Old 04-14-2011, 12:14 PM   #76
Maxwell Power
Member#: 190729
not according to Jeff's spread sheet. However, according to the application chart from Subaru for the two different heads they are both available through 05 and 06. I think it's just VIN specific.
Here:
D25 head 11039AB980
Date Body Engine Train Transmission Grade
'03, November — '07, March SEDAN 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT(OBK:XT)
'03, November — '07, March SEDAN 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT(OBK:XT)
'03, November — SEDAN 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT LIMITED(OBK:XT)
'03, November — SEDAN 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT LIMITED(OBK:XT)
'05, November — SEDAN 2500CC EMPI DOHC TURBO FULLTIME 4WD 6SP Manual transmission 25GT-B
'03, November — '07, March WAGON 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT(OBK:XT)
'03, November — '07, March WAGON 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT(OBK:XT)
'03, November — '08, April WAGON 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT LIMITED(OBK:XT)
'03, November — '08, April WAGON 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT LIMITED(OBK:XT)
'03, November — '08, April WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT LIMITED(OBK:XT)
'03, November — '08, April WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT LIMITED(OBK:XT)
'03, November — '07, March WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT(OBK:XT)
'03, November — '07, March WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT(OBK:XT)
'08, March — WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25XT LIMITED
'08, March — WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25XT LIMITED
B25 Head: 11039AB650
'03, November — '06, June SEDAN 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT LIMITED-I(OBK:XT)
'03, November — '06, June SEDAN 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT LIMITED-I(OBK:XT)
'03, November — '06, June WAGON 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT LIMITED-I(OBK:XT)
'03, November — '06, June WAGON 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT LIMITED-I(OBK:XT)
'03, November — '06, June WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT LIMITED-I(OBK:XT)
'03, November — '06, June WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT LIMITED-I(OBK:XT)
Maxwell Power is offline   Reply With Quote
Old 04-14-2011, 12:41 PM   #77
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Mine came with B25 heads.
EDID: At least that's what being quoted by the dealer in the repair since they looked it up by VIN.
Leonardo is offline   Reply With Quote
Old 04-14-2011, 03:56 PM   #78
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Cool Dom. I'd only seen them with B25. I learned something new today
Old 05-24-2011, 11:20 AM   #79
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
My friend just bought an 05 WRX with an hybrid engine on it (S20 heads + ej255 SB). the previous owner said it was built HG with 2x the thikness.
My question is, at what CR this will put this engine?
Thanks
PS. Sorry for bumping this old thread
Ferraz is offline   Reply With Quote
Old 05-24-2011, 01:46 PM   #80
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
Thanks
without knowing what pistons were used, and what thickness head gasket, among many other things.. that is a hard question to answer.
Z0rr0 is offline   Reply With Quote
Old 05-24-2011, 02:09 PM   #81
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
Stock ej255 short block. I will check what HG was used.
Thanks.
Old 05-24-2011, 02:23 PM   #82
Maxwell Power
Member#: 190729
approx 8.6:1 with OEM headgasket
8.3:1 with 040" headgasket
8.1:1 with 051" headgasket
Assuming untouched S20 heads and oem EJ255 block.
Should have just used the OEM headgasket.
Old 09-19-2011, 07:20 PM   #83
acechase
Member#: 222996
05 wrx sedan
white
After reading this post i have decided to make the plunge. Just bought the EJ255 short block and work on finishing up the hybred. The one question i have is pertaining to the flywheel and clutch. I'm currently running a 05 wrx and have replace clutch with a stage two clutch and upgraded to a lightweight flywheel. Will i need to change these over the 2.5 version or will i be able to run my existing 2.0 parts?
thank you
acechase is offline   Reply With Quote
Old 09-21-2011, 12:17 PM   #84
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
What about 2010 Sti heads?
juanmedina is online now   Reply With Quote
Old 09-21-2011, 12:25 PM   #85
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
2008, 2009, 2010 STI heads are all the W25 heads. Even the 2011 STI heads are I believe. They are Dual AVCS heads and are certainly not the B25 Intake AVCS heads.
Jasper.
jkopinga is offline   Reply With Quote
Old 09-21-2011, 04:03 PM   #86
turbo sol
Member#: 245106
2004 WRX Wagon
San Remo
the EJ255 (semi closed with deeper dish model) and EJ205 heads yields a bit lower compression (8.6:1) than the EJ257block w/ EJ205 heads (8.8:1)
my question is:
is compression the main concern or is it the quench / combustion camber shape that causes the detonation?
i know machining the heads helps with the 257 block, but would you need to do it with the 255?
turbo sol is offline   Reply With Quote
Old 09-21-2011, 04:20 PM   #87
Maxwell Power
Member#: 190729
Chamber is the issue. The higher compression ratio just makes the problem worse.
Old 09-23-2011, 11:02 PM   #88
02wrxej208
Member#: 295496
2002 stroked 20g bug
that sounds about right
02wrxej208 is offline   Reply With Quote
Old 10-23-2011, 11:04 PM   #89
Vdubtype1
Member#: 297549
Does anyone have blueprints of these engines?
Vdubtype1 is offline   Reply With Quote
Old 10-24-2011, 10:13 AM   #90
Homemade WRX
Member#: 33782
96 bastard child
what kind of blueprints do you need?
Old 10-24-2011, 11:30 AM   #91
Maxwell Power
Member#: 190729
I was slightly confused by the question as well.
We have many sheets for blueprinting motors, but the question didn't seem like he wanted that....
Old 10-24-2011, 12:25 PM   #92
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
FHI does!!!
FuJi K is offline   Reply With Quote
Old 10-24-2011, 02:48 PM   #93
Homemade WRX
Member#: 33782
96 bastard child
Well if he was asking for blueprints for sleeving or as Dom said, maybe he want a list of dimensions for 'blue printing'
If you want manufacturing blue-prints, best of luck with that. Time to start measuring
Old 10-24-2011, 02:53 PM   #94
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Anyone have a CAD drawing of a headgasket? I wants to have fun on a CNC
Crystal_Imprezav is offline   Reply With Quote
Old 10-24-2011, 09:29 PM   #95
unclemat
Member#: 114530
2005 LGT 6MT wagon
Subaru's own Subarufast application disagrees. According to it ALL 05 & 06 turbo Legacy and Outbacks use B25 head. 07 use D25. No VIN dependency.
It would have been very strange because D25 use different oil feed pipe that I have not seen on a single 05-06 car.
However, I guess Subarufast was Jeff's source as well. I have never been let down by Subarufast so I tend to believe it over some bulletin from SOA.
Here:
D25 head 11039AB980
'03, November '07, March SEDAN 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT(OBK:XT)
'03, November '07, March SEDAN 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT(OBK:XT)
'03, November SEDAN 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT LIMITED(OBK:XT)
'03, November SEDAN 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT LIMITED(OBK:XT)
'05, November SEDAN 2500CC EMPI DOHC TURBO FULLTIME 4WD 6SP Manual transmission 25GT-B
'03, November '07, March WAGON 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT(OBK:XT)
'03, November '07, March WAGON 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT(OBK:XT)
'03, November '08, April WAGON 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT LIMITED(OBK:XT)
'03, November '08, April WAGON 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT LIMITED(OBK:XT)
'03, November '08, April WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT LIMITED(OBK:XT)
'03, November '08, April WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT LIMITED(OBK:XT)
'03, November '07, March WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT(OBK:XT)
'03, November '07, March WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT(OBK:XT)
'08, March WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25XT LIMITED
'08, March WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25XT LIMITED
'03, November '06, June SEDAN 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT LIMITED-I(OBK:XT)
'03, November '06, June SEDAN 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT LIMITED-I(OBK:XT)
'03, November '06, June WAGON 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT LIMITED-I(OBK:XT)
'03, November '06, June WAGON 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT LIMITED-I(OBK:XT)
'03, November '06, June WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Manual transmission 25GT LIMITED-I(OBK:XT)
'03, November '06, June WAGON OUTBACK 2500CC EMPI DOHC TURBO FULLTIME 4WD 5SP Automatic transmission 25GT LIMITED-I(OBK:XT)
unclemat is offline   Reply With Quote
Old 10-24-2011, 10:03 PM   #96
Maxwell Power
Member#: 190729
My ex-wife's 06 LGT had D25 heads.
Old 10-24-2011, 10:10 PM   #97
Homemade WRX
Member#: 33782
96 bastard child
not to take sides at all but I have yet to see a pre 06 LGT, FXT, Baja that didn't have a B25 head. As we all know, Subaru does seem to just grab parts sometimes or do mid year parts phasing...so the 06 could be just that.
Old 10-24-2011, 10:19 PM   #98
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Can't speak for a 06 by I will run out to my 07 LGT later and see if I can get the head casting number off it.
Old 10-24-2011, 11:04 PM   #99
unclemat
Member#: 114530
2005 LGT 6MT wagon
Are you sure of the car's history? Could it be some dealer's hack job? Maybe a manufacturer's car or something non standard?
E.g. I know of two USDM 06 LGT MT wagons that were manufacturer's cars, even though they were not officially sold - one appeared on used market couple of years later. However it was recognized by Subarufast by it's VIN.
But if it is not reflected in their own VIN-dependent parts database, that's weird isn't it? It would create incredible headache for a dealer repairing such a car. It's not just the difference in the oil pipe, but the air pump holes (I assume D25 have them), or even the engine tune due to the different compression ratio. The changes between 06 and 07 (when D25 appreared) were substaintial. Different ECU (CAN), different turbo, weaker wastegate spring, top-feed fuel rails. You can't just slap the new heads with the rest of the old gear and call it a day.
I mean sure, Subaru does mid year revisions with many parts, but the head swap is not minor change. I know of several mid year changes, e.g. in 05 LGTs and they are all reflected in Subarufast (examples from top of my head: bolts vs. studs on TGV housings, elimination of the gas tank pressure sensor, number of pop-its on rear bumper cover - yeah, seriously!). See, if Subaru goes to such an extent to provide accurate part info, they would skip on something substantial like heads?
With all respect to the knowledge and experience of Maxwell Power, color me very, very skeptical about D25 heads being present on a MY2006 LGT. I'd bet it was a MY2007 car. The car is probably ex just as the wife is, so I guess we can't confirm it
Old 10-24-2011, 11:21 PM   #100
Maxwell Power
Member#: 190729
Bought it new off the lot with thirteen miles. She took it in the divorce though so I can't do **** to back it up at this point. Doesn't really matter though. If you need to know what is in your car, just look.
EJ257 Block and Internals with EJ255 Heads jpirrung18 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-24-2010 05:42 PM
EJ257 vs EJ255 dyno results are in !!!! IA Performance Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 69 03-10-2010 12:37 AM
EJ257 vs EJ255 Cam differences Maxwell Power Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 05-12-2009 11:39 AM
Newbie Q: EJ25E vs. EJ255 vs. EJ257 tekgnosis Built Motor Discussion 2 12-31-2006 02:26 PM
EJ257 vs EJ255 English2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-05-2006 08:52 AM
