Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC > SCIC Vendor Classifieds
Closed Thread
Old 01-04-2009, 04:31 AM   #1
Apollo Performance
Vendor Sales Rating: (35)
Member#: 110949
2005 Apollo Spec 2.5
Time Attack Street Class
Default Apollo Performance Specials: $50.00 HID Kits! All Colors and Bulbs!
On a budget? Need the best service?
Call us for best prices or pm
Our Current Special:
How about a Timing Belt Special folks? Well, here it is! For only $850.00 we will replace your timing belt, but that's not all!
*Tomei Belt Guide not included
Here's what you'll get in the special:
  • Water Pump
  • Gates Racing Timing Belt (one of the best in the market!)
  • Idler Pulleys
  • Labor and all necessary fluids
Usually we recommend that you get a Timing Belt replacement every 80,000 - 100,000 miles depending on the age and condition of your Subie! This is an important tune up that most people don't realize that needs to be done!
No hidden fees or anything else that is needed! You pay $850.00 for this and you're done! You won't find a lower price than this!
Call us at (909)997-3418 to schedule your appointment today!
*This service may require you to put down a $200.00 deposit which will be part of your final bill!
Don't let your Subie GO THROUGH THIS:
This customer neglected to change his timing belt, drove his car with the water pump ceased, belt shredded, and ran the pulleys till they turned blue causing a total engine failure. Instead of a low priced timing belt change, he's going through an engine rebuild! Don't let this happen to you!
Here's what else we can do for you!
  • Services Available including: clutch jobs, turbo upgrades, bracing, aero enhancements, cooling, power build ups, and much more!
  • 30k 60k and 100 k services
  • Port and Polishing available
  • Engine Rebuilds and Swaps
  • Full Race Engine Builds and Race Preparation / Fabrications
  • Official Dealers of: Turbosmart, ARK Performance, Buddy Club, Godspeed Project, Clutch Masters, Motul, APR Performance, Apex'i, and much more!
  • High Performance tires including Yokohama, Bridgestone, Hankook, Falken, Michelin.
  • Anything you need, we can get it for you and customer service is priority
1687 W Arrow RTE Upland CA 91786
Click Here for our Service Pricing! Of course, PM us for the best pricing and to schedule an appointment!
Click Here to view our blog!
Click here to join our fan page on Facebook!
Click here to shop on our online store!
GiNo apollo performance 909 997-3418
apolloperformanceonline.com
Our everyday (and customer) low pricing at Apollo Performance!
Suspension Labor Rates:
Coilover Install $120.00
Coilover Adjustment Height / Dampening $65.00
Spring Install $70.00
Front Sway Bar $75.00
Rear Sway Bar $75.00
Subframe Install $120.00
Roll Center Adjusters Install $120.00
Fender Brace Install $65.00
Lateral Link Install $100.00
Exhaust / Engine Labor Rates:
Cat Back Exhaust Install $60.00
Uppipe Install $140.00
Turbo Inlet Install $160.00 (Hard Inlet $200.00)
Downpipe Install $75.00
Turboback Exhaust Install $120.00
Injector Install* $120.00
Fuel Rail Install* $140.00
Fuel Pump Install* $75.00
Full Stock location Turbo swap* $120.00
Full Stock Location Turbo Swap (Injectors, fuel pump)* $300.00
Exhaust Manifold Install $140.00
Top Mount Intercooler Install $40.00
Front Mount Intercooler Install $220.00
Blow off Valve Install $40.00
Radiator Hose Install $35.00
Radiator Install $70.00
Oil Cooler Install $100.00
Interior / Brakes Labor Rates:
Steering wheel install $80.00
Turbo Timer Install $30.00
Gauge Install (per gauge) $60.00
Rotor/Pad Install (Front and Rear) $130.00
Brake Line Install $60.00
Big Brake Kit Install (Fronts) $140.00
Big Brake Install (Front and Rear) $220.00
Service Rates:
30k Service $300.00
30k Service (with Motul) $330.00
30k Service (with Motul 300v) $375.00
60k Service $400.00
60k Service (with Motul) $430.00
60k Service (with Motul 300v) $475.00
90k Service $300.00
90k Service (with Motul) $330.00
90k Service (with Motul 300v) $375.00
105k Service $975.00
105k Service (with Motul) $1,025.00
105k Service (with Motul 300v) $1,050.00
Iridium Spark Plug Change $120.00 with plugs
Clutch Install $300.00
Synthetic Oil Change with Filter $50.00
Motul Oil Change with Filter $65.00
Motul 300V Oil Change with Filter $100.00
Transmission Oil Change $70.00
Transmission Oil Change with Motul Gear 300 $90.00
Differential Fluid Change $40.00
Diff Fluid Change with Motul Gear 300 $60.00
Brake Fluid Flush and Bleed $60.00
Brake Fluid Flush / Bleed With Motul RBF600 $120.00
__________________________________________________ ____
UPDATE!
We are doing so many engine rebuilds as of lately. We are getting the great reputation of having the fastest turn around time, guaranteed labor, great customer service, and with FREE ACL Race Bearings! Prices starting at $3,200.00 (with labor and free ACL Race Bearings)!!!
We are always taking reservations for spots on rebuilds. Contact us today for your quote!
Thank you!
Apollo Performance is offline
Old 01-04-2009, 09:27 PM   #2
BreaWRX-STI
Member Sales Rating: (10)
Member#: 153482
-06- STI
Ewg ...
BreaWRX-STI is offline
Old 01-04-2009, 10:18 PM   #3
dannyblaze_07
Member Sales Rating: (2)
Member#: 119176
05 STi
PM sent
dannyblaze_07 is offline
Old 01-04-2009, 10:24 PM   #4
mikercp
Member Sales Rating: (34)
Member#: 166465
1994 Civic Cx
Frost White
Gino how much for arp extended wheel studs f/r set 03 bugeye.
Also how much to install , Ive never done wheel studs id feel better leaving this to the pros!!
mikercp is offline
Old 01-04-2009, 11:16 PM   #5
Apollo Performance
Member#: 110949
i will check and pm you tomorrow about wheels studs bro and ricky ill have the price for external gate tomorrow bro
Old 01-05-2009, 01:21 AM   #6
highrevracer951
Member Sales Rating: (9)
Member#: 141470
2009 Legacy
pm sent
highrevracer951 is offline
Old 01-05-2009, 01:46 AM   #7
Apollo Performance
Member#: 110949
pm replied
Old 01-05-2009, 02:00 AM   #8
HB Speed
Vendor Sales Rating: (4)
Member#: 160911
2008 GT33R Evo X
560+ whp GG
/me awaits a lineup of tunes from vroompa!
__________________
[SIZE=3][B][COLOR=Red]
[/COLOR][/B][/SIZE]
[B]10595 Lawson River ave
Fountain Valley CA 92708
714-378-DYNO (3966)[/B]
[COLOR=Red]PLEASE EMAIL or CALL us for questions or appointments![/COLOR] ([COLOR=Red]pm's dont always get seen[/COLOR])
[COLOR=Red][B]Tues - Sat 10am - 7Pm
Sun-Mon - CLOSED[/B][/COLOR]
[COLOR=black]Parts sales, installation, custom fabrication available!
AccessPORT (only REAL AP programmer in OC) Open Source, Ecutek, Hydra, AEM, AUTRONIC, and more!
[/COLOR][COLOR=black]Catch us online at:
[/COLOR]
HB Speed is offline
Old 01-05-2009, 11:37 AM   #9
Apollo Performance
Member#: 110949
you already know bro
Old 01-05-2009, 12:56 PM   #10
wicked_wrx
Member Sales Rating: (18)
Member#: 145833
2004 Clark Tuned WRX
Roof-Rack & Wingless WRB
Apollo Performance FTW!!!
thanks for the install Danny
wicked_wrx is offline
Old 01-05-2009, 09:05 PM   #11
AltronX
Member#: 86241
2006 Bolony Mobile
REAL MAN KREW #5
Where you located man? I'm having some clunking noises going on with my sway bars and I wanted to bring it to a shop and have someone else take a look at it. Would you be able to help me?
AltronX is offline
Old 01-05-2009, 10:23 PM   #12
thisisthenewsic
Member Sales Rating: (32)
Member#: 156829
05 legacygt,00 OBS
red 95 supercharged nsx
they are located in upland......
thisisthenewsic is offline
Old 01-06-2009, 11:31 AM   #13
XWDPX
Member Sales Rating: (39)
Member#: 151123
Yo G
Could you pm me a price for a flywheel change on an 07 cobalt ss.
Thanks
-Steven
XWDPX is offline
Old 01-06-2009, 11:55 AM   #14
xrobbyx
Member Sales Rating: (6)
Member#: 109456
i need the work extended lugs in red and the work red valve stems
let me know a price,
also ru guys rolling fenders and doing allignments
xrobbyx is offline
Old 01-06-2009, 12:02 PM   #15
thejordan
Member Sales Rating: (37)
Member#: 185374
^ pm awdalbert, he's friends with gino and does all the rolling.
thejordan is offline
Old 01-06-2009, 12:29 PM   #16
Apollo Performance
Member#: 110949
yeah i have a good guy for fender rolling
Old 01-06-2009, 12:30 PM   #17
Apollo Performance
Member#: 110949
we are locayed in upland address is 1685 arrow rte upland ca 91786
Old 01-06-2009, 01:44 PM   #18
howweirdo
Member#: 186257
2008 obp GH
VF52 319/325
do you guys do installations? how much for a downpipe installation?
howweirdo is offline
Old 01-06-2009, 05:45 PM   #19
Apollo Performance
Member#: 110949
pmed.......
Old 01-06-2009, 06:21 PM   #20
XWDPX
Member#: 151123
Originally Posted by vroompa View Post
pmed.......
what about me or text me dude .. Was gonna call but im sure u are busy
XWDPX is offline
Old 01-06-2009, 06:46 PM   #21
Apollo Performance
Member#: 110949
steven ill call you in a bit bro
Old 01-06-2009, 06:47 PM   #22
XWDPX
Member#: 151123
Thanks G.
XWDPX is offline
Old 01-08-2009, 03:19 AM   #23
thisisthenewsic
Member#: 156829
05 legacygt,00 OBS
bump for a great shop who does great work for great prices
their greaaaattttt!*tony the tiger voice*
haha
Old 01-08-2009, 04:30 PM   #24
Apollo Performance
Member#: 110949
thanks bro and pm for prices we will def take care of you guys
Old 01-08-2009, 06:21 PM   #25
Niterider03
Member Sales Rating: (35)
Member#: 88186
03 Swagger
Wagon
What up Gino! Hey, can you get me a price for a set of Tein Mono Flex coilovers for a Evo IX?
Niterider03 is offline
Closed Thread
Apollo Performance Grand opening Apollo Performance Southern California Impreza Club Forum -- SCIC 282 03-20-2011 07:55 PM
Apollo Performance 200 tire special Apollo Performance SCIC Vendor Classifieds 190 07-02-2010 12:46 AM
HUGE PROPS to Apollo Performance Today! Deserted1 Southern California Impreza Club Forum -- SCIC 52 02-18-2009 02:30 PM
Apollo Performance impressions........ smileyou Southern California Impreza Club Forum -- SCIC 49 02-04-2009 01:29 PM
Message Board Statistics All times are GMT -4. The time now is 05:29 AM.
