Old 01-01-2009, 03:40 PM   #1
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Default Anyone switched from MAP to MAF based controllers?
Yo guys,
Just wondering if anyone's switched from boost to MAF based and their thoughts. After doing everything cheap I'm doing some driveability mods to make the car more "driveable", things like going blowthrough (I have an FMIC so this should improve throttle response)
And I'm considering replacing my SMC controller with something like the Labonte unit http://www.labontemotorsports.com/st...ow/VC-MAF.html
Now, theoretically alky/WI should be based on airflow, and boost isn't a completely accurate representation of airflow, so theoretically the injection should be more accurate tapping the MAF signal. My question is if you have done this, did you notice positive effects? Think it's worth it for me to do?
Thanks
Ambert
verc is offline   Reply With Quote
Old 01-01-2009, 06:06 PM   #2
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
You may be interested in our map/maf controller. Incase you are not aware I will link you to it. It can inject based on just boost, or just MAF or it can inject based on boost using MAF as a threshold, or it can inject based on MAF using boost as a threshold or lastly and most cool it can take boost and maf and inject using both signals. The last option is the most popular of the maf + boost options we have. the controller would have boost from 1-30 on the MIN and MAX, so you control that. The MAF is programmed in the controller as MIN (1 volt) Max (5 volt) you can adjust the Min and MAX MAF if you want. The default map is 50%. this means it will take the dutycyle of the boost min/max and the dutycycle of the MAF min max and average them together using a 50/50 MAP. You can change that Averaging PCT from 1 to 100%. For example if you set it to 20, it would give boost a 20% and MAF an 80%. Check it out, I am glad to help if you have questions. The averaging function is not listed on the detail, however this verion (1.06) is capable. Its the same controller as in our WRX/STI stage 2 Kits.
Using MAF and Boost you will get a much more predictable curve.
http://www.coolingmist.com/detailmai...pid=controller
Coolingmist is offline   Reply With Quote
Old 01-04-2009, 12:46 AM   #3
benw
Member#: 103320
1998 swapped
Forester L
MAF is a great way to run these injection kits. Not a lot of people do it though, because MAP triggering is easier for most people to understand and install.
My favorite is the Aquamist FIA-II module which ramps injection according to fuel injector duty. Makes for hassle-free easy tuning.
Tuning MAP/MAF is easy too, but isn't as elegant as using IDC.
benw is offline   Reply With Quote
Old 01-10-2009, 12:28 PM   #4
bucket7788
Member#: 124263
2004 WRX Wagon
RomRaider + UTEC Tuned
I have the Labonte unit that works off of the MAF. I'm very happy with it and would recommend it. I have zero issues of any kind.
Buck
bucket7788 is offline   Reply With Quote
Anyone switch from vf39 to evo3 16g? cooleys04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 107 10-17-2008 10:58 PM
has anyone ever switched from vf22 to vf34? senomar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 06-24-2004 10:40 AM
MAP to MAF conversion from UTEC??? Do it today with Xede. turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-01-2003 06:44 PM
Has anyone switched from Vishnu's Ekutek to their Xede? Juliano Engine Management & Tuning 2 03-18-2003 02:10 PM
('93-'01) Anyone switch from a Honda to WRX ??? White4drWRX Impreza Forum 29 10-23-2001 08:43 AM
