Old 01-03-2009, 02:10 PM   #1
CoBB_tHiS!
Member#: 171730
2013 WRX Limited
Default Delta Regrinds on an 2005 ?! Where? How?
Im thinking bout getting some nice power out of my RS as soon as i get my headers and high flow cat installed. I see everyones doing the delta cam regrinds now.. what are your opinions for a daily driver? where could i tune after cam install? and where and how would i contact Delta about getting my cams regrinded?
need to contact them for further information somehow..
please help out
thanks fellas
CoBB_tHiS! is offline   Reply With Quote
Old 01-04-2009, 12:07 AM   #2
SubieGenius
Member#: 176874
2000 Impreza 2.5 Rs
SilverThorne
Bump. I need to know aswell for my 2000 rs
Is there anything i have to do after installing? Some1 said i had to do the timing?
SubieGenius is offline   Reply With Quote
Old 01-04-2009, 02:20 AM   #3
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
That is the only number I have for deltacams. You dont have to set the timing, you do, however, need to set the valve lash. But that is after the timing belt is on.
If you have a way to tune, you will get the most gains from the cams. I would get the spicy cams (I have them, so i'm biased) When they come on you can definately feel it.
Installing/torqueing the cam bridge isn't hard, buy a haynes manual and it will tell you how.
~Josh~
Old 01-04-2009, 03:06 AM   #4
lemons
Member#: 186654
2005 2.5 RS
Navy Blue
Can cams be a DIY job or does it require pulling the engine out?
lemons is offline   Reply With Quote
Old 01-04-2009, 03:16 PM   #5
SubieGenius
Member#: 176874
2000 Impreza 2.5 Rs
SilverThorne
There is diy writeups, but none while the engine is in the car, BUT you CAN do it without pulling it. Too hard for me though so i need to go get raped by 85$ and hour as5holes
Old 01-05-2009, 03:37 AM   #6
ballitch
Member#: 74907
98 cam'd EJ251
^^^ Take that $85 and buy yourself and engine stand. Rent a cherry picker/engine hoist at a tool rental shop. It really isnt hard at all. Just grab yourself a haynes or chiltons manual and a decent set of tools. A 3/8'' and 1/2'' torque wrench are almost mandatory for working on your car.
I would take the engine out.
~Josh~
help with an install on an 06 legacy... how ot remove the climate control cable higgins14 Car Audio, Video & Security 1 05-08-2010 12:58 PM
11 sec on an EJ207 STI - how do I do it ? ElSpa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-19-2009 02:04 AM
Delta Cam Regrind on the 2.5i AWDDownShift Normally Aspirated Powertrain 12 05-07-2008 06:37 AM
Where can I get a great deal on an 05 WRX / How much did you pay? Fitz12444 General Community 17 02-10-2005 03:13 PM
Tuning with Delta Dash on an Ecutek Reflash Tuned Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-04-2004 08:43 PM
