Old 01-02-2009, 03:14 PM   #1
WingsWestWrx
Member#: 68111
Default Problems w/ my heater
whenever i come to a stop my heater in my 03 wrx stops working and blows out cool air... it only blows out heat when im driving...
this happens when my engine is fully warmed up too...
does anyone know what the problem could be?
WingsWestWrx is offline   Reply With Quote
Old 01-02-2009, 03:59 PM   #2
SchmisterTyler
Member#: 185992
2003 WRX Impreza
World Rally Blue
this meens it is really cold outside, turn the recirculation of air mode on so it blows warm air back into your face that is already in the cabin of the car. This will cause your windows to fog up faster though.
SchmisterTyler is offline   Reply With Quote
Old 01-02-2009, 04:22 PM   #3
Will from Maine
Member#: 75152
2015 WRX STI Limited
Check your coolant level, when you are parked your rpms are lower and if you are a bit low on coolant this might reduce your heat. Mine is currently doing the same thing. A thermostat malfunction can do the same, but that would effect the temp gauge reading too.
-will
Will from Maine is offline   Reply With Quote
Old 01-02-2009, 04:27 PM   #4
durania717
Member#: 153468
Have you had your water pump replaced?
Coolant flushed?
Clogged heater core?
durania717 is offline   Reply With Quote
Old 01-02-2009, 06:27 PM   #5
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
+1 for checking coolant level. Turn on car and let coolant get warm (not HOT!) then turn on heat to high. Open radiator cap and I bet your coolant is low. Please don't do this while engine is hot or right after you've raced that civic in a school zone.
trueno16v is offline   Reply With Quote
Old 01-04-2009, 12:20 AM   #6
WingsWestWrx
Member#: 68111
thanks for the help everybody!!! it was the coolant... you saved my ass from spending my x-mas money at the stealership
So my boss stole my heater.... 1shibainu Off-Topic 26 02-28-2006 04:00 PM
Will bypassing my heater core cause my evaporator to ice up? caterpill Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-26-2005 05:49 PM
gas smells on my heater.??? veightkiller Vancouver Impreza Club Forum -- VIC 13 01-14-2005 10:56 PM
I smell gas when I turn on my heater DetroitWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 37 02-13-2004 03:11 AM
Fix my heater please it's getting cold starbuckjunkee 'Old School' Subaru Forum 4 11-09-2003 04:46 PM
