009, 06:33 PM   #96
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
What? The evoIII big16 flows alittle less then the 18g, im sure if you leaned on it like he did on his it'd be pretty close..
and it's not a full ej257 swap, its an ej257 longblock running off the ej205 ecu w/ a open source/utec tune IIRC
Old 01-01-2009, 07:28 PM   #97
smileyou
Member#: 152045
2003 PIA wrx
with junior tuning it.....its a longblock lol
Old 01-01-2009, 09:53 PM   #98
zachary.berrier
Member#: 82476
GOD CREATED TURBO
i spent 4 yrs in georgia, ive seen effects first hand.
Old 01-01-2009, 09:54 PM   #99
zachary.berrier
Member#: 82476
GOD CREATED TURBO
junior's a good guy , he gave me tips on tuning an ej5-40t a few years ago. great tuner you will be very happy.
Old 01-01-2009, 09:59 PM   #100
OppositeLock
Member#: 54060
That's why I pointed it out, I know its not relevant here. In fact his and Coolrex's car's times hold very little comparative significance unless people become more willing to go to similar depths of weight reduction.
IIRC, he's got a TD06SL2-18g-8cm2. That flows quite a bit more then any off the shelf Suby 16g, E3 included.
What would you consider a full 257 then?
subaru 2.0 GX AWD - NOW 2.0 L TURBO jay_parot Normally Aspirated with bolt-on Forced Induction Powertrain 0 07-24-2009 10:48 PM
subaru 2.0 GX AWD - NOW 2.0 L TURBO jay_parot Normally Aspirated with bolt-on Forced Induction Powertrain 0 07-24-2009 10:46 PM
Cobb Stage 2 0-90 MPH log - how's it look? Drivinwest AccessPort 3 06-18-2009 04:09 PM
New Hyundai 2.0 and 2.0-Liter Turbo Diesels with up to 200HP AVANTI R5 Non-Subaru News & Rumors 10 11-06-2008 01:50 AM
apv2 2.0 wrx 2002-2005 600 shipped paypal nuffy Engine/Power/Exhaust 0 07-24-2007 10:48 AM
