#1 |
Member#: 132130
TXIC
Vehicle:2002 Ford F-150 Graphite Gray |
Who's going fast with a TMIC these days? I remember a year or two ago AMS or maybe itwas P&L? idk..someone in the midwest in illinois had a fpgreeen sti that ran an 11.1 with a TMIC.
has anyone ran 10's with one?
#2 |
Member#: 74793
Vehicle:02 WRX BLAZE YELLOW |
Im sure it can be done. 10s with a topmount. Just keep it really cool until you make a pass.
#3 |
Member#: 148681
Vehicle:2007 0-60 in $65,000 SOLD!!SOLD!!SOLD!!SOLD!! |
The AMS car made like 489WHP/512WTQ on C16 at the shootout that looks like 11.81 124MPH your not going to pull an 11.01 with a 2.09 60'
http://www.youtube.com/watch?v=N5znb_pUfc4 I'm going to run my Spearco TMIC 30R on Q16 map this coming year at the 2009 Midwest Shootout. Should be right around 480WHP @ 29psi in that April weather. I'll more than likely add METH to the TMIC after that and then play around and run the METH TMIC/30R combo in the 2010 Shootout. After that I will more than likely go with FMIC and 35R. I do not recall anyone running an 11.1 on an FPgreen at the shootout. Eddie & Paul both had FMIC one 30R on 35R there. the final shakedown run on that was Eddie 11.3 with 1.6 60' I do not have the tires to make 10's but I am sure as hell going to get into the low 11's this year. I only run the 1/4 at the shootout. Last edited by 4ST-AIR; 12-31-2008 at 04:26 PM. |
#4 |
Member#: 143264
RMIC
Vehicle:2006 WRX TR Obsidian Black Pearl |
I am on a Dom III and an APS TMIC. At 4500~ ft above sea level my car is quite capable of high 11's. I am in the process of doing a Aquamist Meth/Water setup, so 11's at this altitude should still be pretty dummy proof.
If you want pretty easy 10's, do a 35R and a FMIC. Otherwise you will need to strip weight out of the car and run very aggressive. |
#5 |
Member#: 162942
Vehicle:2006 STi Black&Gold Stage 2 |
I'm sure if I took off my hood, ran a custom HUGE TMIC along with a HUGE Turbo I could run 9's. lol
#6 |
Member#: 30367
South East
Vehicle:2005 Legacy GT NASA SE PTB Champ |
does air to water count?
#7 |
Member#: 167027
Vehicle:02 WRX Sedan WRB |
On that video it looks like the track slopes down?
#8 |
Member#: 60142
Vehicle:2011 WRX Grey |
Pretty easy is not a term I'd use - "possible", yes, but not "pretty easy." True 10's at full weight are very rare on this board, regardless of mods. A sub-11 second pass is flat cookin', and it takes a talented driver along with beaucoup, real horsepower, not a dyno queen. I've seen way too many "big power" GT35R timeslips in the high 11's/low 12's to think otherwise.
#9 |
Member#: 146554
Vehicle:2004 STi WRB 30R |
it can be done
#10 | |
Member#: 156955
SWIC
Vehicle:2006 STI UR GT35R w/ mad bolt ons |
#11 |
Member#: 139385
same could be said about 13 second stage 2 stis. 2 people on this forum have run 11s, so 13s should never happen
I think I have seen threads with 35r cars only running like 16 psi for fear of breaking something, not enough injector, or whatever the reason, at 16 psi on pump its not gonna be very quick. there are not a ton of good drivers on this forum that own the higher HP cars |
#12 |
Member#: 122306
South East
Vehicle:2002 Sti PTE 6262sp Interlagos Blue 551/441 |
I have 4 months to play with my car before pinks all out is here local again in april. I'm going to run a Top mount. right now Im thinking e85, or c16 plus meth dom4 or 35r maybe a 4088 wanting at least A 10.5. and I wanted to try that at full weight full interior ect. but anything faster than a 11.99 requires a 6 point cage, faster than a 10.99 requires full crash cage. that Im not wanting to do with my daily driver. so I think my 99sportwagon has just been sacrificed to be a full track whore.
#13 |
Member#: 148681
It drops off after the 1320 pretty drastically. They said its pretty level until then. Its in Byron, IL the great thing is there are no BS cage rules only helmet. So that way no ones getting booted during the Shootout and its just an all day event.
#14 | |
Member#: 132130
TXIC
![]() i asked who was going fast with a tmic, not how to get 10's |
#15 | |
Member#: 132130
TXIC
#16 | |
Member#: 159776
South East
Vehicle:2005 Sti OBP |
#17 | |
Member#: 117862
E. Canada
Vehicle:2006 STi 10.85@129.4 96 impreza 9.55e.t.146mph |
Just a correction on that one there IHRA and NHRA require a 4 point cage with a drivers door bar under 11.49 and a 6 point cage under 9.99 11.5 or slower your good without one |
#18 |
Member#: 159682
NESIC
Vehicle:1995 WRX |
#19 | |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
must have come about when people had only gone as far as the mississippi or something like that....cause nowdays it makes absolutely no sense. anyway.....back on topic.....i dont see why it would be impossible.....i mean the spearco is a 1000cfm intercooler, which is a higher flow rating than many of the fmic's people use. especially if its used in conjunction with meth or c16 then it should really be possible. but staying tmic with turbos that flow enough to make a 10 second pass just isnt common. I think there are only 3-4 people in the world in the 10's with a gt30......so we're basically looking for someone with a rotated gt35 or larger thats still running a tmic or someone with a stock location gt35 or FP Red thats got a crap load of weight reduction. People have gone 10's on stock location turbos so again its probably possible, but i think you'll be hard pressed to even find a car thats setup in one of the ways i listed. Last edited by Phatron; 01-02-2009 at 02:03 PM. |
#20 |
Member#: 146554
well put^
| Thread Tools | |
| Display Modes | |
| FS : STI TMIC, STI CBE, Bosal DP... | goob_os101 | MAIC Private Classifieds | 21 | 09-30-2010 10:08 AM |
| FS : 2008 Sti Tmic, 08+ Wrx/sti Aem Cai | graphite | Engine/Power/Exhaust | 15 | 07-04-2010 04:23 PM |
| FS : FS: Zoom H4n handy recorder | Strobe Media | Non-Subaru Stuff | 1 | 06-04-2010 12:51 PM |
| Name some great records made from records | Fach | Off-Topic | 12 | 02-25-2005 03:21 PM |
| Friday night random Recordings= Fun with MS Sound Recorder | The_Triton | Off-Topic | 6 | 02-05-2005 12:11 AM |
