Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 12-27-2008, 02:03 PM   #1
autocannon05
Member#: 136232
14 WRX Hatch
turtles
Default Need Feedback
I am planning once I get my car back to begin running autox on a regular basis and some track events. I would like to know what class I would fall under and besides a lot of seat time what else would I need or need to change on my setup and be competitive. Any feedback will be appreciated.
Also what class will I fall under?
Here are my mods:
Engine
Built ej257 with 100mm CP pistons and Manley Rods
SZ49 turbo
38mm ewg open dump
gt spec headers uel (wrapped)
uppipe with ewg adaptor
3in Invidia dp (catless)
3in Bosal exhaust (catless)
perrin boost control solenoid
perrin big maf
perrin inlet 2.4in
crawford air/oil separator
Power enterprise 850cc inj
step colder plugs
fuel pump
Suspension
JDM pink springs with stock 04 sti struts
perrin sway bars with perrin endlinks (not sure of the size, installed by previous owner)
cusco H brace
front and rear ebay strut bars
steering bushings by kartboy
Tranny
spec stage 1 clutch
?? flywheel (clutch was installed by previous owner)
kartboy shifter bushings
kartboy short shifter
Wheels and Tires
stock bbs 17x7.5
Kumho ecsta asx (planning to get Kumho MX's or XS's)
These are the parts installed on my car.
I plan on getting coilovers (most likely BC), upgraded rear diff bushings, rear subframe lock bolts, alk (anti lift kit), fender brace, a helmet and maybe a harness.
Thanks for your time.
autocannon05 is offline   Reply With Quote
Old 12-27-2008, 02:10 PM   #2
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
First the engine and turbo puts you straight to Street Mod.
Better look at Coilovers and big wheels and tires to be competitive in that class.
Patrick L is offline   Reply With Quote
Old 12-27-2008, 02:21 PM   #3
autocannon05
Member#: 136232
14 WRX Hatch
turtles
damn...i was planning on just getting the feel for my car with my current setup since I am new to autox then eventually getting the coilovers and bigger wheels and tires to become competitive.
thanks for your help
Old 12-27-2008, 03:14 PM   #4
Web Foot STi
Member#: 39086
2004 STi
If you add the ALK you bump to Prepared suspension wise. Not sure what the turbo would do to your classing then. Mod?
Web Foot STi is offline   Reply With Quote
Old 12-27-2008, 04:13 PM   #5
Boxologist
Member#: 21118
XP with the turbo, internals, bracing, ALK.
Boxologist is offline   Reply With Quote
Old 12-27-2008, 04:51 PM   #6
autocannon05
Member#: 136232
14 WRX Hatch
turtles
k i c
thanks
Old 12-27-2008, 05:31 PM   #7
makofoto
Member#: 25243
2006 Legacy Outback
Hopefully your local area has a Run-What-U-Brung class. We do ... and starting this year, a separate class for the same, but with street tires ... for you average street "tuner" guy ... together with an official Newb championship ... requiring only six results.
Autocannon ... if you're just "playing" around to "test" your car, and feel the waters ... shouldn't matter what class you run in at first, ie. just run with the big boys in Prepared. You can still compare your times with whomever.
makofoto is offline   Reply With Quote
Old 12-27-2008, 07:31 PM   #8
autocannon05
Member#: 136232
14 WRX Hatch
turtles
thanks alot i am def goin to check with my local area to see what they offer. Thats pretty much what I want to do cause I eventually want to do track after much seat time.
Old 12-28-2008, 09:27 PM   #9
akuhner
Member#: 462
2000 Impreza 2.5 RS
SCCA Rally Cross Car
Stop modifying your car and put all you resources into the nut behind the wheel, your class won't matter for at least the first year because you won't be a good driver without that seat time you refer to. However, sounds like the class you'll be in will require more than seat time - find all the auto-x schools, test & tunes, etc, that you can go to. Put the word "competitive" out of your vocabulary and focus on leaving every event where your last few runs are faster than your first few.
You'd have an easier time being competitive in a stock 2.5RS than in that beast you've built!
akuhner is offline   Reply With Quote
Old 12-28-2008, 10:14 PM   #10
autocannon05
Member#: 136232
14 WRX Hatch
turtles
lol I will def look into the schools and test and tunes and leave the car as is for a lil bit. thanks for the input man.
also I see u live in brooklyn I live in the bx but go to school in florida maybe you could give me a couple pointers when im in up in nyc.
Old 12-31-2008, 09:30 PM   #11
akuhner
Member#: 462
2000 Impreza 2.5 RS
I gave up motorsport and sold the rally car 2 years ago when my daughter was born, so I'm a bit rusty. They have instructors at every auto-x event and they'll ride with you and give you guidance based on your runs, best free instruction you can get. Unfortunately most clubs don't let passengers ride at auto-x unless they are 'certified' instructors, which I'm not.
('93-'01) 2002 2.5RS Owners, Need Feedback! Dirt Man Impreza Forum 21 05-18-2001 08:42 AM
Anyone using Wolf EMS 3D, Need feedback from Owners... Aspen Normally Aspirated Powertrain 0 03-02-2001 08:10 AM
Gauge pod Temp. gauge actin' up -- Need feedback for Thursday Siper2 New England Impreza Club Forum -- NESIC 4 02-28-2001 04:54 PM
Yokohama A540s .. just got need feedback...plz DarkLite Brakes, Steering & Suspension 0 02-18-2001 04:54 PM
Help! Need feedback on warrenty issue LongIsland RS General Forum Archive 2 10-24-2000 12:11 AM
