Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 12-27-2008, 11:56 PM   #1
Kountersteer
Member#: 198529
'07 2.5i
Garnet Red Pearl
Default Subie Virgin: '07 2.5i... Where do I start?
Two weeks ago I came home with my very first subie; 2.5i, 5 speed base wagon in Sonoma Red. We've had 3 snowfalls since for a total of about 40 cm (roughly 16"-18") and I can't get over how much I love winter now! Will post pics as soon as we get some sun! ...and I can figure out how!!!
The reason for my post is to get some advice on how much power gain I can get out my engine without going "Forced Air", and without doing all the internals. And wether it's worth it or not.
My goals are to keep it a daily driver, reliable but faster and more fun would be nice! Here's what I'm thinking:
-sway bars front and rear (20's I guess)
-17"-18" mags and tires (225/45)
-Pulley kit (ecu issues if I swap all 3?)
-Exhaust (axle back for staters or more if proven power gain)
-ECU upgrade (this is my biggest concern, cost vs gain)
Any advice would be greatly apreciated!
Thanks
Kountersteer is offline   Reply With Quote
Old 12-28-2008, 12:01 AM   #2
mert34
Member#: 183598
2015 WRX
from what i have read on here, its not worth it, suspension is where it counts i guess on our cars.
mert34 is offline   Reply With Quote
Old 12-28-2008, 12:01 AM   #3
cmiovino
Member#: 134005
2004 WRX Premium
20mm rear sway. Keep the stock 19mm front.
17" wheels look good, 18" are getting too big.
Pulley kit would free up form HP.
Exhaust, axleback is good for sound (it's all I had and enjoyed it). Getting a midpipe with it to make a catback isn't going to net you any more power really. If you get headers or a high flow cat, you will make some more HP.
ECU upgrades are costly and I'd like to see you get other things to make the ECU upgrade worthwhile. If you plan on doing all this NA power work, I'd get it lowered at some point too.
Old 12-28-2008, 12:02 AM   #4
cmiovino
Member#: 134005
2004 WRX Premium
I think NA cars are fun with an exhaust (axleback only if you're going cheap) and suspension work. Maybe a hybrid intake too for cheap. Wheel and tires too.
Old 12-28-2008, 12:04 AM   #5
mert34
Member#: 183598
2015 WRX
^ i agree, working on that myself with a UEL header and exhaust in progress. well soon to be.
Old 12-28-2008, 12:36 AM   #6
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
I thought the RS/I/WRX had a 20mm front and the STI had the 19mm front, at least my 05 has a 20mm front, according to my service manual, and the 05 STI has a 19mm front, according to my service manual.
chazly413 is offline   Reply With Quote
Old 12-28-2008, 03:12 AM   #7
GrundleJuice
Member#: 165749
there is no reason to upgrade or change/add on to the factory ECU unless you get something for free. using a laptop and tactrix cable w/ RR/ECUFlash will give yo more ECU control than any aftermarket ecu/piggyback add on.
Keep in mind, bolt on mods will make very small differences without a tune, and potentially huge differences w/ a tune. So if you want to make noticeable power gains ECU tuning is a must. there really is no other way going about it.
Old 12-28-2008, 11:09 AM   #8
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
My advice, some new wheels, stromung CBE (maybe UEL and HFC setup after that), tint the windows, paint the insides of the front headlights, put 05 rear tails on or at least 06 for the gray interiors housings, hella super tones, etc. Maybe a front lip, throw some GF210 springs and enjoy the car.
Don't go nuts with the car engine wise, we'll never be wrx's so why try.
kero is offline   Reply With Quote
Old 12-28-2008, 11:20 AM   #9
BigZach88
Member#: 190548
dammit i got excited i saw virgin and Subaru in the same line i enjoy both of those things lol
BigZach88 is offline   Reply With Quote
Old 12-28-2008, 12:50 PM   #10
Kountersteer
Member#: 198529
'07 2.5i
Garnet Red Pearl
Thanks for the replies everyone! There's no doubt I'm going to doing some int. & ext. mods for visual effect. But my main curiosity is wether or not there is a semi affordable way to get 30-50 hp the N/A way! I'm not sure I understand how any of this ECU flashing works, and they seem to be focused at WRX, & WRX STi. I haven't been able to find anywhere that states how much power gain I would get out of an ECU flash for N/A engines. Are there any other methods of electronicaly boosting hp on my car??
Oh! And one more thing, can anyone tell me how to post pics!
Thks
Old 12-28-2008, 02:19 PM   #11
GrundleJuice
Member#: 165749
you cant get power from just an ecu flash. you have to have done something that will allow more timing to be added without knocking (simplified). since the stock ECU image already runs more timing than the stock engine setup can handle, more than just catback and intake need to be done to make any measurable power. EL headers and HFC seem to be the point at which some real timing advance can be added which will equal more power that you can actually feel.
There are things that can be changed in the ECU image on even a stock motor that will change driveability for the better, make your engine more reliable (no knock) and get you a little better gas mileage all while making your car feel faster but not actually gaining any HP. This is all pertaining to the N/A '05+ EJ engines.
Old 12-28-2008, 02:26 PM   #12
enjoiskater808
Member#: 153686
2006 Impreza 2.5i
1994 Miata 1.8L
If your going to do anything visual, start by lowering it on H-techs, Cobbs, or something similar because I know after a couple months of having my 2.5i sedan that wheel gap really started to bug me.
Your mod ideas look good and well thought out, one thing you might want to add is a short shifter, they give the car a nice sporty feel while driving as well as make your shifts a little quicker.
Good luck man!! cant wait to see some pics
enjoiskater808 is offline   Reply With Quote
Old 12-28-2008, 11:38 PM   #13
msingell
Member#: 153097
2012 CRZ
PWP
msingell is offline   Reply With Quote
Old 12-29-2008, 01:33 AM   #14
chazly413
Member#: 151079
2005 2.5RS RBP
Don't forget to get some struts (probably tokico d-specs) if you get some stiffer springs, it will really make a difference performance wise, and in the longevity of your struts.
Old 12-29-2008, 01:29 PM   #15
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
tires. those brigestones suck
watchunglava is offline   Reply With Quote
Old 01-01-2009, 09:50 PM   #16
SleeperWgn
Member#: 176293
2007 Impreza 2.5 Wgn
Newport Blue Pearl
Here's my setup and I love it:
WRX catback exhaust (cheap/free/ideal size FTW!)
hybrid intake
light crank pulley (agency power via www.rallitek.com)
STI springs (used = cheap/free FTW!)
KYB AGX struts
rallitek sway bars/endlinks
rims and tires! firestone winterforces on stocks for winter/rallyx, summers on Rotas.
SleeperWgn is offline   Reply With Quote
Old 01-01-2009, 10:01 PM   #17
chazly413
Member#: 151079
2005 2.5RS RBP
I just got some bridgestone potenza re960 all seasons on my rs, they're pretty nice for all seasons! Huge improvement over the RE92s.
Old 01-01-2009, 10:22 PM   #18
2.5i
Member#: 112986
N/A Cam'd & Cornfed
DOM TUNED 06 Impreza
Heres what I did and so far I am fairly happy.
F+R sways with endlinks
Catback Exhaust
Hybird intake
STi Pink springs
Had an ECU reflash until I had the engine replaced just haven't had time to get it reflashed.
2.5i is offline   Reply With Quote
Old 01-01-2009, 10:50 PM   #19
Zac86
Member#: 136919
2005 Legacy GT Wagon
ABP
If I were you I would do the hybrid intake, UEL header, HFC, catback, struts/spring combo, swaybars and endlinks and some good tires. COBB is making an Accessport for the 05+ NA engines so you'll be in luck for some good tuning
Zac86 is offline   Reply With Quote
'07 2.5i... Where do I start? Kountersteer Newbies & FAQs 5 12-28-2008 09:54 AM
Super-budget '07 2.5i brake upgrade plans Mus35th Brakes, Steering & Suspension 7 01-22-2007 02:29 PM
Differences between '07 2.5i and WRX baj General Community 10 01-07-2007 12:57 PM
In Atlanta for 2 weeks, where do the Subies hang out silver arrow South East Region Forum 2 06-03-2006 08:41 PM
