Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 01-03-2009, 04:09 PM   #1
subysteve
Member#: 8861
01 2.5rs
Default timing belt and other problems!
i have a o1 rs coupe with 73k on it , is it time to change the timing belt or could i go up to 100k on it ? also if car is stationary turning the steering wheel car is starting to make squeking noise is that cause of drive belt or is it timing belt? also i think my rear bearing is gone i hear like a whooo whooo whooo consistently , if bearing is left can it cause major damage is bearing is left alone?
Also my auto tranny i am getting wheel spin front left tire especially in the rain and snow , Ive read up and I believe its my front dif , I dont drive the car much but still need it , is there a way to correct it without costing a arm and a leg , or is it just better to wait till whole tranny dies and replace it all together
thanks for all your help!
subysteve is offline   Reply With Quote
Old 01-03-2009, 05:20 PM   #2
turd_ferguson
Member#: 114609
I believe the recommended timing belt change for an RS is 105,000.
You probably have a loose power steering belt if it's squealing when you turn the wheel.
If the sound you're hearing from the rear changes depending on the speed or when you take corners, you probably have a bad rear wheel bearing. It may be a humming sound or a metal on metal grinding sound if it's really bad. It's something you should definitely fix.
I don't know what to tell you about the wheel spin problem.
turd_ferguson is offline   Reply With Quote
Old 01-03-2009, 11:15 PM   #3
my4isflat
Member#: 120002
2000 2.5 RS, '95
Legacy w/325k mi (RIP)
As far as your wheel spin problem goes you can put a LSD in the front, that's just the nature of an open differential.
my4isflat is offline   Reply With Quote
Old 01-05-2009, 03:43 AM   #4
subysteve
Member#: 8861
01 2.5rs
problem is with the auto's the front diff is in the transmission so id have to open her up and thats expensive
thats good to know about the timing belt cause any shop i went to and i would tell them how many miles i have they were like yeah its time , but in my mind i was like no way at 73k just wanted to double check , cause i searched and coulnt find the real answer anywhere
Old 01-05-2009, 10:12 AM   #5
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Dont search or ask for maintenance advice as 99% of people, techs included, will steer you wrong. Go read the Maintenance FAQ stickied at the top of this forum...it contains the RIGHT answer.
Old 01-06-2009, 05:21 AM   #6
subysteve
Member#: 8861
01 2.5rs
thanks unabomber , i tried the search and its got to many dif answer but the maintence faq def helped
now just gotta figure out the tranny issue
Ever done your timing belt and later had problems? clkoontziii Service & Maintenance 5 03-21-2010 03:16 PM
STi FUEL LINES TIMING BELT AND COVERS AND ENGINE WIRING HARNESS. OTHER ITEMS TOO! silvershadow Engine/Power/Exhaust 0 07-13-2009 01:53 PM
Timing belt and other services? corms333 Newbies & FAQs 13 05-27-2009 02:48 PM
Changing Timing belt & other belts at 95K Outback Help! Mad Aaron Normally Aspirated Powertrain 4 03-01-2007 05:24 PM
Timing belt and Power steering belt? Kopid Newbies & FAQs 15 02-06-2007 03:08 AM
