Old 12-27-2008, 03:56 PM   #1
jagatek
Member#: 155754
2005 WRX
Default Power loss and strange chirp/cough
I have a 2005 WRX Open source stage 1 with a K&N filter and no additional modifications.
While accelerating, the car will make a noise about once every minute or so. When the noise is made, there seems to be a slight loss of power that only last a quarter of a second. It is just like a hiccup.
The noise sounds like a chirp/cough/hiccup. It sounds like it is coming from the front driver side of the car. No CELs are being thrown either.
It seems the noise has slowly begun occurring more often.
Is anyone familiar with this noise? The last maintenance issue I had to correct, was a popped power steering belt. I had to drive for about 20 miles without the belt.
Any ideas would be appreciated.
Thanks.
jagatek is offline   Reply With Quote
Old 12-27-2008, 04:16 PM   #2
Sudafed
Member#: 70090
2002 2.5 RS
a/c compressor engaging? are you driving with your a/c or defroster on? sounds exactly like that. the compressor clutch cycles, and when it engages and runs, you will feel a slight power loss.
Sudafed is offline   Reply With Quote
Old 12-27-2008, 04:19 PM   #3
jagatek
Member#: 155754
2005 WRX
That is what I thought at fist, but I do not recall it being so pronounced in the past. I am going to go drive it around the block with and without the AC and see if it changes.
Old 12-27-2008, 05:03 PM   #4
jagatek
Member#: 155754
2005 WRX
I drove around the block, and the car is only making the noise, when the A/C is turned on.
But, I still don't understand why it is making this noise now, when it had not been making that noise in the past. Also, the power loss is much more noticeable now than it had been in the past.
Any ideas why?
Old 12-27-2008, 05:04 PM   #5
Sudafed
Member#: 70090
2002 2.5 RS
as the clutch wears out they start to squeak a little more. you can spray it out with brake clean and clean the dust up, and put a tiny bit of valve lapping compound between the clutch and pulley. use a feeler gauge and put it in like 2 places. run it a few times to wear it in and then clean it out again.
Old 12-27-2008, 05:10 PM   #6
jagatek
Member#: 155754
2005 WRX
Thanks for the advice, Sudafed. I will do this. I guess I am just noticing the power loss more, since there is now a noise associated with it.
Old 12-30-2008, 08:14 PM   #7
Reinonu
Member#: 188534
2003 Impreza RS
So one thing to keep in mind is that the A/C belt is engaged when the "defrost" setting is used (front, not rear). So just because the A/C is not formally turned on you might be using that belt anyway.
Any ideas why?
Reinonu is offline   Reply With Quote
Old 12-30-2008, 08:19 PM   #8
Reinonu
Member#: 188534
2003 Impreza RS
This sounds very similar to the problem I'm having on my Impreza RS '03. However, it was diagnosed as the A/C belt needing tightening after realizing the defrost setting also uses the A/C belt. Although the hiccup and power loss are VERY subtle.
Just make sure you test the A/C compressor properly, with the defrost setting off.
Good luck!
Thanks.
Power Loss and loud knock from under the hood. STIdreamer17 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-05-2009 06:34 PM
Dysfunctional AC, massive power loss, and a phantom CEL t3hWIT Service & Maintenance 6 07-30-2008 04:11 PM
Help! Power loss and whining noise N00b xdionx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-24-2006 10:58 AM
Strange sudden power loss cordizzle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 11-29-2004 04:23 PM
Driveline power loss and dynos yamarocket630 Normally Aspirated Powertrain 4 12-01-2001 04:49 PM
