Old 01-03-2009, 06:48 PM   #1
AWDrifterz
Member#: 154048
Default What gaskets I need for my engine rebuild?
Guys, I need help
I need to know what kind of engine gaskets needed to be replaced when doing an engine rebuild? (would be great if someone have the parts numbers) My car has a Phase 1 EJ25 short block attached to Phase 2 EJ25 heads.... and I wounder if I bought a full set that is ment for the Phase 2 would fit right with the block? ( as I remmember when I saw the P1 and P2 blocks setting next to each other there was no diffrence, but that was 2 years ago and I don't remmember 100% )
AWDrifterz is offline   Reply With Quote
Old 01-06-2009, 03:44 AM   #2
AWDrifterz
Member#: 154048
come on guys?
I'm not sure but I assume if I order a full gasket set for P2 engine it will work with the P1 shortblock (since my engine heads are P2)
where are the guru's?
Old 01-06-2009, 01:34 PM   #3
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
you should post this is the engine build section.
watchunglava is offline   Reply With Quote
Old 01-06-2009, 02:06 PM   #4
vangstaboi86
Member#: 119945
2004 sti
java black pearl
list sent thru pm.... hope it helps
vangstaboi86 is offline   Reply With Quote
Old 01-06-2009, 08:33 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Buy a complete engine gasket kit for a phase II Ej25. It will be the most cost effective approach even though there will be a few gaskets you don't use.
what should i use for my engine?.... XmikeX Car Care & Detailing 7 07-28-2008 04:39 PM
What is the code for my engine and transmission? Savage-Handbraking Newbies & FAQs 3 04-03-2008 12:57 AM
What do I need for my home theater? jcholak718 Off-Topic 83 03-01-2007 08:20 AM
what gaskets are needed for uppipe installation? ultraspdWRX Newbies & FAQs 9 01-08-2007 07:04 PM
what do i need for my 16g living4surf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-27-2006 08:18 PM
