Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 03-13-2014, 03:03 AM   #1
bigbikeben
Member#: 360181
2004 Impreza 2.5 TS
Default Engine whine under partial throttle
I've got a MY04 2.5 TS with 117k on the odo (10k with me) and a fully stock drivetrain. This has been my first winter with the vehicle and, as expected, I've had a few issues that poked up along with the cold weather.
My biggest concern is a high-pitched whining coming from the front left quadrant of the car under partial throttle (and only partial throttle). The noise is more audible from outside the car than in the cabin, and presents no change in different gears, loads, temps, etc. When accelerating (going from 0% to about 60-70% throttle), the noise presents itself like a blow-off valve (no, I don't have any aftermarket upgrades under the hood) with a short "tssss" sound followed by normal operation. But if I hold the throttle at about 15-25%, it creates a sustained hiss or whine that sounds like a mixture between a tire deflating and an electric motor running.This is somewhat annoying and unnerving because it happens to lay just in the throttle range of cruising speed and I find myself more lead-footed to avoid the noise.
The sound began after a brief period of sub-0F temps early this winter, but is no longer temperature dependent. It was 60 the other day and, even after fully warming up, the bugger was still at it. I do not experience any noticeable change in performance or other symptoms I can reasonably link to the noise, but its a sound that wasn't there before and now it is... and I don't like it.
Recap/TL;DR:
-Noise under partial (15-25%) throttle, not above or below
-Not gear/rpm dependent or engine/external temperature dependent
-Louder outside cabin than in
-Sounds like high pitched electrical motor/dog whistle/tire deflating/etc
-Began after week-long period of super low temps this winter
Any thoughts?
bigbikeben is offline   Reply With Quote
Old 03-24-2014, 06:07 PM   #2
bigbikeben
Member#: 360181
2004 Impreza 2.5 TS
Well figured it out. Turns out my intake filter casing was improperly sealed.
