Old 12-30-2008, 06:54 PM   #1
96GreenLX
Member#: 60073
1996 Impreza LX
Green
Default Broke a part off the sprocket, is it shot? PLEASE HELP!
Well I tried pulling the crankshaft sprocket off using one of those knobs (by knobs I mean like the part where there is a line that should be pointing to the top for TDC) and one of them broke off. What I am wondering is, is this part needed? My guess is it's used for the the timing sensor located right above where currently my timing mark for TDC is under is this right? I'd hate to buy another part if not needed but I don't want to put the car back together to find out it wouldn't run. Please help, thanks.
96GreenLX is offline   Reply With Quote
Old 12-30-2008, 09:39 PM   #2
mikeythejew
Member#: 141672
A good picture would be very helpful.
mikeythejew is offline   Reply With Quote
Old 12-30-2008, 11:31 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
assume it is shot if it is damaged
Old 12-31-2008, 02:35 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
i'm assuming you mean the timing belt sprocket that runs on the crank? it should have....3 tabs or so coming out. Those are for the crankshaft position sensor. If you broke one off, then yes, you'll need a new one. Pics would be nice so we can confirm just what the hell you're talking about.
Old 12-31-2008, 05:29 PM   #5
96GreenLX
Member#: 60073
1996 Impreza LX
Green
I was pretty sure they were for that sensor. Sorry about the delay in the picture been at work and no camera. The yellow arrow points at the area where the one tab broke off and the red is pointing at what broke off. I know the pictures out of focus but it's a tight squeeze with the radiator and dark garage. Oh plus there are more than three of these, let me know thanks guys.
Old 12-31-2008, 05:51 PM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
yup, replace it.
Old 12-31-2008, 06:11 PM   #7
96GreenLX
Member#: 60073
1996 Impreza LX
Green
Is 50 bux a good deal on a used one? Also the yard want 60 for the crankshaft pulley is that good? Best I can find on the pulley as Advance wanted 281 and my Subaru dealership wanted 150 however those are new, but it surprised me that the Subaru dealership was cheaper!
Thanks again!
Old 01-01-2009, 04:51 AM   #8
avk
Member#: 17252
'06 WX8
59E
I looked up those parts in the catalog at the nearest local "wholesale to the public" dealer, fredbeansparts.com. The sprocket is 23.39 and the pulley is 107.96. You also need a key and, preferably, a new bolt.
avk is offline   Reply With Quote
Old 01-01-2009, 08:46 PM   #9
96GreenLX
Member#: 60073
1996 Impreza LX
Green
Those are great deals! Thanks, I bought a new key because the old one bent and is the reason I'm messing with the sprocket. Working on trying to get the sprocket off I've come to realize the sprocket was shot anyway as when the key bent the sprocket took damage and probably the reason I can't get it off, did manage to get the key out though and the sprocket to be flush with the crankshaft. Plan on cutting the sprocket where the key was to see if that will make it come off the crank. Thanks for the heads up on the fredbeansparts though!
Broke a stud off the uppipe...problems? F3nom3ni Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-10-2005 10:57 PM
brakes shot! please help decide! urbanachiever Brakes, Steering & Suspension 14 01-21-2005 04:58 PM
XT gears in 02 WRX gearbox, is it possible? Please help! skiblur Transmission (AT/MT) & Driveline 11 11-22-2004 02:27 PM
L Motor... shot?! Please help Turbo GC4 Normally Aspirated Powertrain 4 03-05-2003 01:11 AM
$1000 for a buncha parts off the old car - should I do it? Patrick Olsen New England Impreza Club Forum -- NESIC 11 12-30-2000 07:36 AM
