Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 05-28-2009, 06:00 PM   #101
IMPRZV
Member#: 177476
2005 STI Stage 2
Here is more ammo on the head gasket war.
I have an 05 STI and have 55K miles on it. It started overheating and of course found out it was a blown head gasket. I got everything done under warranty. They even replaced my timing belt because they said it had a nick in it. My turbo was cracked and they replaced that also. Great customer service. Disappointed in the whole head gasket leaking though. I thought these motors were bullet proof.
IMPRZV is offline   Reply With Quote
Old 05-28-2009, 06:32 PM   #102
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
I just did the HG on my 01 that has 160K. I did it in car. Whe I have time, I may do a write-up.
Now the oil consumption totally stopped. The mileage is up 1-2 MPG also.
Jerry Xu is offline   Reply With Quote
Old 05-28-2009, 07:14 PM   #103
sxewrx
Member#: 86142
1998 Impreza OBS
Red grey 2 tone
If you do a write up please post the link here.
sxewrx is offline   Reply With Quote
Old 06-03-2009, 04:35 AM   #104
travlinimprez
Member#: 175489
2003 impreza 2.5rs
I just rolled over 100k on my 03 2.5rs, im getting the burnning coolant smell, but i cant find a leak or where it is coming from. Its not the heater core, and there is no smoke from the exhaust. I have replaced the water pump/ thermostat. It isnt over heating, but i just recently had a 5hr trip and anytime i would get over 70mph it would start to overheat...is this the head gasket curse i keep hearing about?
travlinimprez is offline   Reply With Quote
Old 06-03-2009, 02:47 PM   #105
VIsubi
Member#: 187834
06 2.5i impreza
Red
I have 15,000 and I have apsolutely no oil leak or consumption then again I allow my engine to get to the right temp before I drive it..so its never cold..aslo this allows metal to expand and seal....its an 06 and still driving strong and I drive it hard occasionally like 5,000-5,500 shifts....I plan on upgrading gaskets when high flow heads come just to be safe...
VIsubi is offline   Reply With Quote
Old 11-09-2009, 03:27 PM   #106
yossarian1
Member#: 229460
Default Sorry to dredge up an old thread
I'm a noob and can't start a new thread yet and need some expert advice.
I have a blown head gasket on my 99 Legacy Outback 2.5 with 126k and I am going to have the dealer do the repairs for $1500.00 Am I throwing my money away on repairing this? Will this problem resurface in the next 20-40K miles? The rest of the car is pretty solid and would like to keep it if I can. I'd love to get another 3/4 years out of the car.
thanks
Kevin
yossarian1 is offline   Reply With Quote
Old 11-09-2009, 03:48 PM   #107
Sir Punk
Member#: 173492
99 RS
BRP
did you jack up one side of the engine to make it easier?
how long did it take?
Sir Punk is offline   Reply With Quote
Old 11-09-2009, 09:43 PM   #108
2.5_IMP
Member#: 163604
2002 Outback Sport, 110,000 miles. External oil leak started around 90,000 miles. Lately it has been consuming a lot of oil, but the external leak has slowed down a bit. Just noticed some of the dreaded mayonnaise accumulating under the rad. cap this morning.
2.5_IMP is offline   Reply With Quote
Old 11-10-2009, 12:13 AM   #109
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
thanks
Kevin
If they do it right, it should last another 100k or so. Maybe more. If they do it wrong, it won't last 5k.
BAN SUVS is offline   Reply With Quote
Old 11-10-2009, 02:10 AM   #110
Imp-RS
Member#: 212003
'03 legacy, external coolant leak, fixed with conditioner. (around 80k - don't own it any more so..)
'02 RS BHG external, replaced HG's (120k on OD)
Imp-RS is offline   Reply With Quote
Old 11-10-2009, 10:15 AM   #111
yossarian1
Member#: 229460
Thanks! Thats the kind of feedback I was looking for.
Old 11-30-2009, 12:05 PM   #112
Subarudude2
Member#: 139445
2007 WRX wagon
CGM Cobb Stg 2
Default My Story...
I just had an oil change done on the wife's 2002 Forester with 115K miles. got a laundry list of items back.
1. External oil leak at HG. Didn't mention which side
2. Need new spark plug wires
3. Side marker lights out
4. Brakes down to 1/32 up front.
I'm reasonably confident in my mechanical ability to do the middle two, the others not so much.
My question on the HG is if it is advisable to add stop leak to help prevent/put off the internal gasket failure or is it wasted money? I spoke to my mechanic's engine guy and he mentioned doing the timing belt/water pump due to oil leaking onto the belt and ruining the belt. That was just done last year and I don't relish paying for it again. I was quoted ~1380 from the dealer for the HG. Doesn't sound like a bad estimate from what I've read on this thread. I spoke to another friend who mentioned doing a compression test in each cylinder. If that is done and the compression is where it should be, do i go further and get the HG done or ignore it? At this point I'm on info overload and could use a a little guidance. Thanks for the feedback.
Kyle
Subarudude2 is offline   Reply With Quote
Old 11-30-2009, 03:52 PM   #113
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
You're right,t he middle 2 are easy. #4 is also very easy,and brake pads are cheap. If you can rotate your tires, you can change brake pads.
As for the leak, since it's external I wouldn't worry about it if you're not noticing coolant or oil on the ground. Just keep an eye on the level of each for a while to get an idea of how much is leaking.
Old 11-30-2009, 04:20 PM   #114
BillyMagnum
Member#: 219892
00' RSTi 97'EJ20K
Cool Vanilla
supposedly I think its the 98-03 that have head gasket problems...I just redid mine on my 02rs
BillyMagnum is offline   Reply With Quote
Old 12-02-2009, 04:28 AM   #115
MarioAndretti
Member#: 199394
02 Impreza OBS
red
My mother bought a 98 legacy brighton brand new.After 4 years the only problem this car ever had was a failed thermostat.Luckily she paid attention to her guages and got the back home without any damage.She sold the car to my cousin in 2004 with 80k miles on the clock.Since then he has put over 60k miles on it with no trouble,with the exception of leaking valve cover gaskets.Being that this car has been virtualy trouble free for so long and has never nad the coolant conditioner in it,I don't think it's so much a material problem but an issue with the person torquing the head bolts properly.
I have been driving my 02 OBS with 180k+ miles for 1 year now with no leaks anywhere.Cherry capital subaru has records of the work done to this car through 08 and there are no records of the head gasket being replaced.This along with posts about their 07 with only 25k miles needing head gaskets further leads me to believe that human error is the culprit.If it really was a design flaw,I would think that both of these cars should have needed the HG done at least 1 or 2 times by now.
So my observations say that it would either be human error or we have been very VERY lucky.Would you not agree?
MarioAndretti is offline   Reply With Quote
Old 12-02-2009, 09:34 AM   #116
skottm
Member#: 87963
2000 Impreza 2.5 RS
You've been lucky. Lucky that your mom's & cousin's car has a 2.2 which will never die, and lucky that your 2.5 has apparently not failed...yet.
skottm is offline   Reply With Quote
Old 12-02-2009, 09:37 AM   #117
Subarudude2
Member#: 139445
2007 WRX wagon
CGM Cobb Stg 2
Thanks for the advice...I bought Bars stop leak block/radiator formula. I figure it can't hurt, may prevent a future failure and give a little peace of mind too.
Old 12-02-2009, 10:35 AM   #118
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
Get the Subaru Coolant Conditioner
dstan is offline   Reply With Quote
Old 12-02-2009, 12:07 PM   #119
skottm
Member#: 87963
2000 Impreza 2.5 RS
Is it different? I can't imagine a car company inventing their own stop-leak from scratch when there are numerous companies that have been refining their versions for years. More likely Subaru buys it relabeled at a significant discount from someone.
Old 12-02-2009, 12:16 PM   #120
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
They probably didn't invent it, but the chemistry involved can definitely vary from one manufacturer's engine to another. And the Subaru stuff is so cheap, there's really no justifiable reason to not use it.
Old 12-02-2009, 12:27 PM   #121
skottm
Member#: 87963
2000 Impreza 2.5 RS
Hmm, except that the nearest dealer is 45 minutes away. A friend of mine is a subie enthusiast, and lives in another town, might be able to pick some up. I probably should flush the coolant while I'm at it, Peak Global? I've sworn by Zerex G05 for aluminum engines for many years, but I'm open to try something else if it's worked for others.
Old 12-02-2009, 12:41 PM   #122
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Normally I'd say OEM coolant, but with the dealer that far away, I'd just keep using what you've been using. And you can get the HG conditioner really cheap online.
Old 12-02-2009, 01:16 PM   #123
skottm
Member#: 87963
2000 Impreza 2.5 RS
Just bought this car, so I don't know whats in it. I don't like mixing coolants, even after multiple flushes, but I don't know what it is, so I need to pick one. I'll check online for that additive, thanks.
Old 12-02-2009, 04:13 PM   #124
suub07
Member#: 163702
2007 impreza 2.5
UGM
defiantly go with the OEM conditioner. I have read about other brand stop leaks that have caused clogs and such. The OEM conditioner was i think $2.95 or something like that.
suub07 is offline   Reply With Quote
Old 12-02-2009, 05:05 PM   #125
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
My head gasket went on my old outback aswell.
But it was at 175k
bigolrig is offline   Reply With Quote
WRX/STi axle back exhaust bolt on to NA 2.5? Kid Icarus Normally Aspirated Powertrain 10 09-04-2011 02:43 PM
Which head gasket will be most reliable for 2.5 / 2.2 hybrid? JoshP Normally Aspirated Powertrain 8 06-02-2006 04:27 PM
APEXi S-AFC on a NA 2.5 AngryBlueRS New England Impreza Club Forum -- NESIC 15 05-21-2004 11:07 AM
Oxygen Sensor problems on 2000 Impreza 2.5 RS knoffer Warranty Issues & SOA Problems 20 12-12-2001 06:04 PM
Oxygen Sensor problems on 2000 Impreza 2.5 RS knoffer Normally Aspirated Powertrain 11 12-03-2001 02:42 AM
