Old 12-27-2008, 06:08 PM   #1
okioki
Member#: 162906
Default temp gauge not in center with pics
while ive noticed that my temperature gauge is not center. it is below the center a bit.. not to much but enough to annoy me. car is a 07 auto 2.5i also if that helps. is something wrong ?
okioki is offline   Reply With Quote
Old 12-27-2008, 07:42 PM   #2
SLI99
Member#: 134819
2005 Ford F150 FX4
If its really cold out it wont reach the normal (spot) until you really get it warm. If you live where its cold, i cant tell cause you dont have a location in your profile, take it on the highway and drive for a few miles, it should come all the way up to normal. If not, check your thermo
SLI99 is offline   Reply With Quote
Old 12-27-2008, 07:51 PM   #3
soulhassorrow
Member#: 150732
2011 WRXXXX
LRP
my needle is always right below the center,i bought the car brand new and it's always been like that!!is it suppose to be dead center??
soulhassorrow is offline   Reply With Quote
Old 12-27-2008, 07:54 PM   #4
gunny11218
Member#: 186959
98 GT wit fo doz
Mary Jane Green
as the second BD wingless i shall add that, if you really do live in a cold climate like me. sometimes it take literally 15 minutes for my car to warm up to its original point. and also. during the winter months sometimes radiators work too effeciently. that is normal. i dont think you have anything to worry about. now if it starts getting overly hot then you might have a problem.
gunny11218 is offline   Reply With Quote
Old 12-27-2008, 09:02 PM   #5
okioki
Member#: 162906
thanks for the responses. i live in buffalo newyork, it has been cold but today it was around 53 and it still didnt go all the way to the middle. its making me mad because i dont remember it being this way last winter. maybe im just paranoid.
heres a pic... sorry its sideways ( this is a pic of me driving for about 30 minutes with a temp around 53.. wasnt cold out)
Old 12-27-2008, 10:43 PM   #6
cmiovino
Member#: 134005
2004 WRX Premium
It's probably normal. my '95 ran right in the middle. My dad's Buick runs nearly 1/4 towards the cold side. It depends on the car ('95 and '07 aren't really the same car much anymore, heh).
Old 12-27-2008, 11:07 PM   #7
Kountersteer
Member#: 198529
'07 2.5i
Garnet Red Pearl
I have an '07 2.5i and I can tell u that ur gauge is fine, well that's to say that mine runs @ the same temp. So either it's normal or we both have a problem!!
Kountersteer is offline   Reply With Quote
Old 12-27-2008, 11:33 PM   #8
okioki
Member#: 162906
ok thanks its just been anoying since ive been looking at it more and more
Old 12-28-2008, 03:16 AM   #9
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
my 07 is also like that. never seen it actually get to the center. the gauge is not a calibrated indicator, it's just a way to tell you when its cold, normal operating temp and too hot. the specific location of the needle means nothing in itself.
RaceFaceXC is offline   Reply With Quote
Oil temp gauge not working theo79 Electrical & Lighting 1 10-03-2007 08:35 PM
Transmission Temp gauge not reading? cjx17 Transmission (AT/MT) & Driveline 3 06-12-2007 10:47 AM
oem coolant temp gauge not working... czo79 Legacy Forum 0 08-01-2003 01:11 PM
oil temp gauge not working correctly? Penguinking Factory 2.0L Turbo Powertrain 7 11-21-2002 06:22 PM
Temp Gauge Not for Real? IMPRZIV Technical Forum Archive 9 06-21-2000 06:56 PM
Message Board Statistics All times are GMT -4. The time now is 02:53 AM.
