Old 12-31-2008, 08:16 AM   #1
xrw1
Member#: 159772
06 WRX
obp
Default Replacing One Tire (clarification)
Hi everyone,
Just before people start telling me to use the search button, I did. I just need a clarification. Recently I had a nail through the sidewall of my RE92 and don't really have the funds to buy a new set. I picked up a used set of RE92 yesterday and the difference from the used set to my set is around 1 mm in tire depth. I also measured the rolling circumference of it and it is less than 1/4 inch.
What i need clarified is does that rule of less than 1/4 rolling circumference mean the difference between the front to back set of tires. Or does it mean to any tire.
Also would mounting this tire to the front be better or to the back?
Thank you very much.
xrw1 is offline   Reply With Quote
Old 12-31-2008, 09:10 AM   #2
Zottyzot
Member#: 62150
2007 WRX wagon
UGM
Wait...did you pick up 4 matching used tires? If so, your best move would be putting all four on. I dont think a 1mm difference is going to destroy your diff, but it will cause more wear than normal.
Zottyzot is offline   Reply With Quote
Old 12-31-2008, 09:47 AM   #3
Tire Rack Moderator
Member#: 1215
ext. 4362
1mm tread depth difference would have zero effect front to rear or side to side
replacing one tire... uathatis Tire & Wheel 17 12-18-2015 01:05 PM
Replace one tire or all four? less than 10k miles chris_photo Tire & Wheel 6 03-19-2009 10:36 PM
replacing one tire? vinithing Tire & Wheel 13 04-06-2007 03:47 PM
got a lfat, is it safe to replace one tire? chrismindless Tire & Wheel 3 10-10-2005 11:35 PM
Replacing one tire? Gilla-Machster Tire & Wheel 0 04-07-2005 06:52 PM
