Old 01-03-2009, 01:07 PM   #1
Greg - LI
Member#: 42873
2007 Outback 2.5i 5M
Satin White Pearl
Default Can you move factory TPMS from wheel to wheel?
I have an 07 Outback with the factory 17" aluminum wheels with TPMS. I would like to switch to the factory 16" steel wheels so that I can run an off road tire. Can I move the TPMS sensors from the 17" wheels to the 16" wheels? I don't want an idiot light staring me in the face all the time but the cost of new TPMS sensors is prohibative.
Thanks in advance!!
Greg - LI is offline   Reply With Quote
Old 01-03-2009, 02:18 PM   #2
vision.dynamix
Member#: 139955
# OneBoston
Do you plan on swapping wheels/tires back and forth? Because to move the TPMS from one wheel to another, you have to unmount the tires, remount and rebalance.
I find TPMSs annoying..I built a pressurized canister for my Tacoma that I put all 4 sensors in, filled to 30PSI and its sitting in a cubby.
vision.dynamix is online now   Reply With Quote
Old 01-03-2009, 11:04 PM   #3
Greg - LI
Member#: 42873
Satin White Pearl
No, I'm not going to be swapping wheels and tires. Once the 16"s go on, they will be on until they wear out and then I will replace them with either another set of 16"s or put new tires on the original 17" wheels. I won't need two sets of TPMS sensors.
BTW, that is a pretty cool thing you did.......a pressurized can.
Old 01-03-2009, 11:50 PM   #4
vision.dynamix
Member#: 139955
# OneBoston
If youre not swapping wheels there is no reason to not use the TPMS. They should swap over fine.
IRA: How often can you transfer an IRA from bank to bank? plunk10 Off-Topic 5 05-25-2010 11:09 AM
can you reset factory ecu to stock after factory ecu updates SHAG SCOOB Engine Management & Tuning 6 11-29-2009 02:55 AM
Can you disable the TPMS light? tphskab Tire & Wheel 8 02-25-2009 05:06 PM
Can you re-flash ECU from AT to MT? Lamont Transmission (AT/MT) & Driveline 3 04-16-2008 01:43 PM
Can you move the front door speakers to the back door in the WRX? Cjchaps Car Audio, Video & Security 1 08-29-2001 10:44 PM
Message Board Statistics All times are GMT -4. The time now is 09:02 AM.
