Old 01-04-2009, 10:22 PM   #1
jwhisl
Member#: 199199
1998 Legacy GT Limit
Default Rough idle, loud ticking
I recently bought a 98 legacy gt limited. The people that had it hit a deer and obliterated right intake gear. I finally got the engine back in time, replaced the spark plugs and wires, as well as the cam sensor. The car seems to be idling rough at 1500 rpm's then drops to around 850 after 5 or so minutes.
The car has 217k miles on it and ticks pretty loudly (noise can be heard inside the car with the windows rolled up). It revs just fine and has descent power but I am a bit concerned about the noise. Any suggestions?
jwhisl is offline   Reply With Quote
Old 01-05-2009, 08:59 AM   #2
gtbensley
Member#: 167448
2013 2013 wrx hatch
Plasma blue pearl
Does it tick when it is warm? How loud is the ticking?
gtbensley is offline   Reply With Quote
Old 01-05-2009, 09:07 AM   #3
jwhisl
Member#: 199199
It does tick when it's warm. The ticking is pretty loud. At first I thought it was lifters or bad spark plugs but the car doesn't have lifters to my knowledge and I replaced the spark plugs and wires. I can still hear all the engine noise pretty clearly inside the car with the windows up.
Old 01-05-2009, 09:00 PM   #4
jwhisl
Member#: 199199
do you think it's just time for a rebuild?
Old 01-09-2009, 05:39 PM   #5
wisewhiterabbit
Member#: 84091
98 Impreza L
red
im in the same boat i got the 2.2 L impreza loud ticking and rough stumbling idle i was thinking dirty fuel filter or injectors but thats only my uneduamacated opinion on a side note before this i had 2 intake valves bent and replaced and the mech that did the work said something needed to be adjusted ?
wisewhiterabbit is offline   Reply With Quote
Old 01-09-2009, 07:06 PM   #6
jwhisl
Member#: 199199
I'm not driving the car right now but the noise is deffinitely getting worse. I haven't even put 1 mile on the car since I bought it. I've just been running it to keep the battery charged. There also seems to be a "grinding" noise coming frrom somewhere under the hood too.
Old 01-12-2009, 02:11 PM   #7
drbelleville
Member#: 107141
2006 Impreza Wagon
Dark Silver
Check your oil level, at times when the oil level is lower than usual, the pump does not get as much oil and sometimes that may mean damaged bearings, mainly the rear main. If it is good, keep an eye on it to see if you are losing any over time, if so It could mean that it is seaping out at the main or burning off past the rings. Best bet is to take it to the dealer.
Hope this helps a bit.
drbelleville is offline   Reply With Quote
Old 01-13-2009, 12:06 AM   #8
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
Mr_Snips is offline   Reply With Quote
Old 01-13-2009, 10:44 PM   #9
jfine
Member#: 200115
Default Thats my car!
Mr. Snips ... what is that noise in the clip you posted? My car is doing that and I need help figuring it out. Thanks!
jfine is offline   Reply With Quote
Old 01-13-2009, 10:58 PM   #10
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
so you hit a deer and now you have ticks? everyone knows deers carry lime disese ticks .
get some frontline i give it to my cat and he has no ticks.
i watched that whole vid and was at the end of my seat like sieze . Sieze you piece of ! sieze!
watchunglava is offline   Reply With Quote
Old 01-13-2009, 11:11 PM   #11
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
rod bearing~
Old 01-13-2009, 11:14 PM   #12
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
If the cam sprocket was destroyed then you probably bent some valves.
Tim Sanderson is offline   Reply With Quote
Old 01-14-2009, 10:57 AM   #13
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
It sounds like valve lash, I would check the valve clearance on your rockers and see if they are way off. Is it louder on either side of the heads? I did mine last night on one side and it took about 30-45 mins the other side is a little worse, you have to take out the battery and washer fluid tank to get to it.
aclver1 is offline   Reply With Quote
Old 01-14-2009, 01:29 PM   #14
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
it was the rod bearing in my video. if you think its not than feel free to come on over and move the piston up and down in the cylinder without moving the crank. or just shake that rod.
I can post the pictures of the metal in there too.
Old 01-16-2009, 12:58 PM   #15
MadDogSTi
Member#: 85428
2006 Enzo Ferrari
Check your oil dip stick, pull it out and look at the oil. If you see silver/gold shavings then your bearings are going or are gone (worn down = bad). When driving, the car should feel sluggish or lack power.
It could be piston slap, lifter tick, your valves. If it annoys you, then pull out the motor and tear it apart and inspect them.
MadDogSTi is offline   Reply With Quote
Old 01-17-2009, 10:57 AM   #16
jwhisl
Member#: 199199
The oil seems to be clean. I changed it last week and it helped a little. The noise seems to be equally loud on both sides of the engine. I know some of it is noisy injectors, but I also had a friend do the "dollar bill test" to see if it would trry to suck the dollar bill back in..... It's supposed to be a way of checking for a bent or stuck valve.
I would just drop another engine in and be done with it but a used EJ25 is hard to find for a low price
Old 01-17-2009, 12:26 PM   #17
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
have you done a compression test? do it. but you gotta do it when engine is warm.
Old 01-17-2009, 01:23 PM   #18
jwhisl
Member#: 199199
A friend of mine has one that I'm going to borrow sometime this weekend
Rough idle, intermitent and rough cold starts... carter_wrx Pre-2002 Factory Turbo Powertrain 26 10-28-2009 01:03 PM
How Rough is a Rough Idle Go350zGo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-22-2009 11:28 PM
very rough idle lean afr's at idle TDagen Open Source Reflashes 8 07-07-2008 04:28 PM
help! rough/shaky idle and ticking noise from engine resideinva Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-15-2008 09:57 PM
High Idle, Rough Idle? Brettweiser Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-09-2007 11:10 PM
