Old 01-03-2009, 08:00 PM   #1
Cstmboxermotorsports
Member#: 103340
1992 RHD WRX
Default 04 STI DCCD not working please help
My DCCD on my 04 STI isnt working and i have no idea why. I bought the car as a theft recovery, installed a new roller controller, and the DCCD box that goes under the dash, as well, everything is hooked up on the tranny.
I havnt been able to get the roller switch to work. As well my ABS light is on and every part of the ABS is hooked up, but its not working either, could that be part of the same problem?
Cstmboxermotorsports is offline   Reply With Quote
Old 01-04-2009, 03:00 AM   #2
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
The DCCD control integrates into the ABS system. You need to find out what is wrong with the ABS. When you fix it it will likely fix your DCCD as well. The dealer can read the code or you can do it yourself. Use a paperclip or wire to connect pins 3 and 6 on the diagnostic connector. The ABS light will blink the code.
FourOnTheFloor65 is offline   Reply With Quote
Old 01-05-2009, 12:28 AM   #3
Member#: 103340
1992 RHD WRX
Awesome dude, u rock my world
Old 09-16-2009, 05:57 AM   #4
bluetaxi
Member#: 170504
2003 STI ver 8 JDM
I hv a friend also hv this problem on DCCD. but we hv check all the sensor. Finally found out when the can voltage drop >11v, where u also turn on the air-con, head light.... it seem the dccd do need a stable power to run.
bluetaxi is offline   Reply With Quote
sti throttle not working please help Bcoolsti Electrical & Lighting 3 07-20-2009 05:25 PM
06 sti dccd not working nvrenufsti Transmission (AT/MT) & Driveline 9 10-31-2008 01:36 AM
2007 STi tranny in 2004 Sti - DCCD not working ? salt Transmission (AT/MT) & Driveline 0 04-11-2008 11:25 AM
05 Sti Fuel gauge not working please help hilfiger4you Service & Maintenance 5 12-11-2005 12:52 AM
window is not working!! please help Kevex Service & Maintenance 3 01-07-2004 09:43 AM
