Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 01-03-2009, 12:04 PM   #1
DannyGrant
Member#: 188342
2007 STI
Default FP Green 7cm 2.5" inlet IWG
I know this is nothing to brag about.
I just wanted to see if this graph looks normal to everyone.
I know I'm going to get flamed for not having enough supporting mods.
Here's the list:
2007 STI:
COBB UP
COBB DP (catless)
SPT intake
SPT exhaust
255 L/hr pump
850cc injectors
GM Boost control solenoid
Engine Logics custom tune.
As you can see by the torque curve, I don't get thrown back in my seat until 3700 rpm. The power surge quickly ends at 4200 rpm. This was a disappointment to me because I came from the VF43 which punches you in your seat at 2500 rpm all the way through 4000 rpm.
I didn't gain much power from the Green versus the stock turbo. Just alot of perceivable power lag.
Here are my dyno charts with the EXACT same mods minus the Green:
I noticed that I'm at 17 psi at 3700 with the Green. And 17 psi at 3200 with the VF43. This was supprising to me because I bought the 7cm Green for a quicker spool than the 8cm (I don't care about top end power). This makes me cringe thinking about what the spool would be like on a 8cm.
But maybe there is something wrong with my setup. That's why I'm making this post. What do you think? Are these normal green numbers?
I'm getting the following done in a couple weeks:
APS TMIC
GTSpec GEN II unequall length header
IAG UP
TiAL 38mm External Wastegate (V-band)
Jorge IAG custom tune
My main concern is being able to move the dyno chart to the left. Hopefully I can get more punch out of it.
Anyone with FPGreen dyno charts would help alot.
Thanks!
DannyGrant is offline   Reply With Quote
Old 01-03-2009, 12:10 PM   #2
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Wow, so you gained 12whp and lost 2wtq. The spool honestly is close to where it should be. The lack of efficent cooling and only 17psi is more than likely why your numbers are suffering.
Infamous1 is offline   Reply With Quote
Old 01-03-2009, 12:32 PM   #3
DannyGrant
Member#: 188342
2007 STI
Haha, yup. And it seems worse because it is compounded by the perception of a TON of lag.
I do get to 20 psi on the Green by 3875 rpm. This quickly tapers to 17 psi which, I assume, is due to the smaller 7cm hot side. It's just so weird because even though I'm making more boost up top (17 vs 15 psi), I can't tell a difference.
Old 01-03-2009, 12:45 PM   #4
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
it doesn't look correct to my eyes. I don't understand why it wouldn't hold boost. Maybe a leak somewhere? I would do a smoke/leak test if i were you.
WRX4eva is offline   Reply With Quote
Old 01-03-2009, 12:55 PM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
My opinion is that either the car is tuned very conservative or something is not right mechanically. Even without buying all the parts you mention there is a lot left on the table as far as power and boost goes. 17 is low boost for an FP green. This turbo can run easily in the mid 20's. There is a lot that can be done with the avcs to get the car in boost sooner if that is what you are after also.
Old 01-03-2009, 02:04 PM   #6
pearljam11
Member#: 113335
13 WRB BRZ Limited
05 STi AgileTuned 320/352
Wow that really falls off. Stage II STis have about the same peak hp #s and much higher tq #s
pearljam11 is offline   Reply With Quote
Old 01-03-2009, 02:43 PM   #7
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
yeah man, those are pretty bad numbers. but the spool looks just about dead on. there is NOOOOOOOO reason why that thing cant hold 20 psi. my green holds 25 psi to red line (ewg and 8cm but still) kinda seems maybe like a bad tune possibly? i mean 12 more wheel over a vf43? come on.
first off you need more boost, a green and larger turbos dont even wake up till 22+ psi. i made like 360 wheel and 320 tq at 21 pounds then i told the guy i want 24-25 psi. then the car made 30 more wheel and about 80 more wheel tq, which is hella more at only 3 more pounds.
i would check for leaks, but i dont think it would spool like that if there was a leak. the car just aint holding boost and doesnt have enough boost in the first place. good luck
(waiting for phatron )
godforbid67 is offline   Reply With Quote
Old 01-03-2009, 02:58 PM   #8
wrex03
Member#: 29963
04 sti
Green is not a lean as the past tune. Why only 17 PSI? What kind of gas?
wrex03 is offline   Reply With Quote
Old 01-03-2009, 03:02 PM   #9
DannyGrant
Member#: 188342
2007 STI
93 octane.
Old 01-03-2009, 04:28 PM   #10
godforbid67
Member#: 137168
06 Built SGM WRX
pretty damn sure my green is blown ...........
Old 01-03-2009, 04:31 PM   #11
n2oiroc
Member#: 141952
15 legacy 16 wrx
is it a catted dp? if so, thats keeping you down 15 whp or so. i bet the rest is from the lack of boost. you NEED to be at 21psi +.
n2oiroc is offline   Reply With Quote
Old 01-03-2009, 04:34 PM   #12
MattPersman
Member#: 139385
so you have an engine logics tune now? what does Chris say about this assuming he tuned it? he is very knowledgeable and experienced so the tuner is not the problem
why are you switching to a Jorge tune and not have Chris retune it with the new stuff maybe at a slight discount?
your location says Houston, why not bring it by MZM and have them look at it or retune it? they have built solid cars
if you are in the tri-state area you have access to numerous good tuners; nothing against Jorge by any means he is a helluva tuner from what I have seen with loads of experience but, I would like to be tuned by one of your local ones so if you have any questions or need something looked at quickly it is local and convenient.
gotta be something in your set up that is holding you back, 7cm green should make a good 50 whp + over a stage 2 car even with cats and a restrictive cat back
MattPersman is offline   Reply With Quote
Old 01-03-2009, 04:36 PM   #13
HighSpeedLowDrag
Member#: 59871
2004 STi - Silver
FPGreen,FMIC,Wisecos,MSPT
I have the small green just like you. It easily holds 20psi all the way to redline. You are losing a lot of power on the top end at only 17psi. As far as running this turbo with a TMIC, honestly, if I were you I would run an FMIC being in Houston and on stock pistons. I have run it with both a big TMIC and FMIC. You are leaving yourself vulnerable to detonation on a hot summer day with a TMIC, and the stock pistons do not handle detonation very well at all. My car runs super consistently in the summer with the FMIC, even in traffic with the a/c running. I don't know about dyno graphs, but I cannot "feel" any difference in spool between the two intercoolers other than that the car runs much stronger with the FMIC.
HighSpeedLowDrag is offline   Reply With Quote
Old 01-03-2009, 04:44 PM   #14
sleepersti04
Member#: 146554
2004 STi WRB
30R
You really have all the supporting mods needed, your numbers are definently low.
I made 60whp more on the 8cm Green
sleepersti04 is offline   Reply With Quote
Old 01-03-2009, 04:51 PM   #15
DannyGrant
Member#: 188342
2007 STI
Brad tuned it. He said he honestly didn't know why it was performing so poorly. There were other problems that came with Brad's tune. Such as a rolling idle. He even tuned it twice. Problem is still there.
I'm in the tristate area right now for school. That's why I'm getting a tune up here.
I didn't know about MZM. I'll have to look them up when I move back.
Old 01-03-2009, 04:54 PM   #16
DannyGrant
Member#: 188342
2007 STI
Catless.
Old 01-04-2009, 11:20 AM   #17
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
Wow that ain't a good tune with a Green with that output I have the same sized Green on my 2.0 and at 24psi I pushed 380whp.
Junior tuned it way back when and yeah I have a JDM engine and FMIC but if I only came that much up in HP when I did my turbo swap I probably would have sold my car
2002WRXSTi is offline   Reply With Quote
Old 01-04-2009, 02:04 PM   #18
MattPersman
Member#: 139385
if you are in the tristate area now for school get JR tune!
Old 01-04-2009, 02:21 PM   #19
DannyGrant
Member#: 188342
2007 STI
What's JR? Link pl0x?
Old 01-04-2009, 07:40 PM   #20
MattPersman
Member#: 139385
Jr is the tuner at The Shop. his screen name is Junior2JZ and http://www.theshopct.com/ PM him and tell him what you got going on, he will be able to help you out I am sure
Old 01-04-2009, 07:46 PM   #21
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
wow those numbers even make me sad. =(
ownnij is offline   Reply With Quote
Old 01-04-2009, 08:31 PM   #22
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
your numbers are low because of your lack of boost. im assuming you're on 93 octane....you should be running 21-22 psi tapering to 20 psi by redline. upping the boost 3 psi at redline will net you around 30 whp.
your lag is due to your 2.4" turbo inlet pipe, 2.4" inlet, tgv's, stock headers......
your power is a result of your setup and your tune, not the turbos fault. there is really no point in getting a green if you're only gonna run it at 17 psi at redline....shoulda just kept the stocker. at high rpm the only way to make more power is more boost (or cams, but that really doesnt apply here). the only reason to lower the boost like that is if the tmic was not up to the cooling task and you were knocking at higher boost levels.
also, some others have reported that the spt catback becomes a hinderance with larger turbos....not sure what turbo flow the losses start to appear at though.
heres my 3" 8cm green
20psi by 3600rpm
25psi by 3700rpm
Old 01-04-2009, 08:56 PM   #23
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
I agree with Phatron, it's the supporting mods. I get peak torque at 3600 on the dyno with my Green. I'm only running 19.5 PSi on 91 octane and I don't have AVCS.
slowmike is offline   Reply With Quote
Old 01-04-2009, 08:59 PM   #24
DannyGrant
Member#: 188342
2007 STI
20psi by 3600rpm
25psi by 3700rpm
Thanks for the info! Could I request a graph of your torque curve please?
Old 01-04-2009, 09:28 PM   #25
Phatron
Member#: 36033
CEO PhatBottiTuning
here ya go...91, 91+meth and 100+meth
Fp green 7cm 2.4 inch Udaman Engine/Power/Exhaust 7 05-24-2010 02:12 AM
FS; NEW FP green HTA 2.4 inlet JT's06sti Engine/Power/Exhaust 12 12-23-2009 01:06 PM
FP Green 8cm 2.4" Inlet nebulanbloom Engine/Power/Exhaust 3 10-25-2009 10:45 PM
FP Green 7cm^2 2.4" Inlet IWG motocooney Engine/Power/Exhaust 6 04-13-2009 10:26 PM
WTB: FP Green Turbo. 2.4 inlet 8cm housing hettchen Private 'Wanted' Classifieds 1 12-01-2007 02:25 AM
