Old 12-26-2008, 12:10 AM   #1
Robot Hands
Member#: 142099
1993 1.8 AWD Wagon
Default 93 impreza starting problems
For a few weeks now i have been having trouble starting my 93 impreza. i turn the key and its cranking and trying to turn over but has lots of difficulty. If i crank it and have the gas down it takes about a minute to get it started. Once it it started it drives normal and will start up easier after its been driven, unless it sits for a while. Once i get it started i have to let it idle for a little or it will start choking if i hit the gas. I have been using ether to get it started which helps some. I had a mechanic hook it up to some computers and he cant get any readings. Any ideas?
thanks
Robot Hands is offline   Reply With Quote
Old 12-26-2008, 12:13 AM   #2
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
if its turning over strong enough to turn over for about a minute its probably not a starter problem, if it runs fine once started it might not be an ignition problem, unless you replaced your air filter with 'great stuff' your engine is getting enough air. I'm guessing something is wrong with the fuel delivery system.
Dirty25RS is offline   Reply With Quote
Old 12-27-2008, 11:34 AM   #3
Robot Hands
Member#: 142099
1993 1.8 AWD Wagon
any other ideas?
Old 12-27-2008, 05:06 PM   #4
Sudafed
Member#: 70090
2002 2.5 RS
could be cam/crank sensor issues. how up to date are you with wire/plug/air filter/fuel filter services?
Sudafed is offline   Reply With Quote
Old 12-27-2008, 06:03 PM   #5
Robot Hands
Member#: 142099
1993 1.8 AWD Wagon
air filter is good, im pretty sure the plugs and wires are ok, could be a bad fuel filter... im just not wanting to guess and throw money into it if im not sure. but i will prob give the fuel filter a try unless some other ideas are out there
Old 12-27-2008, 06:04 PM   #6
John*G
Member#: 19562
95 coupe
red
Well it is a 93 and OBD I, you cannot hook it to a computer so I am sure he could not get any readings. He probably does not know how to pull the codes unless he is a Subaru mechanic.
Buy yourself a Haynes manual for a early Legacy, they don't have one for a Impreza but they are exactly the same. It will tell you how to pull the codes and interpret them. You could also search here it is around on several threads.
John
John*G is offline   Reply With Quote
Old 12-27-2008, 10:21 PM   #7
Sudafed
Member#: 70090
2002 2.5 RS
usually you make sure your car is up to date with all maintenance items before you start chasing runability problems around. change the fuel filter, you need it anyway.
Old 12-28-2008, 11:40 PM   #8
Robot Hands
Member#: 142099
1993 1.8 AWD Wagon
so i pulled some codes and i got 21 and 12... is that water temp sensor and starter switch?
93 Impreza transmission problem?? splash_emt Newbies & FAQs 1 10-06-2009 07:16 PM
Advise appreciated - 93 Impreza not starting/turning... SubyZ Normally Aspirated Powertrain 2 06-08-2007 03:50 PM
need help, car not starting. 93 impreza L fyr3 Service & Maintenance 13 09-04-2006 10:55 PM
('93-'01) 93 impreza electrical problem, ej22 swap, fwd 5spd MilesFox Impreza Forum 0 06-28-2005 12:56 AM
93 Impreza L AWD Turbo WONT START! animestore Subaru Conversions 14 09-21-2004 04:55 PM
