Notices
Old 12-29-2008, 10:08 PM   #1
FastInMass
Member#: 96082
2003 Stage 2 WRX
Sedona Red
Default 2 Separate Problems...need help
After searching I found nothing definitive on either issue...i have a 2003 WRX Stage 2 protuned with RA gears and Organic Exedy Clutch plus more goodies not really related...anyway:
Problem 1: In each gear when i hit 3k rpm while getting on the throttle it seems to lose hold of the gear until right before 4k. the rpms actually rev and it catches when it get up around 4k. DOES THIS SOUND LIKE A BLOWN CLUTCH? i didn't think that it would be the same area in each gear had it been the clutch but i could be wrong
Problem 2: I just replaced a blown radiator a month ago. Had it assessed at the dealership and they said the head gasket was ok, just the radiator. so i replaced it. i have all solid connections with new samco hoses throughout so no leaking hose and the slightly used radiator is in mint condition. no puddles and no noticeable changes in level in my reservoir tank. [b]DOES THIS SOUND LIKE A LEAKING WATER PUMP?B]
please advise...any help is extremely appreciated
FastInMass is offline   Reply With Quote
Old 12-29-2008, 10:16 PM   #2
FastInMass
Member#: 96082
2003 Stage 2 WRX
Sedona Red
wrong area
Old 12-29-2008, 10:24 PM   #3
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Holy snacky cakes! A self-recognized fail!
LetItSnow is offline   Reply With Quote
2.0/2.5 Hybrid engine with problems, need help!!! hernan_Arg Built Motor Discussion 14 07-27-2010 08:45 PM
2 separate problems...need help FastInMass Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-30-2008 10:25 PM
2.5 over boosting problem need help!!! 2006greywrx AccessPort 12 04-01-2008 11:01 PM
98 OBS - 2 Problems, need help Lowball Outback Forum 1 07-25-2007 08:45 AM
('93-'01) Clutch problem need help dvs81n Impreza Forum 0 04-24-2001 06:13 AM
