Old 12-30-2008, 03:23 AM   #1
atenzany62
Member#: 163172
Default My key can't open the door!!
the only way to open the door is to use the remote. i do not have an alarm system just a normal remote that does lock/unlock/panic. i tried to use the key to open either one of the doors one day it doesn't work at all. why????? could this be that the previous owner or something had a complicated remote start and was removed by someone incorectly?
atenzany62 is offline   Reply With Quote
Old 12-30-2008, 08:00 AM   #2
z&cobb
Member#: 12344
2002 2JC
blue
Try the valet key, if you have one.
The dealer can cut you a dual function key for about $6. He will need your key to do it. Go to the parts department. Go in the back door and stay out of the sales room, since they will say you need a new car.
z&cobb is offline   Reply With Quote
Old 12-30-2008, 11:33 AM   #3
joecerv
Member#: 110459
2006 Impreza 2.5i
Steel gray metallic
Remove the door panels and check that the locking mechanism are still connected.
joecerv is offline   Reply With Quote
Old 12-30-2008, 11:54 AM   #4
DrewDeezy
Member#: 160279
2004 STi
Crawford Performance
does it turn once inside the keyhole?
DrewDeezy is offline   Reply With Quote
Old 12-30-2008, 11:58 AM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
try replacing the battery.
Old 12-30-2008, 12:13 PM   #6
atenzany62
Member#: 163172
yes it turns but it doesnt unlock the doors. i just got a brand new battery a month ago.
Old 12-30-2008, 12:32 PM   #7
joecerv
Member#: 110459
2006 Impreza 2.5i
Steel gray metallic
He is pulling your leg.
The ley lock cylinder is mechanical, it has nothing to do with the battery.
Since 05wrxguy's question was answered and the key does turn, the locking mechanism might not be connected, as I stated before, when you get a chance verify that everything is in place. It could be that the previous owner disabled them.
Old 12-30-2008, 12:49 PM   #8
DrewDeezy
Member#: 160279
2004 STi
your locking mechanism is failing. might be a long shot, hit the inside of your door panel as this could jolt something. If you are not the DIY kind, sure a dealership could fix for you for roughly 100 bucks assuming you dont need any new parts
Old 12-30-2008, 01:49 PM   #9
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
If your key works in the passenger's side door/trunk/glove box then it's your locking mechanism as stated above.
Old 12-30-2008, 02:50 PM   #10
atenzany62
Member#: 163172
passenger side dont work. key works for the trunk though. i'll check that out thanks guys.
Old 12-30-2008, 04:23 PM   #11
DrewDeezy
Member#: 160279
2004 STi
locking mechanism is failed sounds like. do you have only 1 key to test?
Lock cylinder, impreza, left 95-02 $42.82
MY advice to you? call around and ask how much it would be just to look at it. Usually if you take it to a locksmith, they might give you an idea what might be wrong
can't open the doors ganker Mid Atlantic Impreza Club -- MAIC 29 02-03-2010 09:31 AM
someone keeps propping open the door to the ladies' room coop119 Off-Topic 11 08-11-2006 09:14 AM
Open the door, get on the floor, everyone walk the dinosaur -=C=- Off-Topic 5 08-17-2005 11:01 AM
ARG! Someone just opened the door to my stall! theJrod Off-Topic 23 01-29-2004 10:08 PM
:Monkey: to people who can't open car doors Tricky Vancouver Impreza Club Forum -- VIC 10 06-11-2003 04:09 PM
