Old 12-31-2008, 01:33 PM   #1
Matt4545
Member#: 193752
1999 Legacy 2.5gt
Default reccomend me a cold air intake?
I cant seem to find a cold air intake for my '99 subaru legacy 2.5gt. its got the NA 2.5l engine. ive searched the vendors, ebay, and google and cant find any that would fit my car?? are they not made? if anyone could point me in the right direction that would be great! thanks.
Matt4545 is offline   Reply With Quote
Old 12-31-2008, 01:35 PM   #2
litebrite2001
Member#: 41656
2002 WRX Wagon
Not the answer to your question, but you'd probably have better results with a drop-in panel filter.
litebrite2001 is offline   Reply With Quote
Old 12-31-2008, 01:37 PM   #3
Matt4545
Member#: 193752
1999 Legacy 2.5gt
ok, could you point me in the direction to those? would that just be a replacement filter to the one that's in there already?
i don't know a lot about Subaru's at all, im trying to learn. thanks for help
Old 12-31-2008, 01:42 PM   #4
cmiovino
Member#: 134005
2004 WRX Premium
High flow drop in + hybrid piping FTW.
Old 12-31-2008, 01:42 PM   #5
Uncanny
Member#: 133012
2011 WRX
Obsidian Black Pearl
from every bit of information i have seen, the best intake out there is the "hybrid" style that was first thought up by Willaty. Its basically retaining your stock resonator in the fender and airbox, while replacing the torque box and maf to throttle body piping. Its generally made from an ebay short ram intake and can be done for about 40 bucks.
Theres a thread on it stickied on the top of the NA forum.
Uncanny is offline   Reply With Quote
Old 12-31-2008, 01:47 PM   #6
Matt4545
Member#: 193752
1999 Legacy 2.5gt
thanks for pointing out that sticky it helps alot! if anyone else has any suggestions im still interested
Old 12-31-2008, 04:00 PM   #7
str8 h8n
Member#: 187766
2008 2.5i hatchback
dark grey metallic
do what i did, and read all of the FAQ's and threads of note first. Lots of good info in there for sure. especially if you're trying to learn and get up to speed with this stuff
str8 h8n is offline   Reply With Quote
Old 01-01-2009, 09:45 AM   #8
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
before you spend the time, $ and cut up a SRI for the hybrid, make sure that your 99 is MAF based and not MAP based. The MAP based systems dont have the problem that is solved by the hybrid intake from what i understand, so a straight SRI/CAI would work well if you dont mind the noise.
RaceFaceXC is offline   Reply With Quote
Old 01-01-2009, 05:46 PM   #9
Matt4545
Member#: 193752
1999 Legacy 2.5gt
yeah mine is MAF based because i have the sensor going into the stock airbox just like in the picture in the sticky
Old 01-01-2009, 07:45 PM   #10
Zac86
Member#: 136919
2005 Legacy GT Wagon
ABP
Yes go with williatys hybrid intake, I did it and I love it.
Zac86 is offline   Reply With Quote
Old 01-02-2009, 12:30 PM   #11
Matt4545
Member#: 193752
1999 Legacy 2.5gt
can anyone give me a link to the short ram that williatys used? i cant find one that looks just like it on ebay
nevermind, i found one for $38.21 !!!
Old 01-02-2009, 10:11 PM   #12
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
Injen CAI. I have an Ebay intake on the 07, am now switching to the Injen.
Explain:
The ebay intake worked beautifully except I hear sound of air turbulence at high engine speeds.
This is probably happens at joins of tubes that are of different diameter (The ebay intake is 3",
the MAF housing is 2.5 I think, and the throttle body is 2.75").
Injen has a built in place for MAF sensor to sit. It is of a single diameter to facilitate a fast and smooth airflow.
Jerry Xu is offline   Reply With Quote
Old 01-03-2009, 10:37 AM   #13
V8Slayer
Member#: 111565
1999 Legacy 2.5GT
Boosted & meth injection!
OBX is another CAI you could try. Its the same as the Injen CAI and should only cost you maybe $50. I've been running one for almost 2 years now and have had no problems.
You want to look for an intake that fits a MY98 2.5RS, it will fit perfectly. Not too many(if any)companies marketed an intake for our generation of Legacy but thankfully there are quite a few options around for the phase 1 2.5L Impreza which we are able to use.
V8Slayer is offline   Reply With Quote
Old 01-03-2009, 05:18 PM   #14
Jerry Xu
Member#: 36629
07 2.5i
With OBX he still has to use the 2.5" MAF housing came with his MAF car.
Old 01-03-2009, 10:52 PM   #15
subiepntbllr
Member#: 189899
07 impreza 2.5i
NBP
Explain:
thats what i got. it seems to work pretty good
subiepntbllr is offline   Reply With Quote
WTB: 02/03 WRX stock air intake or trade for Injen cold air intake limpstick VIC Private Classifieds 17 02-16-2007 01:46 AM
A civic made fun of me for no cold air intake ChiefontheDitty Off-Topic 57 07-05-2006 05:36 PM
Opinions on cold-air intake or no cold-air? gldenchld Tri-State Area Forum 7 11-06-2002 07:55 PM
ram air intake vs cold air intake Shaji Factory 2.0L Turbo Powertrain 62 07-21-2002 09:05 PM
AEM cold air intake or Injen cold air intake? energy57 Factory 2.0L Turbo Powertrain 31 05-20-2002 12:27 AM
Message Board Statistics All times are GMT -4. The time now is 04:42 AM.
