Old 12-28-2008, 09:32 PM   #1
EJ25I
Member#: 130500
2006 Impreza 2.5i
Regal Blue
Default 06 2.5i oil consumption
just wondering if anyone else is having this problem or do i need to go to the dealer, even though i think they voided my warranty for aftermarket parts
i use mobile 1 5-30 and use about 1.0-1.5 quarts every 3500 miles or so.
i change my oil every 3000, was told i was wasting oil and to wait till 5000 or longer,, just hit 5500 miles on mobile 1 5-30 and wasnt even on the stick about 2.5 quarts low. any help would be great.
EJ25I is offline   Reply With Quote
Old 12-28-2008, 11:46 PM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Jesus, just search. You'll find eleventy billion people bitching about oil consumption. You'll also find that a lot of them are bitching specifically about Mobil1.
Old 12-29-2008, 01:38 AM   #3
chazly413
Member#: 151079
2005 2.5RS RBP
s-techs mad tyte yo
Maybe you should top it off when it gets low?
chazly413 is offline   Reply With Quote
Old 12-29-2008, 01:42 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Lol, you know, about a month ago, there was a thread by a guy who was checking it regularly and noticed it consuming a lot of oil. Tried to figure out why. Never topped off the engine, blew it up.
Old 12-29-2008, 02:35 AM   #5
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
my EJ253 used a lot of Mobil1 5w-30. About 1.5qt per 3000-4000 miles. i have since changed to AMSOil and the consumption is significantly less. im maybe .5qt low @ 4000miles. And it's better oil, to boot.
RaceFaceXC is offline   Reply With Quote
Old 12-29-2008, 02:49 AM   #6
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Got you all beat. I'm eating a quart of Redline 5w30 every 1200mi.
Race, which Amsoil are you using?
Old 12-29-2008, 03:00 AM   #7
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
im using their 5w-30 full syn. Here it is im also using their Ea filter, which is supposed to stop 97% of particles down to 13 micron i think. I'm @ just over 4000 miles on my first amsoil change and the oil looks remarkably clean. ill be sending out a sample to blackstone after the holiday vacation to see how the oil is holding up. the AMSOil dist. said i could run it 25,000 miles/1yr between changes with that filter... which i would never do but i thought that was quite the statement when backed by their warranty.
Old 12-29-2008, 03:05 AM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
God, that's even more expensive than the Redline I'm using.
Old 12-29-2008, 03:09 AM   #9
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
yeah, its not cheap at all, but its still only $50 or so per oil change. and if it goes 8000+ miles per change, ill be very happy. I look forward to the oil analysis results.
Old 12-29-2008, 03:11 AM   #10
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yeah, but it has to actually stay in the engine that long to make it worth it
Old 12-29-2008, 09:27 AM   #11
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
touche. But it is seeming to hold onto the oil better. 1 qt/8000 miles is my guess. thats about the avg for any car, not bad for how I drive her, either.
Old 12-29-2008, 09:47 AM   #12
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
...just hit 5500 miles on mobile 1 5-30 and wasnt even on the stick about 2.5 quarts low. any help would be great.
Just so you know, your warranty isn't voided, but you may have trouble if the affected component is the result of the aft. part. What mods do you have?
And as was said earlier, check your oil level (frequently) for God's sake. I'm pretty sure you drove more than a tankful of gas to be down 2.5 qts.
surowrxa is offline   Reply With Quote
Old 12-29-2008, 10:46 AM   #13
scoby41
Member#: 134737
2000 F350 Diesel
No noticeable issues with mine, but I just have the dealership do it every 3-3500 miles. Apt living FTL
scoby41 is offline   Reply With Quote
Old 12-29-2008, 10:55 AM   #14
chazly413
Member#: 151079
2005 2.5RS RBP
s-techs mad tyte yo
I'm just using Castrol Syntec 5w-30 and a purolator filter. That one filter you posted, RaceFace, sounds amazing, wow!
Old 12-29-2008, 12:52 PM   #15
LTracer
Member#: 167703
2005 '05 2.5RS 5MT
'10 Forester X Limited
It was time for one of these again... I too drank M1, as well as royal purple. GC (0-30W) cured most of my consumption issues and isn't too thick for those cold -20F MN mornings.
Here's a question for group: What else factors into or contributes to oil consumption aside from poor/failing rings and oil viscosity? Have heard alot of high RPM driving, PCV, tuning/modifying can all drastically alter the rate at which an engine consumes oil...
LTracer is offline   Reply With Quote
Old 12-29-2008, 02:36 PM   #16
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Lateral G's and manifold vacuum are two BIG contributors. Lateral G's sling oil into the valvecovers, which then gets sucked up the breather lines. High vacuum (high revs esp. with the throttle closed) cause both the PCV and valvecover breathers to flow more.
Old 12-29-2008, 09:01 PM   #17
EJ25I
Member#: 130500
2006 Impreza 2.5i
Regal Blue
thanks again sorry for not searching always working.
06 2.5i Tranny oil change, car acting funny! Foxhound Transmission (AT/MT) & Driveline 10 12-02-2009 09:29 AM
06 WRX + excessive Oil Consumption jameseshepherd Factory 2.5L Turbo Powertrain 1 12-14-2008 04:09 PM
98 2.5RS oil consumption wiseyZ32 Normally Aspirated Powertrain 8 08-10-2008 02:27 PM
06 2.5i vs 07 2.5i boymk Newbies & FAQs 24 04-09-2008 04:07 PM
My 06 2.5i Has 2 oil leaks 240c Newbies & FAQs 6 08-18-2006 12:46 PM
Message Board Statistics All times are GMT -4. The time now is 03:46 AM.
