Old 01-02-2009, 10:33 AM   #1
thr_wedge
Member#: 164270
Default CEL bad fuel injector but now good
2005 Legacy GT 5MT, original owner, 50k miles. Yellow top, side feed injectors.
I had a CEL and rough idle for the past few months. P0301. Was meaning to change the plugs anyways so swapped out the plugs, still got the code so I swapped injectors between cyl 1 and cyl 2.
I wiped off the injectors, and after much swearing finally got them back in.
Turn the car back on and it is purring like a kitten. Use a screwdriver to listen to the injectors and all are firing at the same rate. Idle is around 700 RPM at idle. Nothing rough.
Obviously they are already back in and working fine, but what is the easy way to reinstall these injectors?
thr_wedge is offline   Reply With Quote
Old 01-02-2009, 02:33 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
why would you want to reinstall them? they're working fine.
Old 01-02-2009, 02:36 PM   #3
thr_wedge
Member#: 164270
I don't want to reinstall these injectors, I want to know if there is an easier way for re-installation the next time they crap out on me. Sorry should have been more clear.
Need Help Stumped new engine/ sluggish acceleration, lean cel/ bad air/fuel ration Boxer4h Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-14-2010 05:39 PM
CEL Code Fuel Injector - Abnormal Output Saetern 'Old School' Subaru Forum 2 12-01-2008 10:58 AM
I used to pull a P420 cel... but now i pull TWO!!!??? opious Normally Aspirated Powertrain 2 02-06-2008 01:58 PM
Fuel injector replaced. Car smells like fuel. Bad? Siper2 Normally Aspirated Powertrain 5 12-21-2004 12:08 AM
bad mileage, getting worse...now a cel! Dick Fitzwell Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 09-08-2003 03:44 AM
