Old 01-04-2009, 03:34 AM   #1
rice or die
Member#: 191034
1992 legacy turbo
Default building my ej22t
ok im rebuilding my ej22t and i want to put forged pistons and rods in, anyone know what set i need, im trying to get them off ebay, the weisco ones but they are for ej20's or ej25. can i get links to the right stuff?
also i want to put 2.5 heads and manifold on my ej22, do i need to drill a hole for an oil line to my turbo? and is there any other major modifications i need?
im starting this build tommorow so i really need to find out info
rice or die is offline   Reply With Quote
Old 01-05-2009, 04:47 PM   #2
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
From what I know the crank and rods are forged...the pistons are turbo friendly but not as strong as forged.
Oil supply for turbo is not supplied on the 2.5rs heads ( where the bango fitting is on the turbo heads for the oil supply ) so YES you will have to either rout a line or tap the NA passenger side head for oil. Actually it maybe easier to pull from the oil pressure sensor hole on top of the motor....?
You will also have to rout that oil back into the motor. The easiest spot is to tap the pan above the separation baffle. If it where me Id go through an oil cooler B4 back into the block.
dangerousatom is offline   Reply With Quote
Old 01-05-2009, 11:38 PM   #3
rice or die
Member#: 191034
1992 legacy turbo
anyone here know whats the max psi the ecu will compensate for and can i change to a jecs maf so i can run even more? im trying to run 20psi with stock ecu
Old 01-06-2009, 12:40 AM   #4
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
20 psi w/ a stock ecu is a looong shot!
sense of nature is offline   Reply With Quote
Old 01-06-2009, 01:01 AM   #5
rice or die
Member#: 191034
1992 legacy turbo
well i found that the most i can run on my ecu is 444cc of fuel so if i get 440cc greys and if im running 14 psi with stock injectors i should be able to just max out my tdo4 with those 440 greys right? the td04 maxs at 20.1 psi but it would probably not hold it for long
Old 01-06-2009, 01:07 AM   #6
RallyColtTurbo
Member#: 16819
Lots of info on LegacyCentral.org that directly relates to your questions.
RallyColtTurbo is offline   Reply With Quote
Old 01-06-2009, 08:49 AM   #7
DSM_Outback
Member#: 56345
93 Swapped L
Green
Wiseco K601M98 or K601M975, depending on wear.
Yes oil return line will need drilled on the passenger side, just pull an oil galley plug back there for the feed.
DSM_Outback is offline   Reply With Quote
Old 01-06-2009, 08:39 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
1. That's way past efficient range on a 2.0l. 1.1bar is about the max you would ever want to run that turbo.
2. You are now running it against 2.2l of discplacement. 10% more displacement is going to change how much boost that turbo can push efficiently.
Old 01-06-2009, 09:27 PM   #9
dangerousatom
Member#: 70710
cant you just get an adjustable RRFPR and tweek the presure insted of goin larger injectors? . . . To a certin point
So my ej22t build is underway i have questions tho fastlanerex Built Motor Discussion 48 12-22-2011 12:08 PM
Pretty much decided on my engine build ej205/ej22t/TS OPINIONS? hotshot2109 Built Motor Discussion 0 12-05-2009 06:02 PM
Building an EJ22t PhilSine Built Motor Discussion 24 07-19-2008 02:28 AM
What if I were to slowly build an EJ22t? burtonsnowman Pre-2002 Factory Turbo Powertrain 34 05-15-2008 09:27 PM
anyone know alot about building an EJ22T? kc_tap1 Pre-2002 Factory Turbo Powertrain 4 07-20-2006 12:02 AM
