#1 |
Member#: 44256
Vehicle:2002 WRX Wagon |
All Im finding are generic piston rings that say they are good for every 2.2 subaru made....
Anyone know where to find a good set of stock size piston rings? Should I go oem? Anyone have the ring gap specs from subaru for stock size pistons?
#2 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
I have successfully used the NPR (nippon piston ring) rings for the NA pistons many times in turbo pistons.
#3 |
Member#: 44256
what are you using for gaps? Im assuming they dont come pregapped?
And, why use the npr over oem? You think there are any notable differences between the two? |
#4 |
Member#: 64673
NWIC
No difference, just alot cheaper.
Gapped to spec. |
#5 |
Member#: 44256
thanks for the help doug, and happy new year!!!
#6 |
Member#: 25731
Vehicle:02 wrx(sold)/2005 Sti/ 93 Leg Wag |
I'd like to bring this thread back to ask one question, normally the NPR rings I've used in the past were all gray (steel), the most recent pack that I received had a gold/copper color for the top ring.....I'm wondering if this is going to be a problem with durability or heat regarding FI?
#7 |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
Probably just some sort of color they add to make it look good. I doubt they would change the material unless they had several expensive complaints. Maybe its a break-in coating or something, cant tell you.
~Josh~ |
| Thread Tools | |
| Display Modes | |
| new rings on stock pistons | zblad | Built Motor Discussion | 1 | 01-30-2010 11:24 AM |
| rings for os2 piston for ej20 | supernick77 | Private 'Wanted' Classifieds | 1 | 06-03-2009 05:24 PM |
| rings for os2 piston? | supernick77 | Factory 2.0L Turbo Powertrain | 0 | 05-18-2009 03:45 PM |
| Amr Tmic And Brand New Ej257 Pistons+rings For Sale Florida | greend02wrx | Engine/Power/Exhaust | 1 | 10-15-2008 11:54 AM |
| WTB: EJ22T Block for stock Pistons | nativo | Private 'Wanted' Classifieds | 0 | 06-16-2004 08:39 PM |
