Old 12-02-2009, 04:26 PM   #126
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Originally Posted by skottm View Post
Just bought this car, so I don't know whats in it. I don't like mixing coolants, even after multiple flushes, but I don't know what it is, so I need to pick one. I'll check online for that additive, thanks.
Drain and fill with 100% DI water. Run it for a day or two, drain and repeat one or two more times. Then you can be pretty sure that you won't be mixing enough coolant to possible cause issues, and running for a few days on 100% water won't hurt either. Besides, a gallon of pure H20 is a buck at the grocery store and you'll only need 6 or 8 to be sure you're flushed.
BAN SUVS is offline   Reply With Quote
Old 12-02-2009, 04:34 PM   #127
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Originally Posted by Subarudude2 View Post
Thanks for the advice...I bought Bars stop leak block/radiator formula. I figure it can't hurt, may prevent a future failure and give a little peace of mind too.
That might have been bad move. If its the one with stuff floating around in it then it seals all the leaks including ones you don't want it to seal like the radiator cap. It doesn't work with the headgasket leaks because the combustion gasses will reopen the hole once the goop gets in it.
The Subaru coolant conditioner has no solids like the Bars stuff. You are right that Subaru didn't make it themselves. It's Holts RadWeld See the similarities? lol
Old 12-02-2009, 04:45 PM   #128
06demon
Member#: 151398
i have a head gasket leak also and they told me my PCV valve is bad, but i'm still under warranty!!
06demon is offline   Reply With Quote
Old 12-02-2009, 05:52 PM   #129
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
The bottles both having "Holt" on them and the same shape doesn't prove they're the same substances, but it's pretty strong circumstantial evidence.
Old 12-03-2009, 01:25 PM   #130
Subarudude2
Member#: 139445
2007 WRX wagon
CGM Cobb Stg 2
I have not added the Bars stuff yet. I planned to this weekend. I have a dealership on my way home i can stop by and pick thisup. Thanks for the advice. Is this just add and forget or do i have to do the whole flush and fill thing?Thanks.
Subarudude2 is offline   Reply With Quote
Old 12-03-2009, 03:51 PM   #131
impRSa
Member#: 6521
I just had mine replaced at 105K, over the 8 year/100k warranty. Wrote to Subaru, they decided to split the cost.
02RS
impRSa is offline   Reply With Quote
Old 02-14-2010, 07:54 AM   #132
montana54
Member#: 238335
I just returned from the dealer while having an unrelated recall rervice performed. They informed me that the head gaskets are leaking and should be replaced.
The oil looks fine, I don't add any coolant, and I don't see any obvious drips. Where or what else should I be looking for that would indicate the head gaskets are leaking?
2005 Outback, 2.5i, 85,000 miles
montana54 is offline   Reply With Quote
Old 02-14-2010, 05:18 PM   #133
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Ask the dealer to show you what they found. Then you get the bonus of laughing in their faces if it's something stupid.
Old 02-14-2010, 08:00 PM   #134
EJ25I
Member#: 130500
2006 Impreza 2.5i
Regal Blue
i have an 06 impreza 2.5i 58,000 my head driverside head gasket is leaking. when i had it up on the lift the other day i should have taken a picture. mine is an external leak.
EJ25I is offline   Reply With Quote
Old 02-15-2010, 09:41 AM   #135
montana54
Member#: 238335
Yes, I should have asked dealer while I was there. I have looked fror signs of an external leak but haven't seen anything (unless I'm looking in the wrong place).
Any other suggestions on what I could check?
Old 02-15-2010, 07:58 PM   #136
EJ25I
Member#: 130500
2006 Impreza 2.5i
Regal Blue
mine is not that bad of an external leak, when i had it on the lift you could see the oil leaking from the head gasket. easier to see with header off. i had to take my heat shields off the other day loud rattle, very annoying. thats when i got a good look. just keep an eye on your oil level and coolant. like every six months or so my coolant resivour will be about empty.
Old 02-15-2010, 10:49 PM   #137
Neoshi
Member#: 76605
A bunch of us over at Subaruforester.org are exhibiting HG failures, leaks, or weeping. I, for one, am exhibiting HG weeping oil, coolant loss, bubbles in overflow after driving, high sodium content in uoa results. 05 ej253 with 65,996 miles. hg weep started about 3-4k miles ago, coolant conditioner always used with coolant changes at 30 and 60k maints. we are starting a group effort to write to soa ceo. come join us (problems and maintenance sub forum).
Neoshi is offline   Reply With Quote
Old 02-16-2010, 07:07 PM   #138
EJ25I
Member#: 130500
2006 Impreza 2.5i
Regal Blue
ill check it out thanks
Old 02-16-2010, 07:25 PM   #139
GotHP?
Member#: 51138
2015 LE STI
just back from the dealer here, 2003 Outback leaking oil and coolant. Quoted $2100 for head gaskets! 20 hrs. labor seems crazy to me...also contacted SOA to see if they'll step up and help, can't hurt to try.
GotHP? is offline   Reply With Quote
Old 02-16-2010, 11:33 PM   #140
Riderofthelastday
Member#: 226922
2004 obs
I read they changed hg material for the 04 models, and if you go on edmunds it shows hg problems under the reliability section from 97-03, and then 04+ are good, but it could have just not shown up yet, but since others say its been fixed...
Riderofthelastday is offline   Reply With Quote
Old 02-16-2010, 11:37 PM   #141
Riderofthelastday
Member#: 226922
2004 obs
i thought that subaru blue bottle was a conditioner to prefent acidity or somthin and because somthin about the aluminium block, not a stop leak
but yeah stop leak can plug up stuff like your thermostat, heater core or at least the line too it ect
Old 02-17-2010, 12:49 AM   #142
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
I forgot to update this thread since no one answered my question, many posts back, but about 4-5 months ago when putting on the uel headers, bam, drivers side head gasket leak, how do I know for sure, a suby shop mechanic on my local board helped me put the headers on and he pointed it out to me, the kicker, have about 27K on the car and not abused, well maintained, etc.
Just waiting for the weather to get nicer and will get it fixed under warranty as I still, now, at this point, have 6K left, but I am now worried about them placing the blame on the uel headers, which I know the leak was there at the time of install.
I guess I know why my car has stunk of anti-freeze for a very long time, why I fill the anti-freeze over flow tank on a regular basis, unless there is an additional problem as well? I am not sure to be honest what's leaking down there as I am not Mr. Head Gasket Expert, anti-freeze, oil or both?
My car also seems to like to drink oil, not crazy amount but def, at least 1 quart between oil changes.
kero is offline   Reply With Quote
Old 02-17-2010, 06:26 PM   #143
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Depending on the miles, you might be covered. My pop-in-law has a '03 Legacy w/66K miles and SOA owned up 100%.
They are changing his timing belt for free as well. He is as happy as a little girl. Thanks SOA.
surowrxa is offline   Reply With Quote
Old 02-18-2010, 04:28 PM   #144
nitro1956
Member#: 230682
Default 2.5 HG Leaks
Something I've been wondering about.
The 96-97-98 2.5s are prone to internal HG leaks. The 2000-01-02 2.5s are prone to external HG leaks.
So how about the 1999s . Do these have a mix or internal/external HG leaks ? This gets confusing.......since the 99s apparently could have either Phase I or Phase II blocks and either SOHC or DOHC heads.
( related question...the 1999 Legacys.......did these come from the factory with four different N/A engine configurations....ie.. the mix of Phase I/Phase II and SOHC/DOHC ? )
nitro1956 is offline   Reply With Quote
Old 02-18-2010, 04:32 PM   #145
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I just fixed an 05RS with 90k miles. Had external coolant leak on the bottom side of both heads and also an internal cylinder leak into the water jacket.
Old 02-19-2010, 02:28 PM   #146
pdi180
Member#: 77540
2002 Legacy L Sedan
I have an external coolant leak on my 02 legacy. I had the HG replaced at 50,000 miles and it was under warranty. Now it is at 76,000 and it happened again. I called up SOA and they were good about helping me out. They told me to take it to the dealership for an inspection (~$50) and they would see if they could cover it. My Engine is not one of those effected by the warranty extension, but the guy at SOA said that since I have had it serviced and kept things up to date, that they wouLd "see what they can do." I take it in this afternoon.
pdi180 is offline   Reply With Quote
Old 02-19-2010, 08:33 PM   #147
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
my 07 impreza's head gaskets are in good shape with 85k on the odometer, however while changing my spark plug wires and plugs i came to find out my valve cover gaskets are shot. But those are 99% easier to fix!
07ImprezaMB is offline   Reply With Quote
Old 02-19-2010, 09:35 PM   #148
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
don't worry. hg is programed to come soon after the vcg game.
Jerry Xu is offline   Reply With Quote
Old 02-21-2010, 10:22 PM   #149
Subarudave09
Member#: 209316
14 XV
my 2008 started to leak at 22k !!!! its bad now at 59K its gettn fixed this week
Subarudave09 is offline   Reply With Quote
Old 02-21-2010, 10:48 PM   #150
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Aaaaand now my personal car just had both heagaskets fail at 114k miles. Coolant leak to the outside, we'll see if there's a leak internally.
WRX/STi axle back exhaust bolt on to NA 2.5? Kid Icarus Normally Aspirated Powertrain 10 09-04-2011 01:43 PM
Which head gasket will be most reliable for 2.5 / 2.2 hybrid? JoshP Normally Aspirated Powertrain 8 06-02-2006 03:27 PM
APEXi S-AFC on a NA 2.5 AngryBlueRS New England Impreza Club Forum -- NESIC 15 05-21-2004 10:07 AM
Oxygen Sensor problems on 2000 Impreza 2.5 RS knoffer Warranty Issues & SOA Problems 20 12-12-2001 05:04 PM
Oxygen Sensor problems on 2000 Impreza 2.5 RS knoffer Normally Aspirated Powertrain 11 12-03-2001 01:42 AM
