Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 01-02-2009, 05:43 PM   #1
jmika003
Member#: 53755
2000 Legacy GT LTD
Titanium Pearl
Default Bad Oxygen Sensor
Hi there,
My 2000 Legacy (2.5L) threw a CEL recently, and the code indicates a bad front oxygen sensor.
I'm wondering if there is any reason that I should replace the rear sensor at the same time? Also, to anyone who has experience changing one, am I going to need one of the sockets designed for removal/installation of oxygen sensors, or will a regular socket work?
Thanks!
Jared
jmika003 is offline   Reply With Quote
Old 01-02-2009, 07:37 PM   #2
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
just replace the one that is bad. you will need to buy a socket or wrench for the o2.
crampfan is offline   Reply With Quote
Old 01-03-2009, 01:43 AM   #3
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Mine has that code (also a '00 Legacy), every time I reset the CEL with my scantool, it comes right back on when I turn the key on...usually the car will run for a while, recognize the error, and then have the CEL illuminate.
Now that you know what it is, can you clear it (at AutoZone for free, or other shop?) and let me know if it comes right back on? This would be a great experiment for me
PS-- best prices on OE-type front O2 sensors for our cars is at SparkPlugs.com , I have used them a lot the past 5 years and they are top notch and always cheapest. They are in CA.
PS-- front O2 should just be able to remove with a 7/8 open wrench, to fit a socket on there I think you'd have to pull the cat assemblies. No fun. Be sure to unplug the sensor first, or you'll twist up the cable when removing.
JamesWilson2 is offline   Reply With Quote
Oxygen Sensor - What causes them to go bad? Carlito2002WGN Newbies & FAQs 9 04-28-2013 12:09 PM
2007 STI Front Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 0 02-13-2009 03:16 PM
oxygen sensor vs air/fuel sensor paintbing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-02-2008 02:09 PM
Could a bad oxygen sensor slow my car down? Mohammadov Newbies & FAQs 7 06-21-2008 06:40 PM
FS: Front oxygen sensor 04 WRX 02 sensor Chino Bling Engine/Power/Exhaust 4 11-21-2007 12:56 AM
