Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 01-16-2009, 07:37 PM   #1
WREX88
Member#: 166373
2002 WRX (VF-39)
BMW 330XI
Default 291 whp 285 wtq VF-39 on a 2.0L
These were done in the heat of summer, the temp next to the airbox was 115 degrees F.
3rd Gear:
4th Gear:
AFR's and Boost:
HKS Up Pipe
3'' Invidia Cat-less DP
3'' HKS Hi-Power Cat-back
Cobb AccessPort (Stage II 93)
Cobb Lightened Crank Pulley (not under driven)
Walbro 255 lph
IHI VF-39
HUGE ebay TMIC
06 WRX Injectors 560 cc
Halman Pro RX MBC
STI Pressure Plate (5MT)
STI Clutch Disc (5MT)
STI Light Weight Flywheel (5MT)
OEM Short Throw Shifter
TGV deletes
ebay inlet pipe
tuned by Paul @ ECS performance in Springfield, MA.
WREX88 is offline   Reply With Quote
Old 01-16-2009, 07:48 PM   #2
hauntedwrx
Member#: 115104
2003 WRX
Sedona Red Pearl
How do you like that Cobb Pulley, is it a nice piece? Nice numbers by the way.
hauntedwrx is offline   Reply With Quote
Old 01-16-2009, 08:30 PM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
nice numbers
Old 01-16-2009, 08:33 PM   #4
XWDPX
Member#: 151123
Very nice numbers our mod list about the same and i only put down 260hp
Not very happy w/ my tune.
XWDPX is offline   Reply With Quote
Old 01-16-2009, 08:43 PM   #5
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
Seems almost like it's a bigger turbo than a 39. A bit laggy and power didst drop off a 7000rpm. Did you like the tgv delete mod?
scoobystas is offline   Reply With Quote
Old 01-16-2009, 08:53 PM   #6
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
That's laggy as hell for the that turbo and setup. My 30R comes on full at the same time.
4ST-AIR is offline   Reply With Quote
Old 01-16-2009, 11:29 PM   #7
Android287
Member#: 180861
2005 IAG Closed Deck
Larry's Power built heads
What do stock sti's put down on that dyno. Im out here in Western MA. Maybe i'll check them out.
Android287 is online now   Reply With Quote
Old 01-17-2009, 10:52 AM   #8
WREX88
Member#: 166373
2002 WRX (VF-39)
BMW 330XI
Cobb pulley is a nice piece, not under driven, its just lighter. Didn't notice any gain obviously.
TGV deletes were awesome, definitely noticed gains up top.
Android I recommend checking out ECS for sure.
Old 01-17-2009, 11:19 AM   #9
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
I was thinking it was a bit laggy as well...And it doesnt fall off up top?!?
I dont look at many vf39 sheets but it seems odd that my 18G w/FMIC comes on sooner, yet falls off just a tad up top compared to this.
Nice job tho as long as you are happy
jmlaser is offline   Reply With Quote
Old 01-17-2009, 01:01 PM   #10
sidewayz
Member#: 5810
2001 S366 2.5RS
timing seems to be a bit conservative (unsure without a log). May be to the fact that he's got you at 20 psi on a 39...thats kinda pushing that turbo. Curious to see what your IDC's are like
sidewayz is offline   Reply With Quote
Old 01-18-2009, 12:14 PM   #11
clbd39
Member#: 104078
2013 WRX
looks very similar to my vf43, good job!
clbd39 is offline   Reply With Quote
Old 01-18-2009, 02:49 PM   #12
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
98 Unicorn EVO Killer
Ryan,
You know I'm always conservative with my timing on stock motors.
-Paul
PumpsGOTAWD is offline   Reply With Quote
Old 01-18-2009, 03:01 PM   #13
ARBoost
Member#: 190876
2005 STI CGM
361hp/370tq Done by Jorge
Those are some sexy Dyno cures .
ARBoost is offline   Reply With Quote
Old 01-18-2009, 03:02 PM   #14
Sharky NRK
Member#: 29549
2003 WRX
it does seem a bit slow on response - what gear was the pull in?
Sharky NRK is offline   Reply With Quote
Old 01-18-2009, 03:37 PM   #15
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Nice dyno Graham. Sweet numbers.
Jubert69 is offline   Reply With Quote
Old 01-18-2009, 03:46 PM   #16
RexTexWagon
Member#: 150987
2013 Ford Focus ST3
Dont forget every dyno reads differently. Yours just might be a 290 car on ECS's dyno.
Looks like its a good tune. Not much power on the bottom end, but holds it till red line, which you usualy dont see in the smaller turbo department.
RexTexWagon is offline   Reply With Quote
Old 01-19-2009, 10:47 AM   #17
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
nice numbers graham
BONFIRE074 is offline   Reply With Quote
Old 01-20-2009, 02:10 AM   #18
eMoneyyy
Member#: 200680
2002 W R X
Rally Blue
i cant wait for vf39 time
eMoneyyy is offline   Reply With Quote
Old 01-20-2009, 04:23 PM   #19
Lboogie
Member#: 171611
2014 FiST
Blk
chart says "flywheel horsepower" & "flywheel torque"...
Lboogie is offline   Reply With Quote
Old 01-20-2009, 04:45 PM   #20
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Wierd thing was, a buddy of mine, same Tuner(Paul), and same dyno with a VF34 on an 05 WRX only put 260whp.
Old 01-21-2009, 08:54 PM   #21
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
Tell me more about this particular car?
-Paul
Old 01-22-2009, 12:45 AM   #22
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
ah, at the flywheel....that makes more sense.
aboothman is offline   Reply With Quote
Old 01-22-2009, 03:41 PM   #23
WREX88
Member#: 166373
2002 WRX (VF-39)
BMW 330XI
It's at the wheels.
Old 01-22-2009, 11:03 PM   #24
EFI Logics
Vendor
Member#: 193180
Couple things. That VF-39 is spooling really late, even for a EJ20, but that may not be the tune, it could easily be the way the Dynapak is setup. For starters, there is no reason to pull a WRX in third gear on the Pak, the reason for the line being so squiggly is because it's in a higher torque gear, and those dyno's love that (Sarcastic smiley here). If this pull would have been done in 4th with the proper ramp time, the line would have been more linear, and boost may have come on a bit sooner. I have no idea how the dyno was setup, but if the duration of the pull was too short, then the turbo would spool up late and hold boost a bit better up top. The car has an MBC, so it's really not WG tuning related.
The tune itself looks ok, AFR's come in nice as boost increases, a little conservative on the AFR at lower boost, but better safe than sorry.
Dynapak's are a beast of their own, you can get a tuner who knows how to tune on any other load bearing dyno, stick them on a Dynapak and watch their tune go to complete chaos, I've seen it for years, they are just a very unique tool to tune cars with.
- Chris
EFI Logics is offline   Reply With Quote
Old 01-23-2009, 02:38 AM   #25
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Originally Posted by WREX88 View Post
It's at the wheels.
Thats strange, cause the graph says flywheel. Huh, nice numbers, but how does it drive?
FEELER: VF-38 kit for 2.0l WRX.... Your thoughts? eveofrevolution Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-07-2010 06:57 PM
305 Whp 335 Wtq Vf-39 ( Now with dyno sheet!!!!) blackdub06 Proven Power Bragging 18 03-01-2010 10:22 PM
vf-39 on a stock ej22? SubaruCalgarian Normally Aspirated with bolt-on Forced Induction Powertrain 11 02-23-2007 02:01 AM
Running VF-39 on stock catback 06 wrx Sypher Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-01-2006 01:05 PM
vf-39 on wrx? scoobyracing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 08-26-2005 11:45 AM
