Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-01-2009, 05:14 PM   #1
zoltan
Member#: 135502
Default Destroyed a tire at 9,000 miles. Replace all 4?
My Impreza has 9,000 miles on it, and I just destroyed one of tires when it picked up a razor blade (who the hell throws a razor blade on the road?!?). I'd rather not have to replace all four tires. The remaining tires, Potenza RE92A, have 8/32 tread left. I don't know how much tread a new RE92A has. Unfortunately I don't know of any tire place which can shave down a tire.
The dealership said I can just put a new one on and not worry about it.
So, do I need to place all four, or can a just slap a new one on there?
zoltan is offline   Reply With Quote
Old 01-01-2009, 05:15 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
take this opportunity to GET RID OF THE GARBAGE RE92'S!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
DO not BUY RE92 TIRES AGAIN
Old 01-01-2009, 05:35 PM   #3
joe1
Member#: 93518
2011 Impreza WRX STI
WR Blue Mica
+eleventy billion
joe1 is offline   Reply With Quote
Old 01-01-2009, 06:02 PM   #4
JoeB820
Member#: 152224
2007 Impreza 2.5i
Urban Grey Metallic
Yea ditch the RE92's I got a good set of BFG all seasons on special at tire rack
JoeB820 is offline   Reply With Quote
Old 01-01-2009, 06:15 PM   #5
zoltan
Member#: 135502
I'm not a fan of the RE92A, but I'm not going to spend $600 right off the bat to switch them out. Sorry. I want to put some more miles on the stock tires to get a little more money out of them before I switch them out.
Old 01-01-2009, 06:23 PM   #6
penusai
Member#: 102808
1995 Built EJ207 6sp
30r ***in progress***
a good set can cost you like under $500 installed for high/ultra performance all season.
so whats the point of your question if you are not willing to spend money on a new set of tires?
well, then just replace that one obviously.
penusai is offline   Reply With Quote
Old 01-01-2009, 06:53 PM   #7
Donutz
Member#: 148803
11 WRX 4dr
96 Impreza 3.6RS (EZ36R)
exactly what i did, picked up a set of BFG Super Sports for 51 a piece (tirerack sales ftw), while the re92as would cost me 199 a piece.
Donutz is offline   Reply With Quote
Old 01-01-2009, 07:04 PM   #8
blaze9489
Member#: 173732
2004 WRX STi
Blue Ridge Pearl
Easier said than done. The tires cant have too different amounts of tread remaining or the diff will burn out. Same reason why they shouldnt be different sizes.
blaze9489 is offline   Reply With Quote
Old 01-02-2009, 12:34 AM   #9
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Default multiple choice
If you take the opportunity to do anything, getting away from all season tires would be worth considering. If you want to buy another re92 to work with the other three just have it shaved, problem solved. Of course there is no time better to stop throwing good money after bad and just get some good tires. Hope it works out.
UFOpilot is offline   Reply With Quote
Old 01-02-2009, 01:28 AM   #10
penusai
Member#: 102808
Yes, you are correct.
RE92 from Tireack if you have a 16" wheel its $195 and 17" $219
So you can buy new have it shaved, not sure on the cost to shave it.
But for another $200 you can have yourself a whole new "better" set.
Or you can buy a whole set for under $300.
Brand/type all a factor.
Then you can sell off your RE92s. There are probably some willing to buy.
Your other option is to buy a "used" tire close to same mileage which i don't really recommend.
But in the end its up to you, how much you want to spend, etc.
Old 01-04-2009, 03:20 AM   #11
subaru3169
Member#: 55252
* pullup bar *
i don't even think tirerack shaves anymore
subaru3169 is offline   Reply With Quote
Old 01-04-2009, 10:43 AM   #12
chad2.5i
Member#: 187720
2008 2.5i
hey zoltan are you still looking for tires?
i have 4 stock steel rims and tires off of a 2.5i with @10,000 miles on em let me know if you need em! i dont know where you are but im in ma!
chad2.5i is offline   Reply With Quote
Old 01-04-2009, 07:07 PM   #13
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
if the RE92's are garbage why are they so expensive?
shamrock 05 is offline   Reply With Quote
Old 01-04-2009, 07:10 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
to confuse and bemuse those who dont know
Old 01-04-2009, 07:28 PM   #15
zoltan
Member#: 135502
A new RE92A shaved and mounted was going to cost me $270, so instead I ordered four new General Altimax HP tires which will be mounted tomorrow.
The review for the Altimax HP have been great, and it looks to be THE value tire right now. Looks like Continental's takeover of General Tire has been a good thing.
FS: 4 Nokian Hakkapeliitta 5 Snow Tires ~ 1,000 miles - 205/55/16 redobs NESIC Private Classifieds 2 10-08-2009 07:54 AM
Clutch Throw-out Bearing and Plate Replaced at 25,000 Miles Rexer06 Transmission (AT/MT) & Driveline 9 02-22-2008 02:41 PM
SOCAL: Baja Turbo yokohama 225/60/16 4 used tires 9,000 miles STIwagoon Wheels/Tires 1 05-04-2007 01:18 PM
FS: IHI-VF22 Turbo, 9,000 miles. NO shaft play. Only run at 17psi njpreppy Private 'For Sale' Classifieds 2 01-29-2005 04:28 PM
1 blown tire, do I need to replace all 4? Capt Crunch Tire & Wheel 17 06-06-2004 05:23 PM
