Old 12-30-2008, 01:44 PM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default Dyno tests confirm Nissan GT-R drivetrain loss, power ratings
Testing cars for power ratings is a tough and tricky business - accounting for different conditions, locations, equipment and techniques can make it tough to generalize results. And to make matters worse, there is often a lot of guesswork employed to get between real, delivered wheel horsepower and output at the crankshaft, or vice-versa. A recent test of Nissan's GT-R has answered some of the ongoing questions of how it performs so well, however, and taken a good bit of the fiction out of the process.
Rumors and reports from around the web have been claiming Nissan's stated figures for the GT-R's twin-turbo V6 are understated ever since it began its remarkable climb up the many performance charts. All-wheel drive and tons of rubber just couldn't make up for the massive power deficit, they claimed. But it turns out Nissan's claimed 473hp (353kW) figure isn't far from the truth at all, according to MotorTrend. The torque numbers are about 40lb-ft (54Nm), or roughly 9%, larger than Nissan's 434lb-ft (588Nm) rating, and could help explain a little of the car's low-end acceleration abilities.
The key to this latest round of testing is the use of Hyper Power Dynamometer's DYNOmite, which allows testing not just of engine output, but of powertrain drag. After a dyno pull, instead of ceasing to record data, the machine records the slow-down period, and measures the drag due to the car's powertrain, including engine, transmission and wheels.
The end result? As physics would suggest, the parasitic losses of the drivetrain increase with speed, varying from 23hp (17kW) at 50mph to 84hp (62kW) at 100mph. That works out to a real-world inefficiency ranging between 5-17%, depending on speed - quite good for an AWD car.
One thing to keep in mind, however, is that this is just one particular example of the car - power figures can and will vary from vehicle to vehicle. It will simply take time and repetition to see if these results are more or less representative of the general population of Nissan GT-Rs than previous tests. The method, however, is a definite improvement.
http://www.motorauthority.com/dyno-t...r-ratings.html
Old 12-30-2008, 01:47 PM   #2
Skunkers
Member#: 115480
monaroCountry in 5... 4... 3... 2...
Skunkers is offline   Reply With Quote
Old 12-30-2008, 01:59 PM   #3
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default 2009 Nissan GT-R Horsepower: The Truth
Go to link for Graphs of the Pulls
Yes, we have already dynoed Nissan's GT-R and we made some very controversial claims as to the true power output of said GT-R. The unknown in that test was the elusive "driveline losses." That's the amount of power lost to inertia of spinning parts like gears and driveshafts and friction in the transmission, U-joints, axles, etc., which have traditionally had to be estimated. We used the conservative estimate of 15% that's usually used for simple manuals, but this one uses twin hydraulically actuated clutches, includes all-wheel drive, with two separate prop shafts, so we considered our estimate conservative.
Our Dynojet inertia-type machine indicated a mean output of 430.6 hp at 6700 rpm and 425.3 lb-ft at 3900 rpm, which we interpreted as 507 hp and 500 lb-ft after accounting for the 15% loss.
We were recently contacted by a Motor Trend reader who saw our first GT-R dyno story. He said he had a new type of dyno that was able to compute the drivetrain losses directly and accurately, removing the guesswork. How, you might ask, does it manage this? That's what we're here to tell you.
When you arrive at Hyper Power International and first see this new dyno, it looks like any other inertia-type dynomometer -- four big rollers, wires, computer screens, the usual -- and like any other dyno you start the process by strapping your vehicle down.
Once secured, the next step is to do a gearing calculation run. This provides the dyno with the engine rpm in reference to the roller speed thus eliminating the need for an rpm pickup, which can provide inaccurate information.
Just before we make our first run the ambient weather conditions are entered into the dyno computer. While we were there the temp ranged from 68 to 72 deg, humidity ranged from 44% to 49%, and the barometric pressure ranged from 29.55 to 29.61 in. of mercury. Again, all this is operating norm for dyno runs. Now it's time for some power pulls.
Our target is Nissan's factory claim of 480-hp @ 6400 rpm and 430-lb-ft of torque @ 3200-5200 rpm.
First pull:
Ending at 6500 rpm, our first run's results were: 485.9 hp @ 6116 rpm and 469 lb-ft @ 3834 rpm (corrected for weather and subtracting the measured losses).
Second pull:
Again, going to almost 6500 rpm the second run gave us 485.5 hp @ 5984 rpm and 475 lb-ft @ 3717 rpm. This is only a 0.4 hp (0.08%) difference from run one with the torque differing by 6 lb-ft (1.2%).
Third pull:
The final run provided us with 483.4 hp @ 6106 rpm and 466 lb-ft @ 3811 rpm, a difference of 0.4% for hp and 1.9% for torque.
Averaging the runs gives us a Hyper Power rating of 485 hp @ 6050 rpm and 470 lb-ft @ 3800 rpm.
So, how did Hyper Power USA measure our driveline drag? At the end of a pull, the computer instructs the operator to put the vehicle in neutral, the dyno then measures the rate at which all the rotating parts slow down, which is directly related to friction and inertia. Our instruments found the loss to be exponential -- as the speed grew so did the loss.
We saw a loss of 23 hp at 50 mph and 84 hp at 100 mph. Over the three runs we saw a driveline loss range from 88 hp to 93 hp. Thus, there is no longer the need to guess at a percentage, Hyper Power Dynamometer's DYNOmite measures it and gives you an actual figure generated by the engine and consumed by the driveline
Here is an example of why using a fixed percentage number for drivetrain loss is flawed in calculating measured dyno horsepower:
Take a turbocharged vehicle, dyno runs put its output at 400 hp and 400 lb-ft of torque. Applying 15% for driveline loss yields an actual output of 460 hp and 460 lb-ft of torque. Now, take same vehicle, turn up the boost on the turbo.
The dyno pulls now have the same exact vehicle rated at 600 hp and 600 lb-ft torque, apply 15% driveline loss, actual output is 690 hp and 690 lb-ft torque. Why does the loss increase with more horsepower? It's the same exact car, just with the boost now turned up. The loss should be the same; whatever the horsepower number is, it's the same driveline.
So, what does this all mean? Well, it suggests that Nissan is basically telling the truth with their horsepower numbers, but the torque numbers are conservative by about 40 lb-ft.
So what does this tell us about Nissan's mighty Monster's miraculous performance? It suggests that the super-short gearing, the twin-clutch gearbox's uninterrupted torque flow, and the amazing (and also controversial) launch-control system are more responsible for generating the incredible acceleration numbers than hidden unclaimed horses.
Pull one versus two
Pull two versus three
Drivetrain drag
Pull one versus two drag
http://www.motortrend.com/features/p...est/index.html
Old 12-30-2008, 02:59 PM   #4
delongedoug
Member#: 124113
and beyond!
Hell, this thread has GTR in the title, I'd expect him to be in here bashing before the OP clicked Submit New Thread!
delongedoug is offline   Reply With Quote
Old 12-30-2008, 09:54 PM   #5
robertrinaustin
Member#: 51964
2008 STi, OB, EVO
Blk Sti and EVO, Navy OB
I can't believe I beat monaroCountry, but maybe it's because all the "it's over rated idiots" haven't shown up yet.
robertrinaustin is offline   Reply With Quote
Old 12-31-2008, 12:50 AM   #6
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
jigga is offline   Reply With Quote
Old 12-31-2008, 01:47 AM   #7
Superglue WRX
Member#: 106275
New Chevy SUV
Government Motors White
Monarocountry is in Australia so we have to remember that time is upside down there. We must have caught him sleeping.
Superglue WRX is offline   Reply With Quote
Old 12-31-2008, 09:10 AM   #8
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
themonarocountry does not require sleep, only posts about GTR to feed his insatiable appetite
Old 12-31-2008, 10:34 AM   #9
Chiketkd
Member#: 71634
In hibernation...
Chiketkd is offline   Reply With Quote
Old 01-01-2009, 04:50 AM   #10
seattle944t
Member#: 18308
2005 WRX STi
Friction is a function dependent on load, so coast down measurements != parasitic losses under power...
seattle944t is offline   Reply With Quote
Rumorville: 2011 Nissan GT-R with More Power and New Aero Kit AVANTI R5 Non-Subaru News & Rumors 12 05-12-2009 03:42 PM
Edmunds test the Nissan GT-R DocDetroit News & Rumors 6 12-19-2007 10:10 PM
negate drivetrain loss on dyno Beanboy General Community 1 12-10-2004 07:45 PM
Gtech vs Dyno and drivetrain losses SubaruStu General Community 16 11-08-2001 11:15 AM
Dyno tested the BPM GT setup today. Rexy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 06-03-2001 07:55 PM
