Old 12-25-2008, 07:19 PM   #1
VAUGHNB19
Member#: 112422
Default hks bov leak?
i just noticed that my hks bov have air coming out of it...is this normal or is it a leak from the bov...this probably a dum quiestion too..which can explain why my car running rich most of the time in my 2004 rsti?
VAUGHNB19 is offline   Reply With Quote
Old 12-25-2008, 07:54 PM   #2
Retiarius
Member#: 198130
Ssqv?
Retiarius is offline   Reply With Quote
Old 12-25-2008, 08:16 PM   #3
fastlanerex
Member#: 133391
2004 boosted saleen
white
yes you have a leak in it mine doesnt do that and it shouldnt.
fastlanerex is offline   Reply With Quote
Old 12-26-2008, 01:17 AM   #4
VAUGHNB19
Member#: 112422
yes ssqv...and i think then i found my intake or leak...thanx..will check it out or get another one..
Old 12-26-2008, 03:53 AM   #5
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
Is it leaking at idle? If it is leaking at idle it needs adjusted. There is a screw and a lock nut on the end of it. It is used to adjust the preload on the spring inside the valve. All aftermarket valves need to be adjusted to the proper vacuum of the motor they are used on. Click on this link, scroll down about half way to where it says "Adjusting the spring preload"
http://www.gofastbits.com/index.php?...ub_option=1008
They give a decent description on how to adjust BOVs.
That being said. HKS SSQV BOVs use a very strange design. They are not like most of the other BOVs on the market. They tend to be hard to adjust properly. Even if you get them closed at idle they tend to flutter and surge. They do not have a good design in my opinion.
If you have one, I would just put the stock one back on. Unless you are running enough boost to make the stock one leak, there is no real reason to have an aftermarket valve. Aftermarket bovs especially atmospheric ones are nothing but trouble on Subarus.
FourOnTheFloor65 is offline   Reply With Quote
Hks Ssqv Bov Leaking pollawrx06 Engine Management & Tuning 0 02-20-2010 01:49 AM
F/S HKS BOV, HKS turbo timer, replica turboxs rfl bov jm0327 MWSOC Private Classifieds 2 07-04-2009 11:08 AM
HKS BOV Leak dunk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-27-2008 02:11 PM
HKS bov leaking, can this cause serious damage? Jus Blaze Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-04-2006 02:44 PM
F/S: HKS Bov kit, HKS Type-1 Turbo Timer + Harness, Blitz SS style Bov kit JunGdb Private 'For Sale' Classifieds 11 07-26-2005 07:04 AM
