Old 12-29-2008, 03:42 AM   #1
kh15
Member#: 132400
Default clutch install checklist
just wanted to make sure i get everything i need for a clutch install...
*all parts will be oem
-flywheel (i would rather just buy a new one rather than bother with re-surfacing)
-clutch disc
-pilot bearing
-pressure plate
-release bearing
how its look? is there a gasket between the tranny and the engine?
kh15 is offline   Reply With Quote
Old 12-29-2008, 10:36 AM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
No gasket, just technibond or other goo like that. Read the sticky threads in the tranny forum...install advice is in there, I'm sure.
Old 12-29-2008, 10:16 PM   #3
kh15
Member#: 132400
i know. im not doing the install just buying all the stuff for it
Old 12-30-2008, 09:24 AM   #4
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
The only kind of seal/gasket that you may want to replace when doing the clutch is the oil separator plate. Once the tranny is out, there's the plate on the right of the rear of the engine. Take the bolts out(big phillips bolts), clean the surface off really, really well(razor blade works well), and put a thin coat of fujibond(should be available at the dealer). This isn't necessary if its not leaking, but they tend to leak after 4 or 5 years. As far as parts go, that list above is all you'll need to replace.
Mika
finnRex is offline   Reply With Quote
Old 01-01-2009, 05:59 PM   #5
EJ20_lee
Member#: 106799
2004 built 257 tomei
powered ^.^
hondabond
EJ20_lee is offline   Reply With Quote
Old 01-01-2009, 08:48 PM   #6
pro934
Member#: 169234
2005 STI WRB Reffing
the Kumite from the South
Originally Posted by EJ20_lee View Post
hondabond
+1 for hondabond
pro934 is offline   Reply With Quote
Clutch change: Checklist ragejed Transmission (AT/MT) & Driveline 8 12-21-2007 09:08 AM
Turbo install checklist, bcarleton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-27-2006 08:58 AM
Installing used turboback exhaust: Pre-install checklist FleaDog Newbies & FAQs 28 03-25-2006 05:45 PM
Newbie install checklist Bomb20 Car Audio, Video & Security 8 04-25-2003 06:07 PM
clutch install checklist phast Transmission (AT/MT) & Driveline 1 10-19-2002 02:25 AM
