Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 01-06-2009, 09:47 AM   #26
Tuned200
Member#: 127740
2007 FSXT-Mine
2007 F-STI-Her's
Originally Posted by testes1010 View Post
^ I'll see what I can wring out of the stock fuel system w/ a slight increase in fuel pressure, by then, it'll be time for tax return.....
I often wonder this.
In the nissan world, We often added adjustable fuel pressure regulators and turned up the fuel pressure from say 3bar to 4bar.
Why dont the subaru people/tuners do this?
Tuned200 is offline   Reply With Quote
Old 01-06-2009, 09:53 AM   #27
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
cause modded stock injectors are free....
cause used injectors cost less than a name brand FPR...
cause new injectors + core rebate arent that much more than a FPR...
Old 01-06-2009, 10:07 AM   #28
testes1010
Member#: 47145
2012 Gas Saver
some do, the factory FPR can be 'crushed' to bump up fuel pressure a 10 psi or so to gain a bit of headroom. Phatron named off most the reason why most don't use an aftermarket FPR.
testes1010 is offline   Reply With Quote
Old 01-06-2009, 10:38 AM   #29
Dobbs
Member#: 28291
2015 WRX
i'd like to hear some impressions of the legacy vs. impreza... did the impreza seem more nimble? does the ride quality of the legacy make up for it? do you think you will enjoy the increase in displacement + AVCS + better gearing vs. the better mileage of the impreza? i have been debating going this route for awhile...
Dobbs is offline   Reply With Quote
Old 01-06-2009, 10:42 AM   #30
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
The last link was broke, I fixed it.
I actually went one step further with the wrapping, I can only wait for the nasiocwh0res to scream ghetto, ghetto, ghetto......true, but its function over form.
And you thought people were going to call you ghetto!!
Nice setup and look forward to talking to you again.
akira02rex is offline   Reply With Quote
Old 01-06-2009, 11:08 AM   #31
testes1010
Member#: 47145
2012 Gas Saver
My WRX definitely handled much much better than the LGT, however as you stated the LGT ride quality is light-years ahead of my old bugeye. I'd always had fun tuning the Sti's & +06 WRX because of the gobs of torque that the 2.5L allows, however I never wanted a 2.5L in 'my' WRX. I haven't toyed w/ the AVCS yet on the LGT, however my STi maps generally have some minor AVCS tweaking. I'm getting ~22.5mpg from the LGT vs. ~24mpg from the WRX.
Old 01-06-2009, 11:08 AM   #32
testes1010
Member#: 47145
2012 Gas Saver
You never know about this place. Thanks.
Old 01-06-2009, 03:00 PM   #33
Tuned200
Member#: 127740
2007 FSXT-Mine
2007 F-STI-Her's
Cool thread. I may see you sometime at a track/event since your only 2 hours away
Old 01-08-2009, 11:06 AM   #34
testes1010
Member#: 47145
2012 Gas Saver
Big thanks to 5starperformance/Kingofparts, ordered the turbo Monday got it on Wed. Should have it installed tonight.
Also compiled all the dyno graph data to one graph:
Old 01-11-2009, 01:10 PM   #35
Dobbs
Member#: 28291
2015 WRX
how did the install go?
Old 01-11-2009, 01:12 PM   #36
testes1010
Member#: 47145
2012 Gas Saver
Install went well, direct bolton, no issues. I took it out and drove it a bit yesterday but I haven't had a chance to log it.
Old 01-11-2009, 01:52 PM   #37
Dobbs
Member#: 28291
2015 WRX
i bet you'll see ~320/280 tq/hp if you're on 92... be sure and update when you get a chance
Old 01-11-2009, 09:48 PM   #38
testes1010
Member#: 47145
2012 Gas Saver
we've got good (non-E10) 93 here...
First off I'm going to do a few runs with the existing STG1 map w/ the boost set to peak at ~17psi just to give it a good comparison to the VF40 using the same exact map. I would like to break 300whp on the stock TMIC keeping it under 20psi peak, but the logs will tell the tale. Then I'll upgrade to the reworked Tuning Alliance TMIC I have.
I'll have logs up in the morning from the compute to work.
Old 01-11-2009, 11:16 PM   #39
Dobbs
Member#: 28291
2015 WRX
nice, i'll need something to see while i'm at work...
Old 01-12-2009, 09:13 AM   #40
testes1010
Member#: 47145
2012 Gas Saver
This turbo should be alot of fun.....considering all these logs were under 17psi on my same STG1 map. Per these logs I'm already on the edge of 300whp w/ just over 300wtq on my DLL software.
A peak of 278g/sec vs. 250g/sec or so before with similar temps. I can't wait to crank the boost up.
http://www.box.net/shared/gffa0mfete
http://www.box.net/shared/9xc31ol26r
http://www.box.net/shared/zf30839ktf
Old 01-12-2009, 01:03 PM   #41
Dobbs
Member#: 28291
2015 WRX
very nice... can't wait to see 18psi from 3000-5500 do you think you'll be able to get away with 16deg @ peak tq on higher boost? if so, i'm jealous...
Old 01-12-2009, 01:14 PM   #42
testes1010
Member#: 47145
2012 Gas Saver
I'm still at 11.2-11.4 or so on 93(via Innovate LM-1), so I'm still a bit rich so I don't see the timing ~18psi being affected too much. I'll get some more logs on the way home, a few dyno logs as well. Then crank up the boost.
Old 01-12-2009, 06:19 PM   #43
testes1010
Member#: 47145
2012 Gas Saver
Same STG1 map I have posted on Romraider, however boost is just under 16psi during these runs:
two runs opposite directions on the same road, showing levelness of the road & consistency of tune.
VF52(<16psi peak) vs VF40(<17psi peak):
VF52 vs. OEM 100%
Compiled data, yes I picked up ~30whp just bolting this turbo on & ~5wtq peak BUT +25wtq near redline:
Again I can't wait to push +18psi.
Old 01-13-2009, 10:42 AM   #44
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Hey, what weight and tires are you using?
west_minist is offline   Reply With Quote
Old 01-13-2009, 11:40 AM   #45
testes1010
Member#: 47145
2012 Gas Saver
3300(vehicle weight) + 210(driver) and stock sized tires(215/45/17).
Old 01-13-2009, 11:55 AM   #46
west_minist
Member#: 53451
w/ AVCS Silver
Ok. I used 1600kg. Not far off. Ur weight came out to be 1592kg.
The only settings I required are the drag and frontal stuff, but either way less than 320 tq/hp. Like all others, it would be nice to see 18psi on that.
All the best and Happy New Year!
Old 01-16-2009, 09:25 PM   #47
testes1010
Member#: 47145
2012 Gas Saver
Logs of the 2 runs:
http://www.box.net/shared/k6902lnjci
http://www.box.net/shared/hg50qpli46
VF52 still using the same STG1 map I have posted tuned @ 19psi peak:
VF52 @19psi vs. 100% oem stock:
Using Airboy's sheet, 50-80mph =3.08 60-80mph = 2.10
Its amazing what a little boost will do...
Old 01-16-2009, 09:35 PM   #48
testes1010
Member#: 47145
2012 Gas Saver
Looks like you got your wish. I'll need to wait for injectors to turn it up to +20psi
Old 01-16-2009, 09:38 PM   #49
west_minist
Member#: 53451
w/ AVCS Silver
Yep. Nice. Almost look like a 2006 Aussie STI 2.5 I tuned. very nice. Checking the logs now. That LGT must be sweet.
In EcuEdit, 336whp @ 5710rpm & 375wft.lb @ 3914rpm. If I had the speed, it would be nice to compare. But either way, great work and demo for others to swapped. Have a great weekend.
Old 01-18-2009, 05:03 PM   #50
Bullwinkle1983
Member#: 172332
2006 WRX
You using any correction factors on your DLL dynos? What IATs have the recent runs been at?
Bullwinkle1983 is offline   Reply With Quote
FS: 2005 LGT 5MT - 4.11 Final kpluiten Drivetrain 40 09-09-2010 10:42 AM
FS: (UT) APv1 for a 2005 LGT 5MT keithk831 Legacy Specific Parts 1 03-31-2010 06:17 PM
Feeler: Possible trade - 2005 SWP LGT 5MT for 02-05 WRX/WRX STi getawaydriver Private Vehicle 'For Sale' Classifieds 9 08-25-2008 01:35 PM
FS: 2005 Legacy LGT 5MT wagon dashwort77 Private Vehicle 'For Sale' Classifieds 4 10-16-2007 10:59 AM
FS: 2005 LGT 5MT AccessPort w/TDC map StopSweatinMe Tri-State Area Private Classifieds 7 04-25-2007 08:21 PM
