Old 12-29-2008, 05:13 AM   #1
H5N1
Member#: 412
DOHC 2.5RS - SOLD
SOHC 2.5RS
Question Head Gasket Leak Problem on all NA 2.5?
I have owned 2 Impreza 2.5 RS. One is a MY98 and the other one is a MY99. Both cars have head gasket leak once roll over 100k (60k mile). My friend's MY02 TS also have the same problem. Does anyone know if Subaru have the problem fixed? I am planning to buy a newer NA Subaru but would like to know if this problem still exist in the newer engine.
Thanks in advance!!
H5N1 is offline   Reply With Quote
Old 12-29-2008, 07:24 AM   #2
mdungelman
Member#: 97251
'13 Impreza 2.0i
Mine were leaking under 60k. Luckily replaced under warranty. I don't necessarily think its so common on the newer n/a's.
mdungelman is offline   Reply With Quote
Old 12-29-2008, 10:31 AM   #3
qstarin
Member#: 186129
2001 2.5RS
STM
I think they have finally started providing multi-layer HG gaskets for the NA 2.5L's to fix the common HG leaking problems. For older engines, they are the replacement part. I would guess that they come on newer engines from the factory - but I don't know what year that may have started.
qstarin is offline   Reply With Quote
Old 12-29-2008, 11:03 PM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
The dreaded HG leak on the newer motors is external, and not nearly as common as the DOHC EJ25D. So it just leaks out of the coolant passages, instead of into the combustion chamber. But the problem seems to have gone down with the newer style MLS gaskets.
~Josh~
Old 12-30-2008, 07:03 AM   #5
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Most of the SOHC's tend to have them leaking externally where the DOHC's can leak and can be blown internally. I have only seen 1 SOHC engine blow headgaskets compared to several DOHC's.
blackfang is offline   Reply With Quote
Old 12-30-2008, 01:09 PM   #6
my4isflat
Member#: 120002
2000 2.5 RS, '95
Legacy w/325k mi (RIP)
I'm half tempted to start a "Who hasn't had their HG's replaced?" thread. I still have my originals with about 182k miles on them and the engine sees a decent amount of abuse.
my4isflat is offline   Reply With Quote
Old 12-30-2008, 04:29 PM   #7
doubledribble
Member#: 42912
2003 Outback Sport
bird **** & door dings
my wife's 02 forester with 60k on it blew both headgaskets two weeks agao. my 03 OBS is currently in the shop with a blown driver side headgasket...feeling the urge to call SOA about it even though i doubt there will be any other conclusion than tough luck.
doubledribble is offline   Reply With Quote
Old 12-30-2008, 07:49 PM   #8
H5N1
Member#: 412
DOHC 2.5RS - SOLD
SOHC 2.5RS
So the newer motor doesn't have this problem anymore? Maybe Subaru has fixed it on the newer engine....
Old 12-30-2008, 07:55 PM   #9
blackfang
Member#: 131347
2007 Legacy 2.5i SE
I have seen very very few issues on the new ones.
Old 12-30-2008, 10:03 PM   #10
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Do you mean newer, like 2006+? Please elaborate. A better question is, how many 2006+ cars do you regularly see in your shop with over 60K miles?
And what is the newest year/model that you have seen with a problem?
surowrxa is offline   Reply With Quote
Old 12-31-2008, 01:46 AM   #11
H5N1
Member#: 412
DOHC 2.5RS - SOLD
SOHC 2.5RS
The 2006+ is too new for the problem to surface. I guess the only way to tell is to wait for a few more years
Old 12-31-2008, 02:08 AM   #12
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
me... 198k so far no HG problems.
moogoob is offline   Reply With Quote
Old 12-31-2008, 08:49 AM   #13
blackfang
Member#: 131347
2007 Legacy 2.5i SE
I am referring to 2005+. I would say about 25% of the 2006+ cars have 60-80k on them and roughly 40% of the 05's with that mileage.
I have seen 1 2005 Legacy wagon that had headgaskets leak coolant.
Old 12-31-2008, 03:48 PM   #14
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Tenative +1. My Forester has 125K and has never had them replaced, but I don't think we'll make it to 182K. EJ253, Phase II SOHC.
Do you use Subaru coolant conditioner?
Thanks for the answer. I was under the impression that Subaru beefed up the HG's somewhere around 2006 because of issues still surfacing up to MY2004.
Old 12-31-2008, 06:35 PM   #15
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
230K, 2000 2.5RS "knocks on wood" no HG problems. I am building a new motor thou with some slight modification allow in SCCA Solo SP class. Match weight factory .5mm OS pistons, .04 off the heads and block and balanced internals with a few other things.
Patrick L is offline   Reply With Quote
Old 12-31-2008, 07:35 PM   #16
westy4990
Member#: 158488
2007 Impreza 2.5i
Urban Grey Metallic
My '07 2.5i has had the headgaskets replaced already. I am only at 22,000 miles.
westy4990 is offline   Reply With Quote
Old 01-01-2009, 11:18 AM   #17
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
External leak I presume?
I guess that's why Subaru still wanted the newer models to use coolant conditioner even with the new style HG's.
Old 01-01-2009, 01:37 PM   #18
westy4990
Member#: 158488
2007 Impreza 2.5i
Urban Grey Metallic
Yeah, it was external
Old 01-01-2009, 03:06 PM   #19
SubieGenius
Member#: 176874
2000 Impreza 2.5 Rs
SilverThorne
Same, no replacement with me yet, hopefully never. What are the symptoms we see to know when to replace it? Im at 89k miles nothing been replace. Not headgasket not timing belt, but its running strong.
SubieGenius is offline   Reply With Quote
Old 01-01-2009, 09:12 PM   #20
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
When the temp gauge hits H.
Not from personal experience, just reading alot, you will see coolant disappear. Possible smells of coolant hitting exhaust, bubbles in overflow after running. Heat may not blow hot.
Most important to keep a real close eye on your cold coolant level in your overflow. It'll save you some bucks.
Old 01-02-2009, 07:41 PM   #21
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Well, you're getting awfully close to the service interval on the timing belt. Best to not wait for it to go either. Interference engines don't like that.
Counterfit is online now   Reply With Quote
Old 01-03-2009, 04:04 AM   #22
H5N1
Member#: 412
DOHC 2.5RS - SOLD
SOHC 2.5RS
So even the MY07 has the problem.... and with such low milage?
Old 01-03-2009, 07:49 AM   #23
blackfang
Member#: 131347
2007 Legacy 2.5i SE
What you are not realizing is that all cars can have problems, but the amount of headgasket issues are far far less with the new models than the older ones.
Old 01-03-2009, 05:24 PM   #24
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
my 01 started leaking (internal) at 145K. I fixed it with the subaru coolant additive. I guess it wasn't bad enough.
Question is if we should use the additive (blue bottle) in the newer cars?
Jerry Xu is offline   Reply With Quote
Old 01-03-2009, 07:11 PM   #25
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Up to 2007, yes, it is stated as part of the Subaru recommeneded services. The protocol with the new blue coolant, not sure.
WRX/STi axle back exhaust bolt on to NA 2.5? Kid Icarus Normally Aspirated Powertrain 10 09-04-2011 01:43 PM
Which head gasket will be most reliable for 2.5 / 2.2 hybrid? JoshP Normally Aspirated Powertrain 8 06-02-2006 03:27 PM
APEXi S-AFC on a NA 2.5 AngryBlueRS New England Impreza Club Forum -- NESIC 15 05-21-2004 10:07 AM
Oxygen Sensor problems on 2000 Impreza 2.5 RS knoffer Warranty Issues & SOA Problems 20 12-12-2001 05:04 PM
Oxygen Sensor problems on 2000 Impreza 2.5 RS knoffer Normally Aspirated Powertrain 11 12-03-2001 01:42 AM
