Old 12-29-2008, 12:22 AM   #1
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Smile Up pipe weights
How much does your aftermarket up pipe weigh (please include brand)? I know there is a master weight thread, but it didn't have the information I am looking for.
I am trying to find the lightest up pipe I can. If nothing comes up I am considering cutting the flanges off the stock UP and making my own out of some lightweight steel tubing.
Thanks.
speedyHAM is offline   Reply With Quote
Old 12-29-2008, 07:27 AM   #2
REX8
Member#: 24038
Thanks.
Just keep in mind much of your weight is coming from the thickness of the flanges. This isn't something you're going to be able to skimp on too much. The other concern is heat. Only so thin you can make it.
Old 12-29-2008, 07:52 AM   #3
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
Factory Upipe w/cat 7lbs
Factory Upipe w/o cat 5lbs
Cobb iconel (sp) Upipe w/egt bungs 4lbs
These were weighed on a batroom scale. I should really pick up a better scale.
Those are the only 3 I've ever had so it's all I got a chance to weigh.
mccanixx is offline   Reply With Quote
Old 12-29-2008, 09:34 AM   #4
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
Spoiled little brat! "oooo, look at me and my iconel.""
Rasmusson14 is offline   Reply With Quote
Old 12-29-2008, 09:51 AM   #5
Ice13
Member#: 168326
You can always remove stock heat shielding on your oem up pipe and wrap it.
Ice13 is offline   Reply With Quote
Old 12-29-2008, 10:47 AM   #6
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
How much does that inconel pipe $? I'd think for the 3lbs, it'd be cheaper to just drive on an empty stomach
A thin-walled steel pipe would be light but wouldn't retain the heat you need.
LatentWagen is offline   Reply With Quote
Old 12-29-2008, 11:01 AM   #7
Rasmusson14
Member#: 77658
I don't think Cobb makes the pipe anymore. The material got to be just too expensive. The great thing about inconel is its ability to retain heat.
Old 12-29-2008, 11:02 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
a pound of UP weight is ABSOLUTLY INCONSEQUENTIAL
put a quart less gas in the tank
Old 12-29-2008, 11:43 AM   #9
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
When you are trying to get the car under 2100 lbs with a half tank of gas in it (just enough for two drivers to run a day's worth of autox) every pound counts. I've started looking for ounces at this point.
Also- it's forward of the centerline on a front heavy car, so reducing the weight there will make the overall weight balance better.
Mccanixx- thanks for the info.
Old 12-29-2008, 12:07 PM   #10
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Sean, did you go bracket removing and hardware chopping already?
as for the uppipe...I'm going through materials in my head..thin inconel, ti of course ($$$), 2024 aluminum handles heat really well (would probably still get too soft though 6061 even works well for catbacks)...um
I'm trying to think of ways you could shorten the manifold all together...
Old 12-29-2008, 02:16 PM   #11
PKer
Member#: 27647
06 MX-5-STR 03WRX
(ret), 08 Titan-Tow
Under 2100? WOW!
How about a header instead of an uppipe?
PKer is offline   Reply With Quote
Old 12-29-2008, 04:34 PM   #12
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Impreza GC8
Originally Posted by PKer View Post
Under 2100? WOW!
I'm already going with a Perrin equal length header, since there is both weight savings and power gains to be had with that header over other headers.
Bracket removing and hardware chopping is pretty much done.
If I end up making my own up pipe I will probably use some 16 gauge steel, maybe 2-1/8" OD with a taper going towards the top to match up nicely with the inlet of the turbo. Aluminum would turn to butter at the temperatures an up pipe sees. Inconel or Ti would be best, but a little out of my welding possibilities right now and very expensive.
Shortening the manifold will come in a few years with the next stage of power from the car. I already have a plan to relocate the turbo, make a fairly short equal length manifold that terminates at a twin scroll turbo with some very short intake plumbing through a FMIC.
Old 12-29-2008, 07:41 PM   #13
makofoto
Member#: 25243
2006 Legacy Outback
The very nice APS uppipe was extra heavy ... cast iron ... because you want to retain heat (energy) when driving a Turbo.
makofoto is offline   Reply With Quote
Old 12-29-2008, 08:25 PM   #14
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Because we are pals, I got off my fat ass and took my Crucial Racing pipe upstairs to my digital bath scale that is gnat's ass accurate. Testing it twice in my hand yielded identical 3.6lb weights as it would only register with my weight not the uppipe alone. I'm pleased to admit I'm not as fat as I thought and it's lighter than the OMFG$$$$ Inconel pipe.
My pipe has two studs in it, no more. And....it's for sale. It's got 20k-ish miles and is $75 shipped to your door if'n you wants it.
Old 12-29-2008, 10:49 PM   #15
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
You get better heat retention with a ceramic coating and thermal wrap than you do with extra thick cast iron. Weighs a hell of a lot less too...
Unabomber- thanks, and you have a PM.
Old 12-29-2008, 11:34 PM   #16
makofoto
Member#: 25243
2006 Legacy Outback
Did that with my Downpipe ... JetHot coated:
Old 12-30-2008, 06:19 AM   #17
samrawet
Member#: 195088
Hi PKer
what is 2100?
samrawet is offline   Reply With Quote
Old 12-30-2008, 07:41 PM   #18
leecea
Member#: 37359
2003 WRX
...with a half tank of gas in it (just enough for two drivers to run a day's worth of autox) every pound counts. I've started looking for ounces at this point.
OT from the uppipe question, but how about getting a gas container and topping up in grid? I'd guess you could save 20lbs running less gas.
leecea is offline   Reply With Quote
Old 12-30-2008, 09:00 PM   #19
makofoto
Member#: 25243
2006 Legacy Outback
Like some of the extra serious STS drivers do at Nationals. You MUST have a fire extinguisher at your side if you're going to refuel in Grid.
Old 12-30-2008, 10:37 PM   #20
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I do this at some events, always with a fire extinguisher ready. There are a lot of events where there just isn't enough time between runs to "top off".
Old 12-31-2008, 08:24 AM   #21
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Although I think you decided, I found this as well.
http://forums.nasioc.com/forums/show...hlight=pick+up
Originally Posted by samrawet View Post
Hi PKer
what is 2100?
I think he was referring to speedy's awesome weight goal for his impreza..........and ya ah hey Seb.
Old 12-31-2008, 02:27 PM   #22
PKer
Member#: 27647
06 MX-5-STR 03WRX
(ret), 08 Titan-Tow
Hi PKer
what is 2100?
2100lbs is the target weight for the Impreza being built in this thread. I'm impressed, that will be a light Impreza.
Old 12-31-2008, 02:30 PM   #23
PKer
Member#: 27647
06 MX-5-STR 03WRX
(ret), 08 Titan-Tow
Actually it's only "recommended", but it is a good idea for sure.
What's up Greg..
Old 12-31-2008, 04:35 PM   #24
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
just weighed the gms up pipe, its 3.65 lbs
looks like-
http://forums.nasioc.com/forums/show....php?t=1639549
IMPORTIMAGE is offline   Reply With Quote
Old 12-31-2008, 05:48 PM   #25
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I had not seen that yet, thanks. Always good to have more information.
FS : STi intake manifold and throttle body jcovey2.5 Engine/Power/Exhaust 173 12-05-2011 09:38 PM
Up-pipe comparrison, ID's and weights. DuckStu Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 11-03-2008 05:03 PM
up-pipe/how much weight savings? KJR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-04-2002 08:18 PM
solid up-pipe vs. flex up-pipe r_master Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-25-2002 03:20 AM
Weight of stock up pipe vs. aftermarket Carlito2002WGN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-06-2002 01:45 PM
