Old 01-13-2009, 10:10 PM   #26
DumbUglyDragon
Member#: 61077
1993 WRX
Originally Posted by DRKRYD View Post
Nice numbers...! But im here to help...a lil. I have a close setup to yours as in i have a 95 v2 wrx motor w/td05. Now i also have a Z4 ecu, and my boost peak is the same as yours somewhere in the region of 16.5-18 psi. So use that info if ya need it for reference. Setup in installed in a 2000 coupe. and im keeping and eye on this to see what kind of gains come out once your fully tuned and dialed in.
Hmm... I'll have to toss my Z4 back in and have a look.
DumbUglyDragon is offline   Reply With Quote
Old 01-25-2009, 01:39 PM   #27
DRKRYD
Member#: 83482
2000 jdm V2 WRX
blue ridge pearl
Default Hmm..
Originally Posted by blkgm8 View Post
Is your Z4 chipped?
I dont think so but i have yet to crack it...doesnt look like it has been taken apart before. How would i know if it was....physical chip or just programmed?
DRKRYD is offline   Reply With Quote
Old 02-05-2009, 02:08 PM   #28
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
The z4 is not a flash programmable ecu... unless modified with an add on daughterboard( rare back in the day scoobyecu). It will have a removable chip(eprom) in it if it has been chipped. If not you will just have the factory board with outline where the chip would go.
blkgm8 is offline   Reply With Quote
Old 02-08-2009, 10:56 AM   #29
DRKRYD
Member#: 83482
2000 jdm V2 WRX
blue ridge pearl
Cool i'm gonna pull it today and post my findings.
Old 02-10-2009, 08:43 PM   #30
DRKRYD
Member#: 83482
2000 jdm V2 WRX
blue ridge pearl
Default nothing to report
Findings: No chip...booooo
Nice and clean ecu yay!
Any recommendations for chips? Is it even worth the bother.
Old 02-11-2009, 01:31 AM   #31
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
There are a few options... but none really with support here in the US. I would pm ROB. It seems he has perfected a nice and safe chip setup which will bring you to 16psi and get you a good kick in the pants. I would definitely try one of his chips out if I weren't going big turbo.
Old 02-11-2009, 04:54 PM   #32
DRKRYD
Member#: 83482
2000 jdm V2 WRX
blue ridge pearl
Nice and safe to 16 p.s.i is what im running now...im spiking at 17-18.5 but usually run solid at 15-16 in that range.
Must be something else done somewhere i guess.
And a lil update, I'm now not 100% sure that my motor is a V2 Wrx. I have concluded that it is closed deck and with the many helpful threads on that. As well confirmed that turbo is td05h. So maybe thats where the extra power is coming. And i do not have any information as for block identification except for the numbers stamped on it. Front serial number is 23212 located next to ej20 emblem where block joins, and rear of block on drivers side reads 140318. I do have the black slanty intercooler though, which shows wrx. But the only thing that is throwing me off is the numbers under the oil cap, 94 8 so translate to august 94, weird cant find any info on motors with build dates that line up. Nice little power plant though. going to try to see if the sticker is still on the back of the head, crosses fingers.
Old 02-11-2009, 07:32 PM   #33
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Can you take a picture of the inside of your ecu. I have the exact engine... turbo... and ecu as you and it is not set from the factory at that boost. It should hit around 14.5 then taper off to 12 or so.
I also wouldnt say you are hitting a nice and safe boost level since the jdm z4 ecu runs alot of timing and is tuned very aggressively for us since the 100ron in japan is equivalent to 95-96 octane over here. Also the black slanty ic is extremely small for such a tune. Most chips focus on a safer tune at 16psi for our premium unleaded gas.
I want to see the inside of your ecu because it may be modified differently than chipped and would explain why yours is not functioning as factory.
Old 02-11-2009, 08:10 PM   #34
DRKRYD
Member#: 83482
2000 jdm V2 WRX
blue ridge pearl
Default Z4 ecu pics!
[IMG][/IMG]
[IMG][/IMG]
there let me know if ya see anything. And how are you sure we have exact same motor? I don't even know for sure what i have....lol.
Old 02-11-2009, 09:02 PM   #35
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
That looks pretty stock to me. Does your car have any added on electronics.. such as fcd or mbc?
I know we have the same motor because you stated that you have a V2 WRX, closed deck, tdo5 16g with z4 ecu ... right? Same Here.
Mine used to have the black slanty as well... I now have front mount. The only difference with mine is the options as mine is V-Limited, which gives different tranny *close ratio gearbox, abs, different seats and some exterior mods...and a few other bits not standard on the wrx, The actual motor IS the same.
Old 02-12-2009, 07:54 PM   #36
DRKRYD
Member#: 83482
2000 jdm V2 WRX
blue ridge pearl
Default Hmmm....
I said i thought it was a V2 but was the V2 built in august of 04???? because thats the date under my oil cap. Not that its sufficient enough to prove the year, turbo is td05h, which from another thread i seen came on the v1 sti.
So really i dont know if we have the same motor, most likely, I do not currently have any pics of my motor but can be taken during the day. If you have any post it on here and ill try to compare.
Old 02-12-2009, 10:06 PM   #37
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
V2 started in went from 94 to 96, but it still wouldn't matter... the closed deck is usually found on V1 and is very rare for a V2 car... it is the same motor though.
Old 02-12-2009, 10:10 PM   #38
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Still looking for that plate information with applied model and engine code.
Old 02-13-2009, 09:04 AM   #39
DRKRYD
Member#: 83482
2000 jdm V2 WRX
blue ridge pearl
Default No dice!
I have no history beyond what is currently sitting in my car, they did not have the vin plate im the third person to have this motor and the other two can't shed any light, but happy enough for being closed deck.
Old 02-13-2009, 09:32 AM   #40
Matt Monson
Member#: 832
99 2.5RS, '85 911
That wasn't directed at you.
Old 02-13-2009, 05:51 PM   #41
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Matt... I will get that for you in a day or so. I need to take some more pictures of the car anyway.
What did you gather from the other guy on here with the V-limited? Any useful information?
Old 02-13-2009, 06:35 PM   #42
Matt Monson
Member#: 832
99 2.5RS, '85 911
He never got the info to me. Though your post above got me even more curious. The one here in Colorado that I worked on has the 6K STi ECU. You're sure yours is a Z4?
Old 02-13-2009, 07:57 PM   #43
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
matt when your doing my trans, you can look at my ecu if you want, its a z4
JDMFLCL is offline   Reply With Quote
Old 02-13-2009, 08:41 PM   #44
Matt Monson
Member#: 832
99 2.5RS, '85 911
Is your swap a V-Limited?
Old 02-13-2009, 09:03 PM   #45
JDMFLCL
Member#: 180513
Baby Baby C'mon!
oops nm didnt read in depth enough
Old 02-13-2009, 10:03 PM   #46
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Matt you know there were two versions of the V-limited: WRX V-Limited and the WRX RA-STi VerII V-Limited.
It would make sense that the WRX VL came with a Z4 ECU as it was mechanically the same as the 95 WRX sedan.
-Rob
rob is offline   Reply With Quote
Old 02-14-2009, 12:08 AM   #47
suberdave
Member#: 101865
88 GL-10 STi
is there any good way to tell if the engine came from a V-Limited?
according to the Kenandcaterina (SP) websight my clip that i bought was a WRX V-Limited also... it had the Z4 ECU with TDO5h but it is open deck block, and came with the same trans as the V2 STI and 555 car.
any more info?
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 02-14-2009, 02:52 AM   #48
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
any more info?
-=Suberdave=-
Also if you have the whole car... or the clip, it is supposedly the only one with abs. TY752VB4AA is the transmission code on my car.... the gears are pretty close when driving. My ecu is z4
Old 02-14-2009, 11:36 AM   #49
suberdave
Member#: 101865
88 GL-10 STi
[quote=blkgm8;25586575]Also if you have the whole car... or the clip, it is supposedly the only one with abs. TY752VB4AA is the transmission code on my car.... the gears are pretty close when driving. My ecu is z4[quote]
yep same trans code as mine, engine code is EJ20GDW5HE. but my car did not come with ABS.
according to http://www.catherineandken.co.uk/sti/wrx.html this engine only came in the V-Limited and the Vir-2 STI. now i now this webpage dose not know everything. but that is all we have.
-=Suberdave=-
www.suberdave=-
Old 02-14-2009, 11:47 AM   #50
Matt Monson
Member#: 832
99 2.5RS, '85 911
Ken and Catherine contains a lot of errors. The "5" in the DW5HE just means it was the 5th year of production. But the GC8C48D chassis code contains a "4" in the corresponding position. There's a lot of inconsistencies like that on their site. They've got 1994 cars listed as 5th year of production and then proceed to list 1995 cars as 4th year of production. And they've even got 1996 cars listed at 4th year of production chassis. This is part of why I am always asking people for vin plates. I want to see what Subaru says, not what Ken and Catherine say.
Furthermore, STi's have a "P" in the 9th position of the applied engine code. They've got a bunch of cars they are calling "STi" that don't have that, and they were definitely wrong in that department on my v1 STi wagon, which had a totally different applied engine code than they said it should.
mustang dyno #'s to dynojet #'s team trucha racing Proven Power Bragging 15 01-09-2008 02:11 PM
what kind of dyno #'s are people putting down with a 16g?? Berts_Wrx Proven Power Bragging 3 10-03-2007 02:57 PM
Accesport Dyno #'s on a 06 STOCK STI!-By Gadiel - Great #'s diplo12 Proven Power Bragging 12 01-10-2007 09:56 PM
What are your dyno #'s with one hi flow cat? SupaSizeFries Proven Power Bragging 16 04-05-2004 02:50 PM
