Old 12-28-2008, 01:47 AM   #1
summitwrx
Member#: 148476
2002 impreza wrx
psm
Default Timing belt change gone wrong! Help
So i was changing my timing belt, the second i got the belt off the two cam gears on the drivers side of the engine spun. I dont know if i spun them back the right way or not, do they have to be spun in only one direction?
I tried this over and over, got all the marks lined up, got the belt on, put on the new tensioner, then i forgot to pull the pin on the tensioner, and i spun it around using the crank pulley, i spun it all the way aroun and nothing lined up anymore. So i took it all apart, got everything lined up, got the belt on, put on the tensioner, then i pulled the pin. So everything looked correct, however i turned the motor over using a 22mm and the crank pulley, i spin it around as many times as possible and the lines wont line up anymore. What did i do? How can i fix this? Any help would be greatly appreciated!!
Sorry if there is bad spelling/grammar its almost midnight and im freaking out that i just screwed up my car! Help Me!
summitwrx is offline   Reply With Quote
Old 12-28-2008, 01:51 AM   #2
dunk
Member#: 15359
Once you put the belt on the car and turn it the lines aren't going to be on the marks anymore, even if you spin it back to TDC. (They would line up eventually if you kept turning the motor over but you're going to be turning for awhile). This is normal. If the marks on the belt were lined up to the marks on the pulley's and the pulley's were lined up to the marks on the timing cover then you had the belt on the right way.
-Duncan
dunk is offline   Reply With Quote
Old 12-28-2008, 02:14 AM   #3
summitwrx
Member#: 148476
2002 impreza wrx
psm
Yes i had everything lined up perfectly, then i pulled the pin on the new tension and began to spin the engine over by hand. It feels smooth, however i couldnt get it to line back up, how many times would you have to spin it over to get it to where the pulleys marks are all lined up and the belts marks are lined up with the pulleys (just when the belt is first put on)
Old 12-28-2008, 02:23 AM   #4
dunk
Member#: 15359
Don't worry about it. You can't check it like that. Line it up once, pull the pin, and you're done.
Maybe you've bitten off more than you can chew here.
Duncan
Old 12-28-2008, 02:31 AM   #5
summitwrx
Member#: 148476
2002 impreza wrx
psm
Im usually good at stuff like this, i go to school for it, however it was my first ej series timing belt change, i just want to make sure i got it right. Thanks for the help!
Old 12-28-2008, 10:28 AM   #6
Sudafed
Member#: 70090
2002 2.5 RS
it takes something rediculous like thousands of rotations for the lines on the belt to line up with the pulleys again, if that is what you are asking. but after a full rotation, the lines on the pulleys should still be in the same place.
Sudafed is offline   Reply With Quote
Old 12-28-2008, 11:09 AM   #7
avk
Member#: 17252
'06 WX8
59E
The number of turns it would take for the marks to re-align equals twice the number of teeth on the timing belt.
avk is offline   Reply With Quote
Old 12-28-2008, 12:38 PM   #8
rick-l
Member#: 33868
2003 wrx
srp
rick-l is offline   Reply With Quote
Old 12-28-2008, 03:20 PM   #9
summitwrx
Member#: 148476
2002 impreza wrx
psm
I was being stupid. Got it all figured out now, car runs great with my new timing belt in!
This thread can be deleted now, thanks for the help guys!
Old 12-28-2008, 06:28 PM   #10
rick-l
Member#: 33868
2003 wrx
srp
+1
I turned a 3 hour job into 2 days
Old 12-28-2008, 08:05 PM   #11
VuickB6
Member#: 193568
Originally Posted by rick-l View Post
+1
I did too when I changed the timing belt for the first time on my 1.8T Audi
Hopefully when I change it on the WRX it will go a lot faster...
VuickB6 is offline   Reply With Quote
Old 12-28-2008, 11:53 PM   #12
summitwrx
Member#: 148476
2002 impreza wrx
psm
Haha yea i usually add time on if its a first time job. Service manual says 2.5 hours, took me around 8 haha. I think i could do it again in 3 hours though now that i know what im doing.
changing the timing belt, change bearings or whole idler wheels/pulleys? NicEJ25 Service & Maintenance 15 12-28-2010 06:46 PM
ok time for a timing belt change. speed_ga Legacy Forum 9 09-17-2008 11:19 AM
Help in RI -- 2.2L Timing Belt Change gianspi New England Impreza Club Forum -- NESIC 20 06-06-2008 07:14 PM
Timing belt change with seal change? file_id Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-09-2007 01:59 PM
Bulb Change gone wrong AK_2002_WRX Alaskan Impreza Club Forum -- AKIC 10 09-13-2003 10:26 PM
