Old 01-04-2009, 12:20 PM   #1
mstein
Member#: 130601
2005 Legacy Wagon
2.5
Default Problem starting
I've been having a problem starting my car in the mornings lately. It's winter, so I'm sure the cold has something to do with it. It cranks but will not ignite. Takes me a few times trying to start it and then eventually ignites. The other day, I had left it for a couple days without driving, and it wouldn't start. I jumped it and it worked. Drove to Autozone and swapped out the battery because I figured my battery was going bad. With the new battery, it started up right away. I ran errands yesterday, and each time didn't have a problem starting. Left it over night and had the same old problems this morning. Took 5 times attempting to start before it ignited. Any thoughts? Could something be draining my battery while the car is off? fyi, no dome lights left on or anything.
A couple other notes:
- car has no problem starting after it has been running a while and then shut off
- most recent maintenance is changing my spark plugs and wires. There was oil on the boots. Is that bad?
- seems to "seize up" as it tries to start. Not sure if that is the right term, but that's what it reminds me of.
mstein is offline   Reply With Quote
Old 01-04-2009, 08:08 PM   #2
mikeythejew
Member#: 141672
I'm confused. Try putting a bottle of drygas in your tank the next few fill ups. If you see the iso-heet brand in a red bottle, use that. If you have an electrical short, it can drain the battery.If that is the problem, good luck finding it!
mikeythejew is offline   Reply With Quote
Big problems starting cold. Midwayman Normally Aspirated with bolt-on Forced Induction Powertrain 15 01-16-2003 04:37 PM
Nasty problems starting cold Midwayman Engine Management & Tuning 0 01-15-2003 02:55 PM
Tranny problems starting to appear @ 26k miles Shifty Transmission (AT/MT) & Driveline 24 12-02-2002 12:43 AM
Problems Starting Car Graham Normally Aspirated with bolt-on Forced Induction Powertrain 10 04-22-2002 10:15 AM
('93-'01) anyone ever have this problem starting your RS? IMPRZME Impreza Forum 7 05-09-2001 01:02 AM
