Old 01-01-2009, 12:46 PM   #1
chad1043
Member#: 105818
2006 Impreza WRX TR
WR Blue...
Default 2006 WRX TR Tire Size Suggestions?
I'm looking at getting some new tires soon, just wondering what my best option is? Basically I was wondering what width people would go with. I live in Michigan.
Thanks,
Chad
chad1043 is offline   Reply With Quote
Old 01-01-2009, 01:58 PM   #2
blitzmr2
Member#: 101396
2006 WRX
Grip Grey
Good question. I believe the wheel is a silly-narrow 6", so much wider than the OEM 205s may not work well. I am dreading springing the dough for a new set of wheels just because of their width. Personally I'd at least like 225s.
Lots of good tires out there--Azenis, Advans, various Toyos. Depends on your budget, and if you want all-weather peformance (which it seems you to, living in Michigan, and owning a WRX to begin with).
blitzmr2 is offline   Reply With Quote
Old 01-01-2009, 02:07 PM   #3
BLAKOHFOREX
Member#: 198099
2004 WRX
JBP
What is your current wheel set up? Size?
BLAKOHFOREX is offline   Reply With Quote
Old 01-01-2009, 02:51 PM   #4
chad1043
Member#: 105818
2006 Impreza WRX TR
WR Blue...
Stock, 215/45ZR17... Any other suggestions?
Old 01-01-2009, 05:12 PM   #5
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Thanks,
Chad
225/45 is the biggest you can reasonably go on the stock 06 wheel
id stay with the 215/45 and buy some 17x8 wheels and go from there
Old 01-01-2009, 05:13 PM   #6
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
you believe wrong
dont post unless you KNOW
this will alleviate a great deal of unnecessary confusion here
Old 01-01-2009, 07:14 PM   #7
Big-E
Member#: 123843
2006 SGM WRX S2
Let LED's light your way!
The stock 2006/2007 WRX wheel is 17" x 7" et55, 5x100mm bolt pattern.
You can put a 225/45-17 tire onto the stock wheel.
A 225mm wide tire is generally recommended for wheels that are from 7" wide to 8.5" wide.
If one chooses to mount a 235mm wide tire onto a wheel then the minimum recommended width of the wheel would necessarily be 7.5".
Old 01-01-2009, 08:40 PM   #8
snovvbrdr
Member#: 121063
2006 WRX Stg. II
Steel Gray
Default 4 sets
I have four sets of wheels stockies with the factory tires 215/45r17 re-92's some 16's with 205/55r16 snows and two sets of 17X8's one with 225/45r17 bridgestone re-01r's and the other set is 245/40r17 toyo r1r's
snovvbrdr is offline   Reply With Quote
Old 05-17-2009, 02:09 PM   #9
blitzmr2
Member#: 101396
2006 WRX
Grip Grey
Originally Posted by Uncle Scotty View Post
you believe wrong
The thus "I believe" statement, not as fact. Yes I was wrong. Yes if the only replies that ever were made were 100% certain, zero-chance-of-error facts, forums would be better sources of information, but good luck with that. Discussion is part of the learning process for all. Go bother people that parade their opinions as fact. Had I the time to go find every time you've ever been wrong on a post, and replied with "keep your mouth closed unless you KNOW" I'd enjoy that very much, but I digress.
Anyhow, on my MR2 I actually ran 235s on a wheel that came with 205 stock, but that was very tight. I'd look at your goals and motivation for going wider, and unless you've got money burning a hole in your pocket, consider trying 225s and seeing if they suit your needs.
Old 05-17-2009, 02:12 PM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
just shut it and keep going
2004 WRX STI Spare Tire and 2006 WRX TR Spare Tire! 06TRDude Wheels/Tires 4 09-17-2008 01:28 AM
Stock 2006 WRX TR Rims and Tires and other things gsloppypop Wheels/Tires 4 08-17-2007 11:20 PM
stock tires and wheels from 2006 WRX TR for sale!!! calvinnguyen NWIC Private Classifieds 8 06-19-2006 06:02 PM
WTB 2006 Wrx TR rims and tires bstarr Private 'Wanted' Classifieds 4 04-28-2006 02:50 PM
What are the 2006 WRX TR speaker sizes? AutoBahn Car Audio, Video & Security 3 04-23-2006 11:36 PM
Message Board Statistics All times are GMT -4. The time now is 07:55 PM.
