Old 12-25-2008, 10:44 PM   #1
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
don't-pull-me-over Silver
Default P0341 - camshaft position sensor trouble HELP!
Some background first:
I recently (3 months ago I think) put in Delta 2000 cams along with some other mild N/A mods into my '99 RS (EJ25 SOHC).
I got the P0341 CEL today and the car runs and idles, but does so a little choppy. I pulled the camshaft position sensor and it had some crap on it, so I cleaned it real good with some nail polish remover. After resetting the ECU and reinstalling the cleaned sensor, the RS ran very smoothly for about 3 minutes and then reverted to running choppy and the P0341 came right back on.
I'm going to replace the sensor tomorrow and see if that helps. My only concern is that maybe I jumped a tooth on the timing belt.
Does anyone have any ideas or experience with this CEL?
Danny Boy is offline   Reply With Quote
Old 12-26-2008, 08:53 AM   #2
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
i just replaced the cam sensor with a duralast OEM equivalant from autozone and the car ran good for like 5 minutes then started running choppy. After shutting the motor off and restarting, the CEL P0341 came back on. WTF.
Anyone have any ideas??
Old 12-26-2008, 07:04 PM   #3
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
bumps
Old 12-28-2008, 08:28 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
ask in the na forum and/or the built motor forum
Old 12-29-2008, 01:53 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
check the wiring.
Old 12-29-2008, 02:11 PM   #6
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
I just finished another project opening up the garage, so I'm pulling the RS in and checking it out this week.
Things to check:
1. All wiring to sensor
2. timing to make sure I didn't jump a tooth
3. wires, spark plugs, and coil pack
4. Anything else??
Old 12-30-2008, 07:15 PM   #7
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
I pulled the timing cover and I think it did skip a tooth or two. I took some pictures and thought I'd throw them up here while I warm up and look for my timing belt tensioner pin (to lock the tensioner out of the way).
Any comments or suggestions?
timing belt:
Driver's side cam:
Passenger side cam:
Crank:
Old 12-30-2008, 08:14 PM   #8
96GreenLX
Member#: 60073
1996 Impreza LX
Green
Are you thinking the crankshaft sprocket isn't at TDC? Mine looks the same right now as I'm trying to get that sprocket off but mine appears to be at the same position doesn't quite look like it's pointing directly to the top. One question I have is, is the crankshaft position sensor that sensor directly above the crankshaft sprocket? If so does it read each of those knobs on the backside of the sprocket for timing readings? I ask because I broke one off the sprocket and don't know if I will need to replace the sprocket. Hopefully I didn't break your thread but I can take a picture of my sprocket to show you where it is lined up for TDC it's the 2.2 but I'm sure it's the same.
96GreenLX is offline   Reply With Quote
Old 12-30-2008, 09:47 PM   #9
weston666
Member#: 198759
Default hmmmmm
hmmmmm
weston666 is offline   Reply With Quote
Old 01-04-2009, 10:14 PM   #10
jwhisl
Member#: 199199
1998 Legacy GT Limit
Looks like your crank pulley could be 1 tooth off. You might try lining the markings up on the crank pulley by turning the engine and see where the cam gears are setting
jwhisl is offline   Reply With Quote
Old 01-04-2009, 10:48 PM   #11
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
I'm realigning the timing belt and putting it back together hopefully tomorrow.
Old 12-02-2009, 08:02 AM   #12
SilverDropTopGT
Member#: 147096
Bump...Hey Dannyboy did you ever get this resolve? was the timing indeed off?
Im getting the same symptom as you are discribing.
i put in a new battery [as mine was toasted], installed a new cam sensor from subaru dealership and the car started up and ran fine for abour 5 min or until it was warm, then it would throw the p0341 code and it would idle really low stumbling and when you give it gas it hesitated.
I pulled the code p0341 code again
I reset the ecu [ disconnecting the battery]
Car ran great for a couple min then problem still existed with the stumbling/vibrating motor idle and the hesistation within all the rpm of giving it gas.
SilverDropTopGT is offline   Reply With Quote
Old 12-02-2009, 08:18 AM   #13
SilverDropTopGT
Member#: 147096
Update from Dannyboy via PM
He advise it that the timing was off by 1 tooth.
So for future reference if you have a problem like this and you did replace the cam sensor and it still didnt work. then check your timing its probably a good chance you skipped timing
i had a 2002 Subaru Impreza Wagon 2.5TS 2.5L EJ251 SOHC P0341 [ this is for help with people searching the same problem ]
I hate to read a thread and not find the resolution to the problem
Old 07-21-2013, 06:38 PM   #14
chadness
Member#: 356344
Thanks for filling us in. Glad to know what solved the problem
chadness is offline   Reply With Quote
Camshaft position sensor shaneswrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-14-2004 04:39 AM
Camshaft position sensor dead AntonioS Normally Aspirated with bolt-on Forced Induction Powertrain 3 01-16-2004 05:30 AM
Camshaft Position Sensor ehabs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-31-2003 03:06 PM
Camshaft Position Sensor zsurfrin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-16-2002 10:00 PM
CEL code: 0340 / Camshaft position sensor BluJay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-06-2001 05:07 PM
