Old 12-30-2008, 09:54 PM   #1
weston666
Member#: 198759
Default Engine Misfiring and backfiring when i push the gas pedal more than half way
2003 Subaru baja 100k miles on it.
The car will run perfect under hard acceleration untill I drive it for about 5 minutes, then when i give it more than Half throttle it will start to stutter, backfire and miss on Cylinder 3, I have tested the spark plug wires, looked at the spark plugs, installed new fuel filter, and put in a new throttle body with the 3 sensors, As to no avail. I was also thinking maybe it has a bad fuel injector, but that wouldnt explain why it runs perfect when its cold. Has anyone had these same problems? thanks.
weston666 is offline   Reply With Quote
Old 12-30-2008, 11:15 PM   #2
weston666
Member#: 198759
anyone? I also replaced the coil.
Old 12-30-2008, 11:34 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
so...it is fine until the car warms up???
coolant temp sensor may be bad
Old 12-31-2008, 01:00 AM   #4
weston666
Member#: 198759
i think its something more than just that....im thinking a bad fuel injector?>
Old 12-31-2008, 01:07 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
Old 12-31-2008, 01:10 PM   #6
rick-l
Member#: 33868
2003 wrx
srp
Are there any other codes besides misfire cyl. #3?
This should be low on your list of possible causes but I had an old Audi that kind of acted like this when the timing belt was off by 3 teeth. It did not run perfect until warm however.
rick-l is offline   Reply With Quote
Old 12-31-2008, 02:33 PM   #7
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
explain to me how a fuel injector will affect how the engine runs when cold, but not when hot.
Old 01-01-2009, 09:44 PM   #8
DutchSub99
Member#: 99800
1999 GTT Impreza
Dark mica blue
I would also relate it to the fuel injector...
If let's say the injector for cylinder 3 is not functioning properly and provides a lean fuel mixture you could get detonation in cylinder 3 when the engine is starting to warm up.
I would seriously take it easy to save the engine in any case now!
Better not to run it at all!!
You can have your injector cleaned by a specialist. (ultrasonic cleansing)
It may be worth to do that before you buy a new one, but first make sure the injector is the actual problem.
Other possibilities:
Blocked fuel line
Petrol pump
etc.
Good luck with it anyway!
Patrick.
ps. Why accelerate hard when the engine is cold?
DutchSub99 is offline   Reply With Quote
Old 01-03-2009, 10:44 PM   #9
joey00
Member#: 199119
Ok, lets start from scratch here.
- You've verified the misfire on cylinder 3 through a MIL and/or misfire counter
- usually before replacing anything, you can claim a faulty part by on a cylinder by switching. If you know cylinder 1,2,4 are working good
- start by switch spark plugs, with say..cylinder 1, does the misfire occur on cylinder 1 now? if so replace spark plug and set proper gap.
- use the same method with your coil and fuel injector, does the problem move cylinders?
- fuel filter and throttle probably not the issue, something like that would effect all cylinders
- this is the most cost effective way to diagnose misfire problems
- once you have the simple things covered you can move up
- check valve lash, insufficient lash? once engine is warm valve not seating?
- possible burnt valve, check engine vacuum at idle, leak down test etc
- start simple move on. that's all you can do.
joey00 is offline   Reply With Quote
Why are more than half the cars on Autotrader already sold? delongedoug Off-Topic 28 08-13-2009 06:51 PM
More Than Half of the Automotive Supply Base Could Go Bankrupt in 2009; at Least 1 Mi AVANTI R5 Non-Subaru News & Rumors 0 03-20-2009 11:57 AM
Car starts when I engage the clutch pedal a certain way 05EJ25 Service & Maintenance 7 11-17-2006 04:47 PM
Whats the exhaust popping sound when you release the gas pedal? samwY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-07-2004 01:49 PM
strange sound when I push the brake pedal aek Brakes, Steering & Suspension 1 06-14-2002 05:50 PM
